Secondary air pump noise
Discussion in 'Technical Chat' started by AaronK13, Mar 27, 2014.
  1. Mar 27, 2014 at 11:07 AM
    AaronK13
    AaronK13 [OP] Well-Known Member
    Aaron
    Nebraska
    13 TRD Off-Road
    So last night, i was installing my new K&N CAI. Almost done and I broke one of the plastic valvues on the K&N tube, so I had to put the stock air box and intake back on. But, i left the secondary airpump relocated to the front where you have to relocate it to let the new heat shiled fit. Now, i hear this weird noise. I know the '12+ models have that smog pump or maybe it is the secondary air pump that make that weird noise when you turn the engine off. I hear it at startup and when i turn it off. It is the same sound as before, just louder and a little "grindier" than normal.
    My only though, is that the secondary air pump has to be level....? Right now, it is not 100% level at the new location up front.
    Any thoughts?
  2. Apr 25, 2014 at 11:53 AM
    grubburg
    grubburg Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
