Secondary air injection system P2440 and P2442
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Saseun99, Apr 13, 2015.
  1. Apr 13, 2015 at 7:19 PM
    Saseun99
    Saseun99 [OP] New Member
    Ray
    2012 double cab
    Hi I am new to this forum and would like to know if anybody has had problems with the air pump on their Tacoma. I am a first time Tacoma owner and not happy to find out that Toyota wants to charge $1900.00 to fix my 2012 Tc with 47 000 miles on the clock. There is a lot of talk about the air pumps on the Tundra but not seen any posts about Tacoma.
    Thanks
    Ray
    Markschexnayder and ChadsPride like this.
  2. Apr 13, 2015 at 7:36 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    the secondary air injection system is part of the motor which is covered under 5 yr 60k miles.... have the dealer fix it.
    and if not under the 5 yr 60k power train... you could make a VERY strong case for coverage under the 8 year 80k mi federal emissions warranty as the sole purpose of the secondary air injection is to reduce emissions.
  3. May 9, 2015 at 8:11 AM
    WetTaco
    WetTaco Well-Known Member
    Louis
    Northern California
    2012 DCLB 4x4
    I am having the same issue with my 2012, problem is my taco has 83k on the clock, has anyone posted a diy install on this? I will most likely order a new or used one with warrenty and install it myself.
  4. May 9, 2015 at 8:18 AM
    ThatguyJZ
    ThatguyJZ Instagram: thatguyjz
    Jim
    TRIAD, NC
    2014 MGM DCSB 4x4 TRD Off Road
    A TRD OR built into a Baja/PRO hybrid
    Check the hoses that come off it to make sure there aren't any air leaks. I'm very familiar with the secondary air system on e46 BMW's but haven't really taken the time to fully inspect how the ones on these trucks work.
  5. May 16, 2015 at 7:26 AM
    ccress83
    ccress83 Well-Known Member
    Colin
    Cleveland Ohio Area
    12 Taco Sport
    Just had this happen to me 50k on my 2012. There's a lot of info on the tundra portion of this same problem, I'm gonna take mine out and try and clean it. Hopefully there is only 1 pump. Ya 2 grand is ridiculous.
  6. May 21, 2015 at 2:45 PM
    cshughes79
    cshughes79 Active Member
    chuck
    Tri cities, va
    2012 tacoma 4x4 double cab
    nerf bars;3" toytec lift 885 coils and Ol Man Emmu shocks in the front add aleaf in the rear
    I had both codes pop up on my 2012 tacoma 60K on it. Called the Dealership they told me that they only see this on the Tundra's. They quoted me a price of 1900.00 to fix, luckily i got a buddy with shop, after labor and parts it cost me 827.00. Ready to trade in the tacoma now for a F-150, need more room my midgets are getting to big for the tacoma!!
  7. May 21, 2015 at 2:59 PM
    ccress83
    Colin
    Cleveland Ohio Area
    12 Taco Sport
    Dealership quoted me at 1090. They cleared codes and said they didn't come back on so they let me go, I pulled out of dealership and they came back on. Found the part online from Boch Toyota South in Massachusetts for 426. Part should be here by Tuesday with the holiday and hopefully I'll be back up and running that night after I clear the codes myself.
    Capespencer68 likes this.
  8. May 21, 2015 at 3:07 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Not true, per the EPA the secondary air injection system is an emission control part, those are covered for 2 years or 24k miles. Only major emission control components are covered under the 8yr/80k miles federal warranty (CAT, ECU, OBD)
    http://www.epa.gov/obd/pubs/420f09048.pdf
    presta24 and FJRrider like this.
  9. Jun 4, 2015 at 2:22 PM
    blue97taco
    blue97taco Well-Known Member
    alex
    Raleigh, Nc
    Did you get it fixed? My truck is throwing both codes as well, and I'm trying to avoid taking it to a dealership. Also, did any of you drive around while having this issue? Im worried about messing something else up or being stuck somewhere.
  10. Jun 4, 2015 at 2:25 PM
    ccress83
    Colin
    Cleveland Ohio Area
    12 Taco Sport
    I drove around for alittle bit but when I was going up hills it would slow me down to about 20mph, put the part in cleared the codes before I started the truck everything went back to normal haven't thrown one yet.
  11. Jun 4, 2015 at 2:30 PM
    blue97taco
    alex
    Raleigh, Nc
    Thanks, it did the same thing to me today. I have a couple more questions for you, whats the part called? and how difficult was the install?
  12. Jun 4, 2015 at 2:50 PM
    ccress83
    Colin
    Cleveland Ohio Area
    12 Taco Sport
    http://toyotaparts.bochtoyotasouth.com/oe-toyota/2571031022
    There's the link for the part. I suggest getting the 2 gaskets also. That part number is 17377-31010. Pretty easy if you have tools and have alittle knowledge. Gotta take the air intake tubing out along with the filter housing to access the actual part. 0c5b08dd02971431c0985b54fdc79890_54e7e802e506f991e84559900eae2fedabb453b8.jpg circle is where the part is located
    CoyoteRuns likes this.
  13. Jun 4, 2015 at 2:54 PM
    blue97taco
    alex
    Raleigh, Nc
    ok, thanks a lot and were you throwing both p2440 and p2442?
  14. Jun 4, 2015 at 2:55 PM
    ccress83
    Colin
    Cleveland Ohio Area
    12 Taco Sport
    Ya both of those.
  15. Jun 4, 2015 at 3:15 PM
    blue97taco
    alex
    Raleigh, Nc
    Thank you very much. i'll buy it tonight.
  16. Jun 4, 2015 at 3:26 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I don't have a 2nd gen Tacoma, but I do have a 2nd gen Tundra.
    Why are those parts only warranted to 60k? On. The Tundra, they are warranted to 150k or 10 years.
    I only want to know for educational reasons, I did the "AIP delete" mod for the Tundra, so I will never have to worry about this issue.
    For $15,there is not a better mod you can do for the Toyota trucks.
  17. Jun 4, 2015 at 3:28 PM
    blue97taco
    alex
    Raleigh, Nc
    link?
  18. Jun 4, 2015 at 3:31 PM
    ccress83
    Colin
    Cleveland Ohio Area
    12 Taco Sport
    I had 50k. Toyota doesn't warranty the part. Not sure why that is. I think so many people had the problem with the tundras and sequoia style engines. I think thy are starting to have problems with the tacos.
  19. Jun 4, 2015 at 3:33 PM
    ccress83
    Colin
    Cleveland Ohio Area
    12 Taco Sport
    If you don't have to get an echeck that delete will work fine. I think you just deal with a engine light right?
  20. Jun 4, 2015 at 3:44 PM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    thank god early 2nd gen tacomas doesn't have this
