second gen tensioner replace after only 85k or just belt.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Soylent Green2012, Apr 7, 2022.
  1. Apr 7, 2022 at 3:38 PM
    Soylent Green2012
    Soylent Green2012 [OP] RestoRides MotorSports
    jake
    Apopka, Florida
    2012 Tacoma Pre runner SR5 V6 Limited Edition
    chrome bull bar, 20" vision wheels, LED lighting, Custom grill.
    Getting ready to change my serpentine belt (unknown if ever changed) truck is a 4.0 with 85k miles. Should i really change the tensioner with the belt? Or even go as far as the entire kit, which includes belt, tensioner and both idlers...?
    Any help would be great ...thanks
    TomTwo likes this.
  2. Apr 7, 2022 at 4:22 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    No, I would not change the tensioner.
    Not unless it feels weak. It’s a PITA to change. You need to unbolt the AC and AC bracket. And I think the Alternator needs to be moved too.
    I changed my belt at 111k miles.
    You can spin the idlers and see if they feel good. Or just replace them if you like.
    I’m at 157k now. Still on OE tensioner and idlers.
  3. Apr 7, 2022 at 4:29 PM
    Soylent Green2012
    jake
    Apopka, Florida
    I kind of figured the stock tensioner was going to last longer than this mileage wise, but the truck is 10 years old and under spring tension for that long. I think im going to get the belt and check the idlers for free movement like you said thanks tnshooter
    TnShooter likes this.
  4. Apr 7, 2022 at 4:51 PM
    Soylent Green2012
    jake
    Apopka, Florida
    Yes i understand that pretty well in this case though i dont know how old the belt is. Could be the factory belt. I would feel better if it was new.
  5. Apr 7, 2022 at 5:02 PM
    TnShooter
    Deogee
    STOCK
    I take the Lower skid plate off, let tension off the belt, and jam a small Allen wrench in the “keeper” hole. I’ll see if I can find a picture. It makes life easier.
    Then fish the belt around the fan. It’s not hard, you can do it:thumbsup:
    tacoman45 likes this.
  6. Apr 7, 2022 at 5:09 PM
    TnShooter
    Deogee
    STOCK
    When the hole on the bottom lines up with the slot, stick a something in the hole and it will stay back for you.
  7. Apr 8, 2022 at 1:29 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    I changed my belt at 90k … left everything else alone. Very important to check your belt 18545CB9-3822-4D27-9632-25A18976C955.jpg
  8. Apr 8, 2022 at 7:32 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Make sure you use a genuine Toyota branded belt. It’s worth the higher price IMHO
    tacoman45 and EL Taco Verde like this.
  9. Apr 8, 2022 at 8:16 AM
    Reggie4x4
    Reggie4x4 Well-Known Member
    Cole
    07 Red TRD OR V6 M/T 4x4
    Mostly stock
    When you lock out the tensioner to check idlers/pulleys is when you will note whether the spring in the tensioner is still good.
    Locking my old one out, at 190k miles, felt notchy, and when releasing it wasn't snappy, so out she went.
    Rockauto has Aisin tensioners for ~80 bucks whole assembly.
    Alealexi and trktwo like this.
  10. Apr 10, 2022 at 12:41 PM
    Soylent Green2012
    jake
    Apopka, Florida
    Thanks for the tips, i did buy my belt from rock auto. I always get stuff from them never had an issue. When removing skidplate is there anything else in the way of the belt removal/ installation.?
    Also would the black coating rubbing off the pulley groves indicate the belt has been slipping?
  11. Apr 10, 2022 at 3:27 PM
    TnShooter
    Deogee
    STOCK
    Nothing else to remove, just the skid plate.
    No, paint missing doesn’t mean it was slipping.
  12. Apr 10, 2022 at 4:16 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    I’m at 101k miles and about to change my belt on my 2010. Never been changed and doesn’t sound bad or anything. Just preventive
  13. Apr 10, 2022 at 4:49 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    You have 3 idlers and 1 tensioner pulley. A good indication if the tensioner spring is going is that at full throttle the belt slips and you will smell burning rubber. Or at idle the tensioner is jerking around (spring weak). With the belt off spin the pulleys and listen for rough bearings and feel if any lateral movement in the pulleys. Or if the pulleys are all rusted and pitted time to replace. Tensioner pulley bolt is reverse thread.
    Soylent Green2012[OP] likes this.
  14. Apr 11, 2022 at 3:14 PM
    Soylent Green2012
    jake
    Apopka, Florida
  15. Apr 11, 2022 at 8:20 PM
    optifree
    optifree Well-Known Member
    Gary
    Pflugerville
    2010 AC TRD
    OME
  16. Apr 12, 2022 at 3:31 AM
    Soylent Green2012
    jake
    Apopka, Florida
    If you are talking about the 2.7 then yes its dirt simple.
    4.0 is a bit more involved.
  17. Apr 12, 2022 at 3:37 PM
    Soylent Green2012
    jake
    Apopka, Florida
    I watched the video today great bit of need to know stuff there.
    Now i do have a question that was not covered in the video.
    If any of the idlers are bad where do you purchase them?
    Dealer item or auto parts stores?
  18. Apr 12, 2022 at 5:57 PM
    optifree
    Gary
    Pflugerville
    2010 AC TRD
    OME
    Only way to know is take the belt off and spin the idlers. You can probably just get a quality one from the parts store, or the dealership if you want oem.
  19. Apr 12, 2022 at 6:04 PM
    Soylent Green2012
    jake
    Apopka, Florida
    I would rather not pay dealer prices if they can be purchased from the aps. Yes i know from the video how to check them.
  20. Apr 12, 2022 at 6:06 PM
    optifree
    Gary
    Pflugerville
    2010 AC TRD
    OME
    Just go with a quality brand if you need a replacement. It'll be fine. These aren't all that special of a vehicle that requires everything to be OEM.
