Second gen Power Window Switch Wires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Manuel Portillo, Dec 4, 2022.
  1. Dec 4, 2022 at 2:38 PM
    Manuel Portillo
    Manuel Portillo [OP] Member
    Manuel
    2007 Toyota Tacoma
    4 inch lift 35 inch tires fox suspension
    Hey everyone,
    Im trying to fix the master power window switch and I was hoping someone knew what each one of the wires on the connector plug for the powers window switch did? It’s the 2007 crew cab model.
  2. Dec 4, 2022 at 3:02 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Can you read diagrams?
    If not, we’ll help walk you through it.
  3. Dec 4, 2022 at 3:03 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
  4. Dec 4, 2022 at 3:04 PM
    TnShooter
    Deogee
    STOCK
    Door lock
  5. Dec 4, 2022 at 3:18 PM
    Manuel Portillo
    Manuel
    2007 Toyota Tacoma
  6. Dec 4, 2022 at 3:24 PM
    TnShooter
    Deogee
    STOCK
    Let’s start easy.
    You need to unplug the connector form the switch.
    Once unplugged, the connector will look like the one in the picture.
  7. Dec 4, 2022 at 3:31 PM
    TnShooter
    Deogee
    STOCK
    Next look at the diagrams.
    You’ll see 2 circles “A” and “B”.
    You want to use the Numbers by the “A” circles.
    The number represents the pin number
  8. Dec 4, 2022 at 3:33 PM
    TnShooter
    Deogee
    STOCK
    If you want to know why you are using the “A” circles.
    It’s because it’s 1* is for Double Cab.
  9. Dec 4, 2022 at 3:37 PM
    TnShooter
    Deogee
    STOCK
    So, in this example Pin #7 should have a red wire coming out of it.
    If you look at the full diagram, that wire goes to the 30A D FR Fuse.AB7F7FAE-6F49-4EA1-B1FA-95AD957A2ED8.jpg
  10. Dec 4, 2022 at 3:47 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    It would help if you stated the specific issue.
    TnShooter likes this.
  11. Dec 4, 2022 at 3:56 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    The way I understood his other thread he's trying to put a 2016 switch and door panel in his 07. I looked at the diagrams and the 2016 has 2 different power window options, the basic one "may" work if the connector is repinned but the other one definitely wouldn't work.
  12. Dec 4, 2022 at 4:08 PM
    TnShooter
    Deogee
    STOCK
    I seen that thread, but didn’t realize it was the same OP.
    OP, that’s more work than I’d be willing to do.
    If you get it to work, let us know.
  13. Dec 5, 2022 at 10:00 AM
    Manuel Portillo
    Manuel
    2007 Toyota Tacoma
    Thank you everyone for the help this actually make sense now. Once I fix the mess I already made with my current switch and get ball rolling, I'll update you guys and share how I get it to work.
