Seat Bolts/Threads Stripped! How to?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Relik, Dec 13, 2010.
  1. Dec 13, 2010 at 1:18 PM
    Relik
    Relik [OP] Well-Known Member
    Eddy
    Thousand Oaks, CA
    '11 TRD Sport PreRunner-Auto-Magnetic Gray
    Bilstein 5100s (Front & ext. Rear), Eibach coils @ 0, MaxTrac 4" Spindles, Light Racing UCAs, 1/4" lean spacer, All-Pro 3" Standard leafs, u-bolt flip kit, SpiderTrax 1.25" wheel spacers, 33" (285/70/17) TreadWright Warden A/T tires, extended lines
    Hey guys,
    Took my tacoma to get detailed and they needed to remove the seats to clean all the carpeting.
    (Cab was flooded, pics at bottom: http://www.tacomaworld.com/forum/so...05-trail-run-hungry-valley-12-11-10-a-12.html)
    Interiors all clean now, but one issue is I noticed my passenger seat front mounting bolts were loose (The washer was loose), and that one bolt even looked slightly crooked! I went ahead and removed them for a proper install and could not put them back in! (didn't want to force it ofcourse)
    I removed one of the rear bolts to see if it would work but it could not correctly screw in the front mounts :-/ The bolts do look a bit stripped, they are also are odd looking, with a smaller thread tip which gets larger 1/4" in up. It seems to looked stripped right at the transition of diameter.
    So damn detailers stripped my mounts! Anyone know the proper tap to use to fix? Ideas?
    Thanks,
    Eddy
  2. Dec 13, 2010 at 1:22 PM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    Its probably an M10 1.25 pitch bolt, but I am not completely sure without checking with a gauge.. I would get new bolts, and run a thread chaiser through the floor to clean the threads up. From the way you decribed it, its probably savable
    Justin
  3. Dec 13, 2010 at 1:23 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    What size are the bolts? You just need the corresponding tap, should work like a charm. Remember to run it in a full turn, then back out, then two turns, then back out- it allows all of the metal shavings to work their way out as you go as opposed to just twisting the tap all the way in. You can get a set for a decent price at Autozone, or you should be able to just rent it for them at the same price.
  4. Dec 13, 2010 at 1:24 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    X1..........good luck
  5. Dec 13, 2010 at 3:05 PM
    Relik
    Eddy
    Thousand Oaks, CA
    Yeah I went back a second time the day after it happened because I was concerned of the little amount of moisture still present under the carpets and they dried what they could (looked like they just shoved towels under the carpets and used a heat gun?. Yeah gonna charge it back....
    Ive left the truck venting and its very dry, carpet is 100% dry, insulation is 90% and slight moisture between plastic film of carpet and metal. But honetsly im still unconfortable for how it is under, so I think I'll definitely remove it all and tidy up myself, thanks for the advice.
    Oh and would this work for the thread chaser? It says its for spark plugs... http://www.harborfreight.com/10mm-14mm-spark-plug-thread-chaser-66033.html
    Will get to order new bolts too, hopefully not expensive.
    I was gonna post another topic, but my Airbag light has also been on ever since, did you have the same issue Oswego?
  6. Mar 23, 2017 at 5:11 AM
    Brent33hernandez
    Brent33hernandez New Member
    Brent
    2009 Toyota Tacoma access cab
    1000 amp and 10 woofer. 6.5 inch bass component speakers in access doors. 6x9 component speakers in front doors
    I have a 2009 tacoma. The exact same thing just happened to me. Anyone able to give me a link of what thread kit I need to buy. And if possible tell me where I can buy new bolts. ..
  7. Mar 23, 2017 at 7:45 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Take it back to the detailer and talk to the owner about paying the dealer to fix it. That's a safety issue.
    This is something that should never happen at a professional detailer. Its called a detail shop for a reason
  8. Mar 23, 2017 at 8:17 AM
    Doughnut Spaghetti
    Doughnut Spaghetti Well-Known Member
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    So the bolts strip (the threads) when removed? That's kinda strange. Are they thread locked in? Maybe need to heat them prior to removal. In my Porsche the seat bolt heads would strip and you have to use a hammer and cold chisel to get them out, but he thread were fine. Then would replace them with a higher quality bolt.
    I've already been wanting to replace the bolts in my Tacoma with something nicer. So this is good info to know.
  9. Apr 5, 2017 at 4:56 PM
    huff.jeremy
    huff.jeremy Well-Known Member
    Illinois
    2010 MagGray SR5 Access Cab, 4x4, 2.7L, 5spd
    OME 884's, OME shocks, Wheelers 1.5" AAL, Light Racing UCA, Jason Fiberglass top, URD Short Shifter, Fog Lights
    I just finished the process of removing and installing my seatsfor a project. I didn't notice any threadlock, but the bolts definitely required more torque to remove than a bolt that size should... they all released with a sharp "POP". I'm actually surprised I didn't have mangled threads.
    What I did notice was that each bolt had a strange whitish corrosion on the head and washer. I would bet money that there is a galvanic corrosion issue (dissimilar metals affecting each other) that is causing the problem.
