Sealing gap around Sosche DD radio kit?
Discussion in 'Audio & Video' started by drewskie, Apr 9, 2018.
  1. Apr 9, 2018 at 3:08 PM
    drewskie
    drewskie [OP] Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    How did you seal the gap left around the radio? I installed a Kenwood DD dvd player and it fits well in the dash, but there is a big gap between the kit and the radio. The ring that came with the Kenwood is way too big, and the little dinky plastic that came with the Sosche is too small and doesn't fit anyway.
  2. Apr 10, 2018 at 1:59 PM
    drewskie
    Drew
    Burbank, CA.
  3. Apr 10, 2018 at 2:25 PM
    vietjdmboi
    vietjdmboi Well-Known Member
    Hieu
    Orange County
    '18 Tacoma TRD Off-Road
    this is where masking tape and bondo come in.
    tape off area
    bondo
    sand
    paint
  4. Apr 10, 2018 at 2:58 PM
    Purpleman
    Purpleman Well-Known Member
    Anaheim
    15 PreRunner
    Black auto carpet.
  5. Apr 10, 2018 at 3:04 PM
    DaMaDo
    DaMaDo Well-Known Member
    Northern AL
    2018 White TRD Pro
    I had the same issue and I realized it's made for the 6" radio on the base model and I have the 7" radio, so I had to use the crappy free one that crutchfield sent me. An alternative is to buy the factory panel for the 6" radio.
    drewskie[OP] likes this.
  6. Apr 10, 2018 at 4:09 PM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    Black foam tape.
    ypahuboy likes this.
  7. Apr 10, 2018 at 10:56 PM
    ypahuboy
    ypahuboy Well-Known Member
    Brian
    2009 Tacoma DCSB TRD OR
    +1
  8. Apr 11, 2018 at 7:44 AM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    The flimsy Scoche trim ring worked 85% good enough but not competition or show-car grade. Its loose on the bottom, but not noticeable, at least with an Alpine unit.
    Maybe you have a depth issue? Are you re-using the stock radio brackets? I only had 2-3 mm gap between the bracket and the face of an Alpine.
  9. Apr 11, 2018 at 1:04 PM
    drewskie
    Drew
    Burbank, CA.
    I think I did have the brackets set too far forward on the unit, so I moved them back about 1/4 inch and it does work much better, but still a small gap. I am using the factory brackets,but was only able to use 3 screws.
  10. Apr 11, 2018 at 1:17 PM
    mbrogz3000
    Northern NJ
    Sounds like you have the depth correct. My factory brackets had alignment pips which fell into place on the Alpine frame, which set the depth for me. No guesswork or trial/error in setting the radio depth.
    Cheapest and easiest fix might be to carefully shave down the Kenwood trim ring with a dremel drum or cut off wheel. Take some measurements with the radio installed, and gradually trim the trimring bezel until it fills the gap.
  11. Apr 11, 2018 at 8:16 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    I have the same problem on my 2013. It’s a different Scosche kit for 12+ but I have about a 3mm gap on the bottom edge of my unit. The top edge has about a 1-2mm gap. Sort of disappears when mounted but is bothering me. I might go back and do some black foam tape just to bridge the gap and call it a day. Or get a trim ring and cut it up and epoxy it in place where needed.
