Sealing a 2020 bed prior to canopy
Discussion in 'Tonneau Covers, Caps and Shells' started by Davis1891, Sep 7, 2020.
  1. Sep 7, 2020 at 3:31 PM
    Davis1891
    Davis1891 [OP] Well-Known Member
    Alberta
    2020 OR DBSB
    None yet
    Hey guys, I recently bought a 2020 DCSB OR, and my new cap-it brand bulldog canopy comes in a couple weeks and I'd like to waterproof my truck as much as possible before hand.
    I've looked through the threads and as near as I can tell the 2020's have plastic railings all over the top of the bed. My 18 didnt and I don't see anything for the 2020's
    Does anyone know if I should remove these and apply something? I have a bunch of butyl tape that I'm going to stuff into the tiny gap shown in the first picture, but past that I'm unsure if I should do anything else.
  2. Sep 8, 2020 at 6:33 PM
    OntarioExPat
    OntarioExPat Member
    2020 Quicksand DCSB TRD Off Road
    I just filled those gaps with butyl, installed an ESI “Ultimate Tailgate Seal” Kit I bought from Amazon, and called it a day...
    Davis1891[OP] likes this.
  3. Sep 9, 2020 at 5:15 PM
    Nardogg
    Nardogg Well-Known Member
    19 Cement TRD Sport M/T
    Wheels/Tires, Some Meso Stuff, TURD grille. Hoodscoop Light Bar, Can-o-PY
    When did you order your cap i ordered July 2 Cap it cl-t they initially said 4-5 weeks afer the 5 weeks i called for an update they said the factory is backed up another 2 weeks thats came and gone already just curious of your last contact with them. (Ordered mine through Capit edmonton south)
  4. Sep 9, 2020 at 5:19 PM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    When I picked up my then brand new ARE MX the topper dealer used a "kit" to seal everything up as part of the free dealer install package. Its been just over a year of many heavy storms and no leaks. Your dealer may do this also.
  5. Sep 10, 2020 at 2:07 AM
    Mtn Mike
    Mtn Mike Well-Known Member
    Spokane, WA
    2017 TRD OR AC
    You should also add sealant under the plastic bed railings. What do you mean when you say your 18 didn't have them? I thought all 2nd and 3rd gens had plastic railings.
  6. Sep 22, 2020 at 6:30 PM
    GoodTalk
    GoodTalk Active Member
    Spencer
    2017 Tacoma Pro
    Black silicone works wonders. Took that bar off and just silicone all around it. Now the tailgate will still leak a little.
  7. Oct 8, 2020 at 10:36 AM
    Andocalrisian
    Andocalrisian Well-Known Member
    North Vancouver BC
    2015 Tacoma SR5 Access
    How do you like that seal kit? Decent quality? Think it'll last?
  8. Oct 10, 2020 at 2:06 AM
    OntarioExPat
    OntarioExPat Member
    Yeah, I'd say it's pretty decent quality. It definitely seals all three sides up pretty snug (I don't see any light passing through with the tailgate closed). Just make sure to clean all of the surfaces that the (3M) tape will be sticking to really well. I used rubbing alcohol after washing with soap and water. Also, there is plenty of it to do both sides and the bottom gap where the tailgate meets the bed, but measure twice before you cut. Probably best to keep the pieces continuous from end to end. The instructions on the ESI website are pretty decent and vehicle specific, so install was a relative breeze. As far as how long it'll last, I guess time will tell. So far so good though!
    Andocalrisian likes this.
