Seafoam Spray for my fuel injectors....Yes or No?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PFD FIRE, Dec 10, 2015.
  1. Dec 10, 2015 at 6:05 AM
    PFD FIRE
    PFD FIRE [OP] Well-Known Member
    David
    San Diego
    2011 Toyota Tacoma TRD Sport
    265/75/16 Goodyear Duratrac Tires, Total Chaos UCA, Bilstein 6112 Coilovers (front) Bilstein 5100 (rear), TRD CAI, TRD Cat Back Exhaust, Rough Country/Lamphus LED lights, rear ARB locker, Baja Rack
    I have 80K on my 2011 Toyota Tacoma Sport and its time to do a complete overhaul. This includes:
    -Fuel injector cleaning
    -Flush and replace the transmission oil
    -replace brake and power steering oil
    -replace motor oil with synthetic oil
    -replace oil on front/rear diffs and transfer-case
    -last but not least replace my radiator fluid
    Its a long list of stuff to do!
    My question, does Seafoam spray really work or should I take my truck to a mechanic and have them pressurize the system with additives to remove all the gunk.
    PS: my truck is running great, so before I get people telling me you don't need to change this or that......This is all preventative maintenance. My truck is due to run like new again:)
  2. Dec 10, 2015 at 6:14 AM
    TexasPreRunner
    TexasPreRunner Well-Known Member
    Anthony
    San Antonio/Houston,TX
    2011 PreRunner
    Here's a video
    https://www.youtube.com/watch?v=u6UeJXkzDW8
    Do not flush your transmission just change the fluid
    Synthetic oil, it's a majority vote on this site for Mobil one
    Diffs are done every 30k if I recall, at least that's what my book says for the rear
    Radiator fluid is good till 100k toyota just adds a conditioner to it at 60k I believe
  3. Dec 10, 2015 at 6:24 AM
    PFD FIRE
    David
    San Diego
    Thanks for the heads up! Im guessing that using see foam is a heck or a lot cheaper then taking it to a mechanic to have the injectors flushed. I've seen that video and wis pretty impressed how much gunk was removed. Whats you opinion on Techtron Chevron additive that you pour in you gas tank for preventative maintenance? I was told this stuff is good to use after every oil change to prevent gunk build up
    PS: Why do you recommend not to flush the transmission housing before adding new transmission oil?
  4. Dec 10, 2015 at 6:40 AM
    TexasPreRunner
    Anthony
    2011 PreRunner
    I use a bottle techron every oil change.
    Personal experience with transmission problems with a higher mileage flush, I've always been told anything above 60k just replace the fluid, before 60k go ahead with the flush
  5. Dec 10, 2015 at 7:41 AM
    Holeshot
    Holeshot Well-Known Member
    Gary
    Alabama
    15 Doublecab TRD Off Road 4 X 4
    Yes on the SeaFoam and Techron. Have had good results with both.
  6. Dec 10, 2015 at 11:08 AM
    PFD FIRE
    David
    San Diego
    I just used a bottle of Techron with 20gal of "unleaded plus" and I got to say I did feel a difference. My tacoma felt faster on the freeway, maybe its my imagination or maybe its the fuel grade I used "unleaded plus" 89 octane. I typically use reg. unleaded, figured I'd try something different:)
  7. Dec 10, 2015 at 3:02 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Seafoam has zero ingredients in it to break down gasoline that is gummed up in the injectors.
    Get a proper injector cleaner like redline s1 or gumout with regane
  8. Dec 10, 2015 at 3:14 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    The Elders have spoken...
    Jerry311SD likes this.
  9. Dec 10, 2015 at 3:18 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    I don't quite trust what Seafoam burnoff is doing to your catalytic converters.
    The coolant interval is funny. The maintance booklet says the first replacement is due at 10 yrs / 100k but subsequent replacement is at 5 years...
    DoorDing likes this.
  10. Dec 10, 2015 at 3:49 PM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    Just get a few cans of Seafoam and pour one in your gas tank before next fill-up. I used to have a low-mile 85 Mustang GT (carbureted) that mostly sat. When I would get it out to drive,it always had a hesitation when you would get into the throttle. I would pour some Seafoam in the tank,and I swear within minutes it cured the hesitation. Believe it or don't.
  11. Dec 10, 2015 at 4:58 PM
    Marker4
    Marker4 Member
    2015 taco
    Sea foam absolutely works. I have been using this as a combustion chamber cleaner and fuel additive for years. One of the best ways to remove carbon I have ever found.
    airrage likes this.
  12. Dec 10, 2015 at 5:23 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Just my 2 cents:
    If there is contamination / gunk inside the fuel injector there isn't a damn thing you can do about it. Period. A few skin cells can cause an injector to stick open or closed. Really close tolerances... If something is inside it is going to get stuck.
    There is a one micron filter pressed in the inlet of the injector. The injector is assembled and tested in a clean room environment. They are welded together and usually molded. They can not be disassembled or opened for cleaning.
    If you are wanting to use a product like Seafoam, just put some in the gas tank in the gasoline and it at best will help keep the injection orifices clean on the outside of the injector and maintain the spray pattern. It will not give you more power etc...
    Anyone that is telling you different is just jacking you off.
  13. Dec 10, 2015 at 5:47 PM
    Holeshot
    Gary
    Alabama
    How did you know I am an Elder? But you are correct just not in the religious sense. In that case I would qualify as a Deacon.
  14. Dec 10, 2015 at 5:52 PM
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    People swear by this stuff. It belongs on the golden shelf of things that can pretty much do anything right next to duct tape and baking soda.
    1Shifter and Holeshot like this.
  15. Dec 10, 2015 at 7:47 PM
    PFD FIRE
    David
    San Diego
    Thank goodness my injectors are working just fine. For preventative maintenance I added Techron along with unleaded plus (89 octane fuel) and did notice a extra boost of power on my Tacoma. Don't know if thats coming from the Techron or Unleaded plus, maybe its just my imagination...lol. If my engine begins to lag Im taking it to my mechanic that I trust and getting a full on pressurized/chemical injector cleaning. Sticking with Techron the least invasive!
  16. Dec 10, 2015 at 8:06 PM
    1slowvq37
    1slowvq37 Well-Known Member
    Jose
    Tecate BC MX / Chula Vista CA
    bone stock superwhite trd sport
    new car smell pine
  17. Dec 10, 2015 at 8:18 PM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    Icon ext. travel 2.5RR in front, Icon ext. travel 2.0RR in rear, BuiltRight uniball UCAs, Wheelers Superbumps, Goodridge steel braided brake lines, BruteForce front plate bumper w/ Warn M9000+synth line, American Auto Horns ACDF, Pelfrey Bussman mount+Sandman bussman fuse block (soon), 255/75R16s on painted stockers...because I'm not paying $800 to rock rash new wheels you scrubs. Shok Industries 2/0 big 4 upgrade and sound deadener.
    Seafoam has it's place and although it might not be referred to directly by manufacturers, it somewhat cleaned up a valve issue my buddy was having in his Charger (due to a TSB which he subsequently had to have the dealer actually fix by doing basically the same thing with a Mopar branded product). I personally toss some Techron in when I get a wild hair up my ass and call it a day.
  18. Dec 10, 2015 at 8:37 PM
    KenLyns
    Belly of the Beast
    In Sept., I poured in a bottle of STP fuel system cleaner (the most expensive one, 5-in-1 or something :anonymous:) and the exhaust smelled funny on the first startup. Other than that, I noticed no change in engine performance. My truck had 43,000 miles on it at the time.
  19. Dec 10, 2015 at 9:28 PM
    nd4spdbh
    SoCal
    This is because again.... Seafoam does not have any ingredients in it to break down fuel gumming. Techron has some (PEA) , gumout with regane has a lil more, redline s1 has the most concentrate of PEA.
  20. Dec 10, 2015 at 10:20 PM
    PFD FIRE
    David
    San Diego
    Im keeping it simple, unleaded fuel (87 octane) and a bottle of Techron every 3000 miles. My truck is pushing 80K and still runs good and want to keep it that way.
