Screw type bottle jack
Discussion in 'Technical Chat' started by SphericalCow, Apr 10, 2016.
  1. Apr 10, 2016 at 2:42 PM
    SphericalCow
    SphericalCow [OP] Member
    I was teaching my son how to change a tire on the Tacoma... and had the pleasure of using the OEM screw type bottle jack. Actually, I was impressed by its travel... When I first saw it I thought "no way this will extend far enough."
    I've never used a screw type bottle jack... Anyone know how the internals work on this? Is it mechanical or hydraulic? Has to be hydraulic, right? it more than doubled it's length.
  2. Apr 10, 2016 at 2:57 PM
    Clearwater Bill
    Billy
    Largo Florida
    Mechanical. Hence the 'screw'.
    Hydraulics you pump. And they will eventually leak, so not the best choice for an OE jack/spare changer.
    tomwil likes this.
  3. Apr 10, 2016 at 5:02 PM
    SphericalCow
    Yeah, I didn't know if there was an actual screw mechanism, or it was called that because of the rotary motion used to jack it up. I'm curious exactly how the internals are arranged... as what I know about a screw jack... the screw is a fixed length... how does this jack more than double its collapsed length?
  4. Apr 10, 2016 at 5:06 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Perhaps it is a screw within a screw. I believe the jack does extend in two stages.
  5. Apr 10, 2016 at 5:09 PM
    SphericalCow
    There definitely are 2 sleeves... the first one extends... at that point I thought it wouldn't make it... then another sleeve extends. I thought it was a clever design and tried to Google it (I just like to know how stuff works)... but ended up empty. Thought I'd try here.
  6. Apr 10, 2016 at 5:45 PM
    Clearwater Bill
    Billy
    Largo Florida
    Correct. Double screw. While you don't get 3x closed length, you do get more than 2x, as you found. I've never seen the internals either. Maybe I'll pick one up at a junkyard and cut it open. In honor of dear old dad. He loved doing stuff like that.
  7. Apr 10, 2016 at 5:50 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    This is the best I could find. Just Imagine that you are turning the center screw from below. When it tops out, the outer screw would start to turn.
  8. Apr 12, 2016 at 4:58 AM
    SphericalCow
    Thanks for the replies. That's a good diagram... I suspect you are right in that the screw is just turned from below. I do like the idea of getting an old one to cut open. Clearwater Bill, If you don't report back in a couple of weeks, I may give it a try... "inquiring minds want to know!"
  9. Apr 12, 2016 at 5:57 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
