Screw in tire - repair or replace?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by slyguy47, May 25, 2022.
  1. May 25, 2022 at 3:48 PM
    slyguy47
    slyguy47 [OP] Nerd
    Jacksonville, FL
    15 AC TRD OR V6 4WD 5AT
    Looks pretty fresh as it's still sticking out about a 1/4" or less. Driver side rear. Currently running 265/70R16 Wildpeak A/T3W's with 40k miles. The spare is the same size but OEM so likely 7 years old.
    Was planning on a road trip and vacation this weekend. Is a plug not a good idea with how close to the edge the screw is? Ultimately looking for the cheapest long-term option that won't leave me stranded for the 1k miles I'm driving this weekend.
    If I do need to buy new tires, I assume I need to replace two at a time? Will there be any issues if one axle's tires are 40k mi more worn than the other axles? I suppose if I buy 2, might as well buy a 3rd to be my new full size spare? Thanks for the help y'all.
  2. May 25, 2022 at 3:50 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Where it is and the type of screw it looks like I'm betting it's only in the tread block and hasn't reached the carcass or belts.
    Either way you should take it out now.
    If it does leak unfortunately it's outside the "repairable" zone per pretty much all tire shops though I have plugged ones near the shoulder and never had issues.
    YMMV.
  3. May 25, 2022 at 3:55 PM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    ^This.
    If you do end up needing to replace the tire I'd consider getting a full set. They may only have 40k and decent tread depth but there's a decent amount of cracking I can see so I'm guessing they're getting a bit long in the tooth and are near the recommended ~5-7yr replacement interval.
  4. May 25, 2022 at 3:56 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Take it out. If it leaks, plug it. If it doesn't, let it be.
    I pulled a nail out of one of my tires a couple of weeks ago. It was a small nail and was between the tread blocks so I didn't want to hog out the hole for a plug. I found a short drywall screw, wrapped it liberally in Teflon tape and screwed it into the hole and snugged it down. It's been holding air fine.
    You won't get away with that here because it's on a tread block but a plug, if needed, would be fine in my opinion.
  5. May 25, 2022 at 4:02 PM
    TacoNonspecialist
    TacoNonspecialist Well-Known Member
    Noblesville, Indiana
    17 trd sport MGM DCLB 4x4 wtftacosōs
    Driver mod, KDmax, eibach, wheelers, morimoto, and ricer pro grille
    Take it out and see if it's leaking. The tire per T.I.A. standards requires replacement if it is leaking, however if it was mine I'd ram a plug in and rock it. If it is leaking, 99% of shops won't repair it.
    Silentshredr likes this.
  6. May 25, 2022 at 4:13 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Get a good tire plug kit and learn how to use it. I just went though this earlier this year and learned how to plug a tire. Still running strong.
    b_r_o likes this.
  7. May 25, 2022 at 4:29 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    If you’re going to buy 3 you might as well buy 4 and use the best used tire as your spare (which hopefully you’ll never have to use.)I would not mix new tires with old tires that have 40,000 miles on them. You’ll have better handling on road if all 4 match and off road you’ll have better handling and traction, especially in 4wd if all 4 are the same. I think (not positive) braking is better if all 4 match. I also read that Toyota recommends all 4 replacement on 4wd where there is a large tread difference. (I’m talking 4wd. I know awd is a totally different discussion, you definitely replace all 4 on awd). So bite the bullet and get all 4.
    That screw is so close to the sidewall I doubt a tire shop would plug it but you should take it to one or two and find out. If they say ok to plug I wouldn’t hesitate to plug it.
  8. May 25, 2022 at 4:53 PM
    Normshark
    Normshark Well-Known Member
    Great White North
    2014 Tacoma DCLB Limited
    Pull the screw to see how long it is. If it's all the way through and leaks air, new tire time since it's too close to the sidewall and not safely repairable.
    Cheers.
  9. May 25, 2022 at 4:57 PM
    Stuck Sucks
    Stuck Sucks Aerodynamic styling with functional design
    Jim
    North American Plate
    If it were me, I'd remove the screw and then use a plug kit (yes, it will be leaking). Fill back up with air and you're on your way in five minutes. I've been down this road 100 times, and the repair has always worked.
  10. May 25, 2022 at 5:20 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I agree. If you plug it and want to be “safer”. Keep it on the rear. The few times I’ve spit plugs was when they were on the front.
    And again, like stated above. It is out side the “safe to patch” zone. So do so at your own risk.
    Jimmyh likes this.
  11. May 25, 2022 at 5:36 PM
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    Patch kit is cheap and easy fix. Happened to my old truck years ago. If you don't have enough money for all new tires then use patch instead for now... then you get new tires later whenever you are ready. I had no issues with them.... I mean no leaking from patch for about a year or two before getting new tires.
  12. May 25, 2022 at 5:54 PM
    07RedTacoDawg
    07RedTacoDawg Well-Known Member
    Danny
    Jamestown , NC
    07 Red Tacoma
    2 inch lift , tires and wheels
    Plug and play
  13. May 25, 2022 at 5:57 PM
    slyguy47
    slyguy47 [OP] Nerd
    Jacksonville, FL
    284205685_5439951469372954_7217237159585411440_n.jpg 283793818_5439951722706262_2528281255607669740_n.jpg
    Very small/slow leak as indicated by soapy water. Thinking I might go with a plug. Just bought this Slime plug kit from Walmart.
    Robnik and 07RedTacoDawg like this.
  14. May 25, 2022 at 5:57 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Having 40,000 miles on the tires makes a difference to me. I'd say the chances of it leaking when the screw comes out are less than 50/50. It will probably not leak. If it were MY tire, with 40,000 miles on it I'd plug it myself if it does leak. But I'd probably go ahead and replace all 4 tires soon. After your weekend trip.
    If it were a like new tire I might plug it as a temporary fix for a few days, but would replace that one tire.
  15. May 25, 2022 at 7:09 PM
    slyguy47
    slyguy47 [OP] Nerd
    Jacksonville, FL
    Plugged! No leaks. Only time will tell if this works. Might do 50 highway miles on it before the weekend to make sure it's (somewhat) good. Thanks to all for the advice.
    69 Jim likes this.
  16. May 25, 2022 at 7:18 PM
    wudafxtht
    wudafxtht Member
    david
    2011 Double cab long bed 4x4
    Make sure it's leaking
  17. May 25, 2022 at 7:26 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Just try to plug it. If the plug doesn't work you need a tire anyway.
    After the plug goes in with the rubber cement, light it on fire so the glue will dry and set. Don't worry the whole tire won't go up in flames, the glue will sizzle for about 10-15 seconds and then the flame will go out
    We repair a ton of tires at my shop and rarely use patches. If set properly the plug will last the life of the tire
  18. May 25, 2022 at 7:49 PM
    TnShooter
    Deogee
    STOCK
    I have that same kit.
    It doesn’t ream the hole for $hit.
    Good luck trying to get the hole big enough to press the plug through with that reamer.
    I resorted to a drill bit :eek:
  19. May 25, 2022 at 7:55 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer), Factory/TSB OEM rear leaf spring modification.
    Had the same issue recently. The much dreaded and hated TPMS turned on the light and warned me of it on start up. It was a fresh looking screw that was leaking enough to set it off. Have them repair it with the plug and goo. If it still leaks, have them remove the tire and place a patch on the inside. It's worth it: I have lame "Acme" brand tires on mine: Ya: a new tire is $275 minimum + yada yada yada: NASA balancing, hazardous waste fee, "convenience fee", "old looking clueless guy fee" minimum on mine: Cranks it up to at least three-bills. If the shop refused to repair it I'd get the kit at Autozone and do it myself: right in the tire shops' parking lot that tried to scam me. YMMV, but it looks like you have another 40,000 miles left on those tires. If they are Michelin, make that 50,000.
  20. May 25, 2022 at 8:00 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Well there are reasons we don’t repair in that area and no shop that follows regulations is going to fix it so keep that in mind. A blowout on the freeway could cost you a hell of a lot more then tires. I know it’s not what you want to do but I say don’t risk it and just get yourself some new tires. Either way stay safe bud.
    Normshark likes this.
