Scratches on window of new 2023 OR
Discussion in '3rd Gen. Tacomas (2016-2023)' started by myshoulderhurtsme, Apr 4, 2023.
  1. Apr 4, 2023 at 6:41 PM
    myshoulderhurtsme
    myshoulderhurtsme [OP] Member
    2023 Lunar Rock OR
    I have had this truck for less than two weeks and just saw today that it has the relatively large scratch on the back driver side window. There’s a ton of smaller ones running alongside it as well that the camera can’t pick up. There’s also what’s best described as horizontal smudging that runs in the same path pretty much from top to bottom of the window. This has to be a mechanical issue that occurs from rolling the window up and down right? Should I just take it straight to the dealership? Has this happened to anyone else? Any advice would be greatly appreciated.
  2. Apr 4, 2023 at 7:01 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Take it to dealer. Can't see it in pics. First I have read about it.
  3. Apr 4, 2023 at 7:02 PM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    Probably from the cocaine razor blade they used to remove the window sticker.
    vivid02, Jamesk, Sungod and 4 others like this.
  4. Apr 4, 2023 at 7:02 PM
    908tacoma
    908tacoma Well-Known Member
    New Jersey
    2018 MGM
    OME, SPC, TRD
    Go to dealer. Then update us. Unacceptable
    myshoulderhurtsme[OP] likes this.
  5. Apr 4, 2023 at 7:03 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW…
  6. Apr 4, 2023 at 7:03 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Maybe sand and or grit from the transport?
  7. Apr 4, 2023 at 7:29 PM
    myshoulderhurtsme
    2023 Lunar Rock OR
    Will likely be going to the dealership ASAP. This seems like a Toyota problem but I’m always pessimistic when going to dealerships. I had a Kia before this and they never took responsibility for anything when I had issues.
    908tacoma likes this.
  8. Apr 4, 2023 at 7:40 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    blemishes are tough unless your dealer wants to help. Many will tell you it wasn't that way on pickup. But, still try and get in there quick, call in the morning.
    good luck!
  9. Apr 4, 2023 at 9:41 PM
    Gord0
    Gord0 Well-Known Member
    Get some polishing compound, deal with it and move on.
    deaps, vivid02, DWD484 and 1 other person like this.
  10. Apr 4, 2023 at 9:43 PM
    MGMDesertTaco
    did the dealer tint the windows? tint person probably went crazy with the knife.
  11. Apr 4, 2023 at 9:59 PM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    If you can feel it with your fingernail, you are not polishing the scratch out of glass, (or paint, for that matter). Ski
  12. Apr 4, 2023 at 11:05 PM
    myshoulderhurtsme
    2023 Lunar Rock OR
    you can feel it with your fingernail from the outside of the window
  13. Apr 5, 2023 at 4:41 AM
    cwdog
    cwdog Well-Known Member
    Asheville, NC
    2017 Tacoma Limited
    Meguiars Ultimate Wax, Rain-X, Dog Bed, Undercover Tonneau Tri-Fold, Debadged.
    Didn't you buy this truck at a dealership, new, with warranty?
    RIX TUX likes this.
  14. Apr 5, 2023 at 4:51 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    ok I'll say it...
  15. Apr 5, 2023 at 5:23 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    From the outside? I find that to be very bizarre. Most glass coatings are on the inside, and its the film coat that scratches easily. Glass is not easy to scratch.
    Chew likes this.
  16. Apr 5, 2023 at 5:41 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    it's probably from the microfiber rags they use to clean it. i thought mine had a bunch of microscratches but it was just fibers embedded in the glass from the microfiber rags i was using. try clay bar for cleaning up the glass and vinegar. use paper towels, not microfibers.
  17. Apr 5, 2023 at 6:53 AM
    Gord0
    the point was “move on”…
  18. Apr 5, 2023 at 7:28 AM
    skidooboy
    central lower mich
    people wearing rings, watches and other objects scratching the outside of the glass. or heavy debris in wash rack spinning brushes, or drying towels. glass is soft, and scratches pretty easily. I am highly doubting the dealer will do anything. it is possible toyota may warranty the glass but, still doubtful. all you can do is check in to it, then move on. Ski
  19. Apr 5, 2023 at 9:34 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Most of that is unlikely but not impossible.
    The only common objects capable of scratching sheet glass are diamonds, a hardened chromium drill bit, and maaaaybe quartz if the pressure is right. Stainless and jewelry grade alloys do not scratch glass. Most sand and gravel, despite containing quartz, also does not scratch. It has to be pressed and vigorously rubbed. Most of those you wouldn't see without also seeing paint/body damage.
    /pedant :cookiemonster:
    hiPSI and myshoulderhurtsme[OP] like this.
  20. Apr 5, 2023 at 10:10 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    They use one of these?
    I bought a car in LV and they used these on the lot and I didn’t notice until I got home to the Bay Area.
    MGMDesertTaco and Kev250R like this.
