Scratches... Meguiar’s ScratchX 2.0?
Discussion in 'Detailing' started by CQB 1911, Sep 26, 2011.
  1. Sep 26, 2011 at 7:49 AM
    CQB 1911
    CQB 1911 [OP] Well-Known Member
    Jesse
    AZ.
    2010 TRD OR AC
    Anyone have any luck with Meguiars ScratchX? I have a 2010 in Magnetic Gray and it seems like everyday I see a new scratch on it. :( If not ScratchX can you recommend anything else?
  2. Sep 26, 2011 at 8:00 AM
    fishntaco
    fishntaco Well-Known Member
    Josh
    Mobile Al
    08 Silver Streak DCLB Prerunner Sport
    Are you only working by hand?
  3. Sep 26, 2011 at 8:45 AM
    CQB 1911
    Jesse
    AZ.
    2010 TRD OR AC
    Yeah, I don't have a power buffer. I do have a drill and I've seen some buffers that attach to a normal drill motor.
  4. Sep 26, 2011 at 8:50 AM
    fishntaco
    Josh
    Mobile Al
    The ones for drills are good for removing individual scratches, but if you plan to do the whole truck you would be working for a long time.
    The drill also acts like a rotary polisher which presents a high risk of clear coat burn through if not careful.
    I would recommend Meguiars ultimate compound. You should be able to find it in your local parts store. Its a little more aggressive than the scratch x when working by hand.
  5. Sep 26, 2011 at 10:47 AM
    CQB 1911
    Jesse
    AZ.
    2010 TRD OR AC
    Sounds good - thanks for the advice!
  6. Sep 26, 2011 at 10:49 AM
    I Liquid I
    I Liquid I Well-Known Member
    Puerto Rico
    06 BSP DCLB, 17 Inferno TRD Offroad DCSB, 06 SW ACLB
    Too many mods to list
    I have noticed that for individual scratches that are somewhat deep but still bluffable, working by hand seems to be better than with a buffer.
    I have a porter cable that I love, however for some scratches, I buff better by hand.
    Also, scratch x is good for here and there scratches. I use Ultimate compound for the whole truck or big parts when needed.
  7. Sep 30, 2011 at 10:21 PM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    I haven't had any luck with scratch x on any of my cars
  8. Oct 1, 2011 at 8:31 AM
    CQB 1911
    Jesse
    AZ.
    2010 TRD OR AC
    The scratch X worked alright on minor scratches. I guess I have some pretty deep ones that aren't going to buff out. It seems like every day I have scratch pop up that wasn't there before.
    I have a Magnetic Grey 2010. It seems like the paint just isn't that durable. Is it possible that I got a shitty paint job from the factory, or is it just me.
  9. Oct 1, 2011 at 8:40 AM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    Seems the Mag Grey scratches easily from others that have commented on that color. I have a white one and it does a better job of either hiding or being able to handle minor scrapes.
  10. Oct 1, 2011 at 9:50 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I've buffed out some pretty deep scratches with ScratchX and a cotton wheel on a dremel. That leaves it's own marks in the paint, so I had to polish with the polish glaze compound and a buffer.
    I tried by hand, but just can't remove enough paint that way.
  11. Oct 1, 2011 at 12:57 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    I tried it a few weeks ago and it looked great at first but after a good all day rain, the scratches were back. Don't waste your money. I think the only long term fix for scratches is another paint job.
  12. Oct 1, 2011 at 1:59 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Money? Money?! What's wasted on scratch removal is TIME. Hours and hours of it. If you're going in thinking "wipe, buff, and gone" you've got the wrong expectation.
  13. Oct 1, 2011 at 2:11 PM
    fixnfly
    S.W.PA
    It only took about 15 minutes of work but the disappointment is what really pissed me off:mad:
  14. Oct 1, 2011 at 6:08 PM
    pinktaco808
    pinktaco808 Hot Steppa
    Meguiars ultimate compound is ok still gotta work it in by hand more.
  15. Jan 22, 2012 at 7:22 PM
    Devux
    Devux Well-Known Member
    Devin
    Las Vegas, NV
    2014 TRD Sport 4x4
    Leveling kit & wheels
    Tried Meguiar's ultimate compound today to get out a scratch and gouge I had. The scratch is almost completely invisible and the gouge is a lot better than it was, you wouldn't see it unless I pointed it out. I worked the product by hand using a 100% terry cotton towel, be prepared to spend a good thirty minutes or so on a moderate scratch, results should be well worth it though.
    The finish after you're done is like glass, just as good as a clay bar in my opinion.
  16. Jan 22, 2012 at 8:51 PM
    jprovence
    jprovence Well-Known Member
    Joshua
    Albany
    11' Tacoma TRD
    Stock
    Be prepared to wear out your arm with ScratchX. Though I have used it with a rotary buffer with excellent results with a polishing W9000 polishing pad.
  17. Jan 23, 2012 at 7:12 AM
    jprovence
    Joshua
    Albany
    11' Tacoma TRD
    Stock
    A clay bar should be used before the ultimate compound.
  18. Jan 25, 2012 at 1:08 AM
    808hiker
    808hiker Taco addict
    Justin
    Big Island, Hawaii
    Didn't have much luck either with the Scratch X 2.0 but Meguiar's Professional Line Swirl Remover did work. In my experience, if it's deeper than just a swirl mark, it probably isn't gonna come out.
