Scratched clear coat & black plastic trim stain from wax
Discussion in 'Detailing' started by progrhythmical, Jan 17, 2011.
  1. Jan 17, 2011 at 5:13 PM
    progrhythmical
    progrhythmical [OP] Member
    Central Valley, CA
    11' Tacoma PreRunner Access SR5 V6
    Hello all. I was searching the threads for this first but cant seem to find an answer that I am happy with, haha. I used the meguiars gold class paste wax w/polymers in it and it works GREAT! Except......I got some on my black plastic trim. I have tried scrubbing the SH*T out of it with a green scrubby. I have scrubbed so hard that the green has actually came off the scrubby, lol. It looks like the wax is gone when it is wet, but when it dries it still comes back. WTF!? I mean, it did say in CAPS on the can not to get on plastic or vinyl. But they didn't state HOW imperative it was not to....bastards. I'm sure that is for marketing reasons, as if they stated what REALLY happens when you get it on there, less people would probably buy it, haha.
    First off, do all wax products have this kind of tenacity with plastics, or is just because this has polymers? Will a carnuba ONLY wax still have this effect? If they all do, I guess it looks like I'm gonna have to mask it all off when I wax!? And second off, how (if at all possible) do I remove this crap of the trim? Is there any kind of black stain for plastics on the market to cover it up?
    Also, in the course of scrubbing my tailgate latch trim I accidentally scrubbed the clear coat in a very small area with the green scrub. It isn't deep. More so just looks dull. When I run my finger across the paint it feels smooth until i hit the blemished area. Then it just feels a little rough, just not gliding across. My finger doesn't have a hard time moving across it though, and it doesn't catch. I have some nu finish liquid polish. Will this work on the little area? Also will it stand out from the rest of the good paint that hasn't been treated? I dont want to have to do the whole damn truck so it matches. I was thinkin maybe go get some MeGuiars scratch-x? But i don't know if that is too abrasive for this job. Well, what do you all think i should do here? I know these are A LOT of questions, but Im sure somebody here can answer these in a couple of sentences, haha. Any help will be greatly appreciated. If you cant tell, Im completely OCD about certain sh*t in my life......Maybe I shouldn't have gotten a black truck......Then again, because of the OCD I might just end up having the best lookin' black truck out there, haha. Thanks in advance :D
  2. Jan 17, 2011 at 5:16 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    your truck will be fine.......my first scratch from a branch went all the way down the side of my whole truck......soon as i seen it i said to myself "ahh my truck will be alright." :)
  3. Jan 17, 2011 at 5:18 PM
    crf69
    Ohio
    ummm yeah
    oh i used maguirs cleaner wax....dont know if it's still made but it helps
  4. Jan 17, 2011 at 5:35 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    You don't have to tape off the plastic...just be more aware when your waxing. My Dad did the same thing on his Subaru...white area's all over the black plastic. I've heard and seen utube video's of useing smooth peanut butter...something about the oil in it. I might try it with a tooth brush once the weather warms up. I'm interested in what other's have to say on what will remove the wax.
  5. Jan 17, 2011 at 6:05 PM
    progrhythmical
    Central Valley, CA
    bumpity bump....
  6. Jan 17, 2011 at 6:15 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    Goo B Gone Extreme, it'll strip all the wax off. (used it to remove road paint from mine see here: http://www.tacomaworld.com/forum/detailing/111358-tips-removing-road-paint.html )
    But try the peanut butter thing, I'd like to see if that would work.
    Also have heard that Non-Pumice, garage hand cleaner works at removing stuff if you let it sit there.
    Gas, paint thinner, nail polish remover... there are all sorts of things to try.
    AND
    for the part where you burned though the clear you might try getting a spray can of clear coat touch up paint and then clay bar it to blend it in.
    That could be tough to do though.
    Or just put a few coats of wax on it and just call it good.
  7. Jan 17, 2011 at 6:23 PM
    progrhythmical
    Central Valley, CA
    Thanks for the input guys :) I will try the peanut butter first and get back to you. I still don't know what god damn polish to use though. I don't want to use something too abrasive. I know I'm supposed to follow the fine to course method when it comes to grain size, but i cant find the grit rating on any of these damn bottles. The only one that I can see that states the grain size is 3M, and I cant find the 3000 polish anywhere but the internet. Can anyone help on this part of my dilemma?
  8. Jan 17, 2011 at 6:28 PM
    tinker_troy
    T R O Y
    WY/SD
    3M Finesse It, great polish used by a lot of body shops. You should be able to find it at a paint and body supply store or they will know where to get it.
  9. Jan 17, 2011 at 6:31 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    A gum rubber eraser will take the wax off of trim,with alot less mess than peanut butter.I'd be a little afraid of gas,paint thinner or nail polish remover.
  10. Jan 17, 2011 at 6:38 PM
    progrhythmical
    Central Valley, CA
    Thanks a bunch :)
  11. Jan 18, 2011 at 6:05 AM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    I strongly recommend wax that doesn't stain for next time around...my personal favorites are:
    1. Duragloss Aquawax
    2. Meguiar's Ultimate Quik Wax
    3. CSI Q-7 Wax (which we sell).
    I wax all areas of my truck...paint, trim, chrome, plastic, even side and rear windows. No staining.
  12. Jan 18, 2011 at 6:09 AM
    rwilso03
    rwilso03 Well-Known Member
    Russ
    Dayton
    2010 DC SB 4.0L 6spd Barcalona Red
    TRD Exhaust, Engine Ticking Fix, Fog Lights Anytime, Locking Center Storage, 4LO Trac Mod, Rear Spring TSB
  13. Jan 18, 2011 at 6:10 AM
    TexAggie
    TexAggie Well-Known Member
    Eric
    Houston, TX
    OME Lift
    I get wax on the black trim all the time. Goo Gone takes it right off no problem. I use mothers wax, so I don't know if its different but I'm guessing it will work.
  14. Jan 18, 2011 at 8:34 AM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    Autoglym makes a good product for bringing back the "black" to plastic that has had wax on it. the name escapes me at the moment... "Bumper Care" I think... Either way, check their site, and order some. It's great stuff.
    As far as polishing your gate, it sounds like it's not too badly scratched. If you used a green pad, it should be fine. Try Meguiars Scratch-X. I don't use the stuff often, but I have used it, and it does the trick, and it's readily available at parts stores. It's a VERY fine polish, so good for a beginner. Just mask off the plastic gate handle before you start polishing. Oh, and polish by hand, since it's such a small area. Just use a clean micro-fibre cloth.
    And since we're on the topic of polishes... If you're shopping around at most parts stores, you're not going to find abrasive polishes. They just don't stock them. These abrasive polishes are typically sold at autobody supply stores, as they're the primary users of them. If you're unsure of your polish, just put some on your finger. If it's "gritty" you know you've got a real abraisive. If it's smooth, like a liquid wax, you'll know it's a finer compound.
  15. Jan 18, 2011 at 9:53 AM
    novataco
    novataco Well-Known Member
    NOLA
    06 Sport V6 auto
    Aries bull bar, Lund grill screen, blackened h/l, Weathertech plastic all over, Access LE tonneau, window tint, tube steps, DF-Toy aux adapter, cig plug always on, console vault, hitch step, 1700 watt in-cab inverter and dual battery (in-progress), Delta bike hitch mounts
    For the plastic trim, use Simple Green with a toothbrush first. Then use Back To Black....with a toothbrush as well. The Back to Black does wonders, but the Simple Green does well as a first step and it will help. Back to Black is not a paint, it is a cleaner and it is milky white and they claim it doesn't strip wax. You may not get all of it out of the textured trim like the bed rails, but you will get it almost completely gone that you won't really notice it anymore. In the future, tape it off, or stay away from the trim. The taping doesn't take a long time at all. For the clear coat damage, it sounds in the same class as a scuff. Use a three step polishing system like Sonus SFX-1, SFX-2 and SFX-3
    http://www.autopia-carcare.com/son-410.html
    Use with an electric machine, preferably a random orbit polisher, not a rotary polisher. Most people use the Porter Cable:
    http://www.autopia-carcare.com/ulti...24-dual-action-random-orbit-car-polisher.html
    You can buy a kit with the polisher, the correct polishing pads, and the polishes, and save some money. It should restore it to new or near new. You might want to consider having a detailer do that for you, just have him do that one spot: you don't have to pay for a full polishing, just that spot, and make sure he's good with a polisher.
    You can shop around, but Autopia's detailing forum, and articles, are a great resource.
  16. Mar 22, 2012 at 2:51 PM
    jtgroce
    jtgroce Got R Did
    In the Foothills, NC
    '12 Taco MGM TRD Off Road
    K&N Air Filter Husky Floor Liners Weathertech Vent Visors LED Map/Dome Light Mod Chrome Door Handles AVS Bugshield Bed Mat Fog Light Anytime Mod DTRL LED's Flowmaster Super 40
    I used Mother's Carnuba Cleaner Wax today on my truck and I got that crap on my plastic trim. I always try to wipe it off as soon as i wax around it but it still comes back! The wax worked well otherwise......guess I'll be buying some goo gone and giving it a try
  17. Mar 25, 2012 at 9:13 AM
    jprovence
    jprovence Well-Known Member
    Joshua
    Albany
    11' Tacoma TRD
    Stock
    meguiers quick detailed works sometimes scrubbing with a terry cloth if it's not too embedded. steam cleaner works awesome for deep embedded wax in textured plastic. it cleans pretty much every other part of the car too.
  18. Mar 25, 2012 at 10:07 AM
    jtgroce
    jtgroce Got R Did
    i have some meguiars quick detailer, maybe i'll try that. Haven't had a chance yet since it's been raining the past 2 days
