+SconnieHailer's Build & BS+
Discussion in '2nd Gen. Builds (2005-2015)' started by SconnieHailer, Mar 24, 2013.
  1. Jan 26, 2016 at 1:12 PM
    #2841
    SconnieHailer
    SconnieHailer [OP] PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Front is a 3/4 by ____ can't remember and the rear is m14 by____ can't remember either haha. I'll measure tonight.
  2. Jan 26, 2016 at 2:10 PM
    #2842
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Cool, thanks. What do you think about building in a bit of caster to the lower solid mount tabs? Offsetting them so the tire is pulled a bit more forward when you have to essentially pull it back from the top of the spindle with the UCA adjustment to get the caster.
  3. Jan 26, 2016 at 2:30 PM
    #2843
    SconnieHailer
    Marc
    not a bad idea, you might find it hard getting the bolts lined up at an angle, others have mentioned having a tough time. Easy enough to cut a few different sets of tabs if you are having it done by someone, i've thought about it too. that way you've still got the option to run it straight if its a bear to get the offsets to work. I've currently got my rear cam bolt in the lower arm and about maxed out for + caster so i can clear the 295 for now. If you have some offset tabs for the rear made let me know.
    Once you solid mount the lower, if you want to add caster you will end up moving the tire closer to the firewall since you're using the upper like you said. I like running less caster to keep the clearance i need at the rear now that i use the upper, and by less i mean 3* compared to lots of guys running 4 and 5. The wheel feel is lighter that way and daily driving is much more enjoyable. The flexibility that the rear cam bolt in the lower and the upper arms being adjustable is pretty cool though, was nice this last alignment i did becuase i didnt pull the upper off, i just used the lower rear cam.
  4. Jan 26, 2016 at 2:39 PM
    #2844
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Interesting, never thought about a mix of solid and a cam. Getting some info from @jeffz0rz about the tabs, LSK said they weren't doing them anymore. I may just get a bunch of blanks and drill them myself, and have a few options.
  5. Jan 26, 2016 at 3:33 PM
    #2845
    SconnieHailer
    Marc
    I'll get a caliper on the tabs so you've got dimensions. Could even cut your own :cool: its just 3/16 flat bar.
  6. Jan 26, 2016 at 5:04 PM
    #2846
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Don't worry about the dims, I have mine all ripped apart and calipers handy, I was just more wondering if you had a part list for the bolts. They were .551" and .749"
    I may just make my own, I wanted them to be nicely cut, but I have plenty of steel and cut off discs.
  7. Jan 26, 2016 at 5:07 PM
    #2847
    SconnieHailer
    Marc
    .753 .560 were the inner sleeve dims I got. Close enough! Haha
    Do you want bolt lengths I used still?
  8. Jan 26, 2016 at 5:46 PM
    #2848
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Sure!
  9. Jan 26, 2016 at 8:00 PM
    #2849
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Good work man!
  10. Jan 26, 2016 at 8:06 PM
    #2850
    SconnieHailer
    Marc
    Front bolt on the LCA for solid mount is 3/4" by 4.5". Rear bolt on the LCA for solid mount is a 10.9 grade M14 by 130mm.
    Those length numbers are tight though, the nyloc is just barely hanging on. You could go with 5" on the 3/4 front and 140mm on the m14 rear and be safe if you dont mind some overhang.
    They dont really make that M14x130/140mm bolt for stores so it's a bolt to order @Wishbone Runner Trust me i checked all fastenal stores and other options here for a 10.9 grade.
  11. Jan 26, 2016 at 8:12 PM
    #2851
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Awesome, thanks Marc.
  12. Jan 26, 2016 at 8:17 PM
    #2852
    SconnieHailer
    Marc
    Thanks Pat! I envy your spacious tundy and big motor... Buut i'm glad i've got the lil truck for the trails here. I do have a question though... So you have a bitchn mid travel full size, whats your take on wheeling now? Do you miss it, you clearly cant take the big truck on lots of trails the taco was cool with banging down. Do you look to a side by side for fun now or are you happy with just doing what the tundra is capable of? It's all personal preference i know but just asking :cool:
  13. Jan 26, 2016 at 8:20 PM
    #2853
    SconnieHailer
    Marc
    Right on, no problem man. let me know if you need anything else. Be happy to help :) Wish you were closer, i've got the alignment process down!
  14. Jan 26, 2016 at 8:25 PM
    #2854
    SconnieHailer
    Marc
    Just realized how bad i've been at keeping track of pages of important stuff to the main page. Sorry if its made it tough surfing through the build guys. I'll try and update the OP with the pertinent posts... with that being said, if you guys have any pages of importance bookmarked post em please so i can update the OP :D
  15. Jan 26, 2016 at 8:26 PM
    #2855
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Haha, me too. I think I am going to end up making 50 trips to Firestone to get it all dialed.
  16. Jan 26, 2016 at 8:37 PM
    #2856
    SconnieHailer
    Marc
    Worth it! It's funny how i just forgot about the alignment after i went solid lower. I set it and just forgot about it until i had to adjust for 295's.
  17. Jan 27, 2016 at 8:34 AM
    #2857
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    God. I wish I could do that..
  18. Jan 27, 2016 at 10:50 AM
    #2858
    PLC721
    Patrick
    Chandler, Az
    Hmm don't miss it like I thought I would. And I've lost the desire to daily drive a modified vehicle. The tundra will stay the way that it is. I'm very happy with driving it the way it is. I'm focusing more on career choices for now. Lol plus the lady wants a Rubicon so that might become the weekend trail rig
  19. Jan 31, 2016 at 3:07 PM
    #2859
    copenhagen
    copenhagen Well-Known Member
    South Carolina
    2011 TRD OFFROAD 4x4 SIX SPEED MANUAL AC
  20. Feb 5, 2016 at 9:53 AM
    #2860
    copenhagen
    South Carolina
    Sconnie Hailer, how do you like your FN wheels? You have the Counter Steers with 0mm offset and 4.5" backspace still? Are you still running 285 75 16's? Did you notice a decrease in power from going that large? What about trimming being as we already have aftermarket front bumpers?
