Scepter MFC Jerry Can owners , I have a question for you
Discussion in 'Off-Roading & Trails' started by OZ-T, Apr 20, 2013.
  1. Apr 20, 2013 at 4:39 PM
    OZ-T
    OZ-T [OP] You chose ... poorly
    Peter North
    British Columbia
    When I pour gas from my Scepter MFC jerry cans , I can't seem to keep fuel from dribbling out of the breather hole while I'm pouring
    I'm using the Scepter 3/4" nozzle
    Any tips ?
    Manfred likes this.
  2. Apr 20, 2013 at 5:23 PM
    OZ-T
    Peter North
    British Columbia
  3. Apr 20, 2013 at 5:32 PM
    Kailey Jo
    Kailey Jo Well-Known Member
    Liam
    Ontario
    09 Access Cab TRD
  4. Apr 20, 2013 at 5:33 PM
    OZ-T
    Peter North
    British Columbia
  5. Apr 20, 2013 at 7:28 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    Is your nozzle metal or plastic?
    Herein the term "nozzle" shall be replaced with "horsecock"
  6. Apr 20, 2013 at 7:32 PM
    OZ-T
    Peter North
    British Columbia
  7. Apr 20, 2013 at 7:41 PM
    ouyin2000
    Nova Scotia
    '11 DCSB TRD Sport
    Then that is exactly your problem. The plastic ones are garbage, especially in cold weather. They are brittle and easily cross threaded.
    If you look at the cans, they should have a small breather hole on the lip of the threaded opening. If that hole and the breather hole on the horsecock cap don't line up perfectly (and they almost never do) you'll encounter problems. Ideally you should look into finding a metal one.
    I've used this exact one many times with these cans, and prefer it over the plastic ones any day.
    But if you can't find one of those, maybe try getting a larger spout. You likely are getting a bit of a blockage with the 3/4" spout. Try the 1 1/8" spout offered by Scepter. These are the ones we use the most with the cans.
    http://www.sceptermilitary.com/fuel_containers/accessories_parts/04353/
    The nozzle is a bit large for gasoline, but pour carefully?
    Manfred likes this.
  8. Apr 20, 2013 at 7:44 PM
    OZ-T
    Peter North
    British Columbia
    Thanks for the info
    So , the breather hole needs to align with the holes in the cap portion of the spout ?
  9. Apr 20, 2013 at 7:48 PM
    ouyin2000
    Nova Scotia
    '11 DCSB TRD Sport
    Ideally yes, but if you're getting back flow from a restrictive opening it won't matter. I hate using them to fill gas vehicles. Such a pain in the ass with a small opening. The larger horsecock is much easier to use, but would only fit a tank on a diesel vehicle.
  10. Apr 20, 2013 at 7:53 PM
    OZ-T
    Peter North
    British Columbia
    Yeah , that's why I got the smaller diameter one for my truck
    I emailed Scepter and they suggested that some fuel is getting caught in the breather chamber inside the can , and to put on the spout and tilt the can backwards to drain the breather chamber , and to pour slowly , I tried that today with the same result
  11. Apr 20, 2013 at 8:01 PM
    ouyin2000
    Nova Scotia
    '11 DCSB TRD Sport
    Hm. The only other thing I could recommend is try a different technique. Like laying the can on it's side when you pour. I know how difficult they can be to maneuver when they're full.
  12. Apr 20, 2013 at 8:03 PM
    OZ-T
    Peter North
    British Columbia
    Yeah , I think part of the problem is the can was totally full .
    Thanks for your help
  13. Apr 20, 2013 at 8:08 PM
    kigi
    kigi Member
  14. Apr 20, 2013 at 9:14 PM
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    You sure its coming out of the breather? I added a rubber washer to my home brew to stop some dribbles that only one of my tanks had. o-ring came off an old oil filter from the truck. I gave up on that garbage clamp spout long ago
  15. Apr 20, 2013 at 9:16 PM
    OZ-T
    Peter North
    British Columbia
    Certain it comes out of the breather hole
  16. Apr 20, 2013 at 9:17 PM
    OZ-T
    Peter North
    British Columbia
  17. Apr 20, 2013 at 9:21 PM
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Look inside, see if the little white thing is still there.
  18. Apr 20, 2013 at 9:23 PM
    OZ-T
    Peter North
    British Columbia
    The breather tube in line with the handle ?
    It's there
  19. Apr 20, 2013 at 9:27 PM
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    It cracked? Look w/ a mirror
  20. Apr 20, 2013 at 9:35 PM
    OZ-T
    Peter North
    British Columbia
    This is a brand new can , but I will have a closer look tomorrow
