Scene lights (Trailhunter)
Discussion in '4th Gen. Tacomas (2024+)' started by Wahhabm, Nov 29, 2024.
  1. Nov 29, 2024 at 8:52 PM
    Wahhabm
    Wahhabm [OP] Well-Known Member
    Monther
    We need the aftermarket community to make these scene lights for our trucks. 4 lights around the bed. Let's go. Screenshot_20241129_223111_YouTube.jpg
    TurboDA6 and PDKTaco like this.
  2. Nov 29, 2024 at 8:54 PM
    JB_TN
    JB_TN Well-Known Member
    JB
    Tennessee
    2024 Bronze Oxide TRD OR
    Well as long as they are better than the OEM. Not impressed with them on mine.
  3. Nov 29, 2024 at 8:54 PM
    Mach
    Mach Well-Known Member
    2022 Lunar Rock DCLB TRD Off-Road
    Thats a great idea. Maybe even with a smoked lens so they really blend in until turned on. I don't need more projects on my workbench right now though.....
  4. Nov 29, 2024 at 9:41 PM
    Wahhabm
    Monther
    I sent Meso Customs a suggestion to do them. I think they would find there is demand for these
  5. Nov 30, 2024 at 6:48 AM
    BearWithMe
    BearWithMe Well-Known Member
    Four Corners
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    What would you change to make them better?
  6. Nov 30, 2024 at 7:14 AM
    Wahhabm
    Monther
    Probably brighter is my guess since I have not seen them lit at night
  7. Nov 30, 2024 at 4:15 PM
    JB_TN
    JB
    Tennessee
    Brighter and better light cut off. I don’t have a good picture in a dark area to really show what I mean.
  8. Nov 30, 2024 at 4:41 PM
    JB_TN
    JB
    Tennessee
    This picture does a good job of my issues. Lights are not a continuous pattern around the sides and does not go up to the truck…like to the tire.
    CanadaToy likes this.
  9. Nov 30, 2024 at 5:29 PM
    turbosix
    turbosix Well-Known Member
    dfw
    2024 TRD Pro
    lmao bro it's literally physics. the lights are in the bed rail cap. do you expect them to magically shine through the metal of the bed to light up the tire?
    Taco2GR86, TACODOC1 and rubenc87 like this.
  10. Nov 30, 2024 at 5:42 PM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    Here are couple of photos at a campsite. I have turned on all my LED lights (3) under my topper:
    Wider angle to show coverage:
    I am guessing rock lights might help fill in the void.
    Ironium, chakla and JB_TN like this.
  11. Nov 30, 2024 at 5:56 PM
    JB_TN
    JB
    Tennessee
    No I don't. What would be nice if there were some lights in the wheel well that were part of the scene light package to take care of the void.
    WiFiDoctor likes this.
  12. Nov 30, 2024 at 6:05 PM
    caribe makaira
    Caribbean, Puerto Rico
  13. Nov 30, 2024 at 7:08 PM
    turbosix
    dfw
    2024 TRD Pro
    underglow has been a thing since like the late 80s... if you want to look tacky there's been options for as long as i've been alive.
    Taco2GR86 and CanadaToy like this.
  14. Nov 30, 2024 at 7:43 PM
    WiFiDoctor
    WiFiDoctor Well-Known Member
    2021 TRD Pro
    How about these guys- They are led strobes, but has steady mode. They will be MUCH brighter as they are a class I listed warning light- but you don’t need to use them for that. I have slightly larger ones on my truck that I use for side/scene lighting when working in some very dark areas. Going to add rock lights to fill the lower areas…
    Wahhabm[OP] likes this.
  15. Nov 30, 2024 at 7:43 PM
    WiFiDoctor
    2021 TRD Pro
  16. Nov 30, 2024 at 7:49 PM
    WiFiDoctor
    2021 TRD Pro
  17. Nov 30, 2024 at 8:31 PM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    Not a 4th gen I'll admit - but I "electrified" the crossbed tool box on my outfit to have lighting and run a compressor. To provide side lighting of the ground I fitted the box with these LED RV porch lights. They have cast aluminum housings and an inherent downward aim.
    To work on the forward end of the truck, my best idea has been to put side lamps under the rear view mirrors.
    batacoma and Ironium like this.
  18. Dec 1, 2024 at 3:07 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    White underglow would probably be the most affective soloution for putting light on the ground. Along the pinch weld or running boards below the cab, plenty of lights designed just for that, but I was thinking LED strip lighting. The entire bed rail could be illuminated instead of two lamps at either end. Lights could also be installed in the flares the same as GMC does with those marker lights.
  19. Mar 28, 2025 at 11:09 AM
    BearWithMe
    Four Corners
    Prior: '18 OR 6MT
    Has anyone added the OEM bed scene lights to their Taco? What is the part number for the set of four? Do you just trim your existing bed rail caps along the pre-marked lines?
  20. Mar 28, 2025 at 12:05 PM
    Jacob06
    Jacob06 Well-Known Member
    Atlanta
    2024 TRDOR 6MT
    Here are the 2 part numbers for the bed scene lights that I've been able to find:
    PT944-35240 & PT944-35241
    I believe one number is for the long bed and the other for the short bed.
    Please do post where if you can find these because I haven't been able to.
    I ask the parts counter people at my local Toyota dealership for stuff every time my truck gets serviced but they are so stupid there that they can barely get you an oil filter.
    And when they do, they have to stare at their computer for 15 minutes before they can figure out which one to go get.
    I believe you get the whole rail cap with the lights if you can find them
