Scanner code reader advise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ibdoubled, Feb 13, 2014.
  1. Feb 13, 2014 at 4:16 PM
    Ibdoubled
    Ibdoubled [OP] Active Member
    Dave
    Deming, nm
    1999 Tacoma
    I have a 2013 tacoma with the 4.0 engine, the wife has a 2007 4 runner with the 4.0 engine. I'm thinking of buying a scanner that I can use on both to read any codes. Actually the 4runner has an engine check light, so I guess it's about time. Anyway any advise on something to read codes that I can use on both?
    Thanks
  2. Feb 13, 2014 at 4:20 PM
    toyo8696
    toyo8696 Well-Known Member
    Cumming,GA
    4X4 Sport DCSB, 2008 4R V8 AWD
    What is your budget? I like the Actron brand.
  3. Feb 13, 2014 at 4:50 PM
    Ibdoubled
    Dave
    Deming, nm
    1999 Tacoma
    I don't have an unlimited supply of money but want something that works. I have worked on vehicles most of my life and am an aircraft mechanic/helicopter for a living. I always work on my own stuff when possible
  4. Feb 13, 2014 at 7:21 PM
    jrt
    jrt Member
    St. Louis
    '14 DCLB, red
    Get an OBD II bluetooth or WiFi adapter from Amazon or ebay. Then install any one of various free or paid software options on a smartphone or iPad. You can read and clear diagnostic codes with many of them. You'll be spending 20-50 bucks if you go this route and there are plenty of more-knowledgable folks on this board who have given instructions on how to set them up. Search for 'engine link' or 'torque pro' (only two examples of the software)
  5. Feb 13, 2014 at 8:39 PM
    DaVikes
    DaVikes Well-Known Member
    Ross
    Denver
    Colorado Sports Car
    Arb front bumper, warn winch, All Pro rear bumper, OME up front, OME and All Pro Standard in Back, ARB locker, 34 x 10.5 KO2's, 17" Level 8 Trackers, and fancy single piece driveshaft.
    They have gotten ridiculously cheap. I saw a bluetooth sender (the part that plugs into your truck's odb2 port) for $15 the other day. It stays in the port all the time, and sends the data to your iphone or android phone. There are a bunch of different apps out there that will read codes, etc.
  6. Feb 13, 2014 at 11:22 PM
    LuckyCharms
    LuckyCharms Knows a little about a lot
    Socal
    '13 PreRunner TRD dclb
    I got techstream and bought a cable from Amazon. Pretty sure the cable came with an older, ripped version of techstream. I think it cost me about 40 bucks total and you can change a minimal amount of settings, do OBDII emissions test and read all codes for all late model toyotas. You have to be a little tech savvy to get it to work though. Comes with full instructions.
    Ebay 16 bucks.
    http://www.ebay.com/itm/2014-Latest...561?pt=LH_DefaultDomain_0&hash=item23360bbe01
    Amazon 28 bucks:
    http://www.amazon.com/Newest-V8-00-...=1392362456&sr=8-1&keywords=toyota+techstream
    Edit: I'm not sure that the amazon one comes with a copy of techstream but you can get it via torrent if you are able. I hate Ebay so I would suggest Amazon if you are capable.
  7. Feb 14, 2014 at 3:55 AM
    MSCOFF
    MSCOFF Well-Known Member
    Mark
    CT
    2017 SR5 AC 4WD
    check out the "Torque App" on the google play store.
  8. Feb 14, 2014 at 4:50 AM
    toyo8696
    Cumming,GA
    What device are you using to connect this to? Your links all say it goes to the Techstream. The TIS is Toyota and Lexus's house scanner.
  9. Feb 14, 2014 at 5:01 AM
    Lastplace
    Lastplace Well-Known Member
    Southeast VA
    Just go by Advance Auto, borrow their scanner for free
    If you go OBDII wireless
    wifi sender for Apple
    bluetooth for Android
  10. Feb 14, 2014 at 5:43 AM
    chasdw
    chasdw Member
    Norman OK
    4WD
  11. Feb 14, 2014 at 6:27 AM
    Ibdoubled
    Dave
    Deming, nm
    1999 Tacoma
    Can youbreset the check engine light with those? I noticed some people use like a scangauge or other ones that I guess you mount in the vehicle? I'd like to get something that I can use on both vehicles, I assume any of these can just be put in the vehicle with the fault and read the code?
    Thanks
  12. Feb 14, 2014 at 9:34 AM
    jrt
    jrt Member
    St. Louis
    '14 DCLB, red
    You can reset CEL with many of the software solutions- I can't say for all of them. Torque Pro (android) and Engine Link (iPhone) both can reset alarms. As mentioned above- if you get one of these- apple products (iPad/iphone) can only communicate through WiFi. Bluetooth works on android devices.
  13. Feb 14, 2014 at 11:36 PM
    LuckyCharms
    Socal
    I guess I should have elaborated. The cable is just a OBTII to USB and you plug it in to your laptop. You can read trouble codes on your laptop.
    Edit: Yes, you can clear codes with this software.
  14. Feb 14, 2014 at 11:39 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
  15. Feb 15, 2014 at 7:03 AM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    Just wanted to point out that if you go with the Techstream clone and cable for a laptop you need a laptop running Windows XP. You could also use Windows 7 but you need a dual boot setup for XP. It will not work with Windows 8 at all. Hope this helps.
  16. Feb 15, 2014 at 7:19 AM
    metalpeddler88
    metalpeddler88 Well-Known Member
    Barrow County, GA
    07 Black X-Runner
    Just another voice to chip in their opinion:
    I have an Innova 3100e, and I love it. I haven't gotten to use it much in the Tacoma, since I haven't had a check engine light yet, but I did plug it up just to see if it works. Got vehicle information from it, neat feature. :D I got mine new on Ebay for well under retail price. I think they've since upgraded the model to now handle ABS.
    (http://www.amazon.com/INNOVA-3100-Diagnostic-Battery-Vehicles/dp/B000EVWDAK) This one is $100 right now, from $200, but IMO, well worth it. Saves you trips to an auto store if you like to try and stay independent. :cool:
  17. Feb 15, 2014 at 11:46 AM
    Ibdoubled
    Dave
    Deming, nm
    1999 Tacoma
    Thanks for all the help, Ive been looking at all the ones that were suggested and working on a decision. I borrowed a actron cp9125 from a guy at work and going to see how it works, I've never actually used any of them before. The ones that stay in the vehicles look pretty nice, I just don't want anything too complicated
    Thanks
  18. Feb 16, 2014 at 5:36 AM
    Hugh Morron
    Bill
    I forgot to mention that the Techstream clone is cheap if you already have an XP laptop and you can shut off the annoying seat belt dinger(Will beap 5 times when you first start truck) if you want it shut off. Most code scanners cannot do this.
  19. Feb 16, 2014 at 7:10 AM
    "OldManTan"
    "OldManTan" Bye bloody Taco... Hello MGM Burrito!
    Buffalo, NY
    '16 Tundra DC
    Holy chit, I've done a lot already!!
    There is a procedure to shut that off without external help. On, Off, click heels 3 times, scratch head... something like that.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/38842-disable-seatbelt-warning-chime.html
  20. Feb 16, 2014 at 5:55 PM
    Hugh Morron
    Bill
    OP said he has a 13. I forget what year is the cutoff for that trick but I know it wouldn't work on my 12. On the newer Tacomas the only way to shut it off is with Techstream or clone or plug the seatbelt in.
