Scangauge TFT Code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by claytonketchum, Mar 14, 2019.
  1. Mar 14, 2019 at 5:41 PM
    claytonketchum
    claytonketchum [OP] Member
    Clayton
    Cleveland OH
    2008 Toyota Tacoma Double Cab 4.0L TRD
    I recently bought a scangauge II and input the TFT code from the website. However, i was wondering if there are 2 sensors, one in the pan and one in the torque converter. And if so, does anyone have the xgauge codes for both?
  2. Mar 14, 2019 at 5:46 PM
    Clearwater Bill
    Billy
    Largo Florida
    They are both on their site for my '13.
    If they don't show a second for your '08, it probably doesn't have one.
    IMHO #2 isn't really uber critical anyway. Just keeping an eye on one is 100% better than not seeing anything.
  3. Mar 14, 2019 at 6:20 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
  4. Mar 15, 2019 at 11:29 PM
    2WD
    2WD Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    https://www.scangauge.com/support/x-gauge-commands/toyota-lexus-scion/
    They list 4 different ones for pre 2010. I'd try all of them, and hopefully 2 work.
  5. Mar 16, 2019 at 7:25 PM
    claytonketchum
    Clayton
    Cleveland OH
    Thanks for this link! It definitely helped.
    It seems like there are two temperature sensors in the 2nd gen Tacoma Transmission.
    The code I use as TCT fluctuates a lot, so I’m going with that one as the torque converter. The second one I labeled TFT for the pan temperature. I’m very happy with them now.
    The only thing I’m wondering about now is how accurate they are. I recently did a flush and fill on the tranny, and I put the vehicle in “Transmission Temp Check Mode” to check the fluid level. Then after I finished checking the fluid level, I quickly sealed up the plugs, turned off the vehicle while it was still within the correct check temperatures according to the “A/T Temp” light. I plugged in my scangauge and restarted the truck, it was only reading 93 degrees Fahrenheit! I wonder how accurate the people who used their scangauge to check fluid level are?
    This is what I’m using now:
    “Torque Converter Temp - TCT”
    07e021d9 txd
    032180000000 rxf
    2810 rxd
    00070065fe70 mth
    “Transmission Fluid Temp -TFT” in the pan I assume
    07e021d9 txd
    032100000000 rxf
    1808 rxd
    00090005ffd8 mth
  6. Mar 16, 2019 at 7:57 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    In the temp check mode the light goes on solid when the oil is between 90-115°F iirc
    SR-71A likes this.
