SATOSHI MOD --- 1st gen. write-up (lots of pics)
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomarotto, May 31, 2012.
  1. May 31, 2012 at 12:00 AM
    tacomarotto
    tacomarotto [OP] "Change is inevitable, but growth is optional."
    Jon
    Jacksonville
    Audi S3
    Alright so here is my Satoshi Mod!
    first off id like to give a special thanks to HOMERTACO for supplying the M1 mesh grill and making it look that much more badass.
    also all the other write-ups that inspired me with this mod
    I wanted to make a good write-up for all the 01-04 tacos since i could NOT find a solid write-up for it
    so here it goes...
    Satoshi Mod Links:
    HomerTaco Satoshi and Mesh Grills: http://www.tacomaworld.com/forum/homertaco/
    Original Satoshi: http://satoshigrill.blogspot.com/2008/08/05-toyota-tacoma-satoshi-grill-mod.html
    01-04 Satoshi: http://www.customtacos.com/forum/showthread.php?t=61042-
    98-00 Satoshi: http://www.tacomaworld.com/forum/1st-gen-tacomas/72510-satoshi-type-grill-1st-gen-style.html
    Best Write-up I found and followed: http://www.tacomaworld.com/forum/2nd-gen-tacomas/28831-my-satoshi-grill-write-up.html
    Tips:
    Before you get started i have a few things that you might want to keep in mind while doing this mod:
    -BE PATIENT.
    -When applying the fiberglass, make sure to try and get the fiber glass as close to the surface where you want it to be covering. this means you need LESS bondo
    -LESS bondo the better
    -let bondo dry!
    -fiberglass is really sticky. use gloves. i used my bare hands and it burns... and you have to scrub your hands ALOT to get it off
    -sand everything before you paint it.
    -go slow and take your time. i did mind in 4 days. took breaks and let things dry when needed.
    -you can do this mod but be aware there is a lot of time invested with waiting on things to dry like fiberglass, bondo, paint, waiting for mesh material coming in the mail.... :spy: (i know that doesnt dry)
    -you dont have to follow every step i made. you can do your own thing. take what you like from other write-ups or ideas and make your own process.
    -SAND AFTER THE FILLER PRIMER. it will be bumpy and ugly. so sand a little bit after you do a few coats of filler primer to cover the bondo.
    -01Tacoma- to anyone looking to do this it's a very easy project to just dive into as log a you take your time and pay attention to detail... And for the recor idiot 7" lights behind mine if anyone was wondering about what size will fit
    -im sure there will be more in the future... dont hesitate to ask me :D
    NOW...
    Step 1: Remove the Grill
    Supplies:
    philips screw driver = to screw off the two screws on the corners of the grill
    long screw driver = to disengage all the plastic anchor points​
    here's a good link with the steps to remove the grill
    http://ebayba.uniqueautodepot.net/2010/grillcraft/mx/silver/installation/toy-1945-s.pdf
    the clips are shown in the figure below
    Remove the grill from the truck
    Step 2: Cut out the center piece
    Supplies:
    electric power jigsaw = to cut out the inside plastic
    dremel = to cut off excess plastic
    sandpaper = to sand down and make the inside portion smooth
    goggles = to protect them eyes!
    breathing mask = the dremel heats up the plastic and gives off fumes​
    Alright... NOW to begin!!!
    begin with the jigsaw and cut away at the center piece
    use the dremel to cut and smooth down the remaining plastic
    Now to cut out the small triangles inserts
    (this part is optional to your choosing.)
    cut away at the tabs that secure it
    The use a smaller tip to get in there and cut the triangle off of the grill
    Now use the sandpaper to smooth out the inside
    start with a low grit and work your way up to a higher grit.
    I used 60 - 100 - 220
    60 Grit
    100 Grit
    220 grit
    Step 3: Fiberglass Application
    Supplies:
    Bondo fiberglass repair kit = comes with all the tools needed with instuctions
    painters tape = to make a guide for the fiberglass application
    dremel with cutting edge OR sissors = to cut away the excess fiberglass when it dries
    paper towels and good soap = this stuff is messy!!!​
    i taped off the grill to keep the resin off the grill
    this is the area that the fiberglass is going to be applied
    apply the painters tape on the area that is going to have the fiberglass
    Follow the instructions given and mix up the fiberglass resin
    Cover the cloth fiberglass in the resin and Now apply the Fiberglass
    let the fiberglass sit for about 5 minutes and then remove the painters tape
    Let the fiberglass dry for 90 minutes!
    cut away the extra fiberglass
    Step 4: Bondo Application
    Supplies:
    Tube of Bondo = for filling in the areas that are backed with fiberglass
    sand paper = for smoothing out the bondo when dry
    flat edge = to smooth out the bondo
    a big fan = if you're as impatient as i am​
    apply the bondo
    to say the least, i didnt use the bondo sparingly! i used a lot but i wanted my inside edges really smooth :cool:
    sand it down
    If it shows signs of cracking you might want to reset that area and apply thinner layers of bondo.
    (i had to do this on one area)
    One more layer of bondo
    ALMOST DONE!!!!!!!!!!!!
    Step 5: Spray Paint Application
    Supplies:
    Sand paper = more sanding! i sanded the entire grill to paint it all black (i used 220 grit for this)
    Filler Primer = spray your first coat on the inner rim on the grill with filler FIRST
    Spray Automotive Primer = spray the inner rim with normal primer too (and entire grill if you wish to do so)
    Desired color of spray paint = well... you do want to spray paint it so... pick a color
    painters tape = to tape off sections that are not being painted​
    Sand down everything you want spray painted with a high grit paper
    which for me, was everything
    more sanding...
    I hung the grill up in my backyard on a trellis that is black, so it was perfect
    first you'll want to apply the Filler Primer to the inner rim where you have bondo. I did the entire inner rim with two coats of filler primer
    after the filler primer apply the primer!
    After the primer was all dry i removed the painters tape and put on the 2 coat of primer to entire grill
    then applied 3 coats of semi-gloss rustoleum to the entire grill
    Letting it sit for the night in my basement and will mount it up tomorrow
    Sprayed the Radiator and all the other junk that will be visible behind the grill with High Heat Resistant Spray Paint
    I also removed one of the horns that is right in front of the radiator. it will look ugly if i left it there. I may relocated it... eventually...
    OH BOY MY HOMERTACO MESH ARRIVED
    SO. start by measuring out where you need to cut the mesh down to fit using cardboard to make a template
    Now using the template, trace (sharpie) where you need to cut. I cut a 1/4 inch away from the line i drew
    JUST IN CASE
    Make marks on the card board where the towers are that extend out and connect the grill to the truck.
    you can utilize these towers as a area to anchor down the mesh grill with screws
    CUT and leave yourself some extra mesh so you have some room for fitting
    I shaved the plastic off the bottom of both outside towers so the mesh would lay and fit easier
    then molded the mesh to fit around the towers so i can screw them in and secure the grill at the bottom
    NOW prime and paint it
    I used this...
    I wanted the TRD symbol in the middle so i made a stencil with cardboard!
    And then spray the color of your choosing
    Sorry i dont have a picture of the mesh by itself. my phone battery began to die on me.
    Before you move on the next step (this is optional) finish the triangle cut outs and measure up the mesh for the triangles
    Start by cutting out the middle of the triangle plastic
    then finish off the job with a dremel and smooth out the edged
    measure up the mesh to the triangle so you can install it later
    Glue the plastic inserts back onto the grill. I used gorilla glue.
    Then Paint the Triangle mesh so they can be installed
    Then spray paint the triangle plastic inserts to match the grill
    CONTINUED........ NEXT POST
    Gmonk91, SwampYota and alphabravo like this.
  2. May 31, 2012 at 12:01 AM
    tacomarotto
    Jon
    Jacksonville
    Audi S3
    Step 6:MESH Application
    Supplies:
    Drill = to make holes in the grill to install zip ties and also make holes for the three screws to secure the mesh
    Screwdriver = To screw in the screws that secure the grill at the bottom
    3 small plastic screws = to secure the grill at the tower points at the bottom
    Zip Ties = secure the mesh in various areas
    Once your mesh is dry, prepare the grill to install the mesh. drill holes in the plastic where you will zip-tie as follows
    Screw the Grill into place at the three areas shown
    you can make holes for zip ties where ever you see fit! i added a lot of holes. I wanted my grill to be VERY SNUG
    ALMOST DONE! hang in there. almost time for a ice cold beer
    Now to get the triangle mesh to cover these holes (remember the triangles are a optional step)
    Drill around the triangle area small holes to anchor it down with zip ties.
    I drilled 4 holes in areas i saw fit.
    thread the zipties through the mesh then through the hole. do not tighten the ziptie until you have all the others threaded as well
    tighten the zip ties alternately so one does not take all the pressure. distribute the pressure evenly.
    cut the excess and there you have it!
    DONE!!!
    put your satoshi grill on your truck!
    DO NOT HESITATE to PM or Post questions
    glad to help out.
    enjoy!
    Video of the finished product
    http://www.youtube.com/watch?v=0aLkZBSBki4
    JoeT4R, Gmonk91, Sandeman and 2 others like this.
  3. May 31, 2012 at 1:08 AM
    htuong95
    htuong95 Have a nice day
    Sacramento
    2001 Tacoma 4x4
    Full OME suspension, Level 8 Tracker 16" wheels, BFG T/A KO 285/75/16, etc., work in progress...
    looking good.
  4. May 31, 2012 at 1:21 AM
    tacomarotto
    Jon
    Jacksonville
    Audi S3
    thanks man
  5. May 31, 2012 at 1:22 AM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
  6. May 31, 2012 at 9:53 AM
    trmarshall1
    trmarshall1 The Least Interesting Man In The World
    Tim
    San Jose, CA
    02 Tacoma 4x4 TRD Supercharged
    4" Pro-Comp Lift, TRD cat back exhaust, grey wire mod, clutch pedal linear spring mod
  7. May 31, 2012 at 9:58 AM
    trmarshall1
    Tim
    San Jose, CA
    Can't wait for the full write up! Love the look, and am going to do this with lights behind. It'll take me a while to do and I've got to color match, so I'm gonna buy a replacement grille to Satoshi so I don't have to drive around to a few weeks sans face.
  8. May 31, 2012 at 10:09 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
  9. May 31, 2012 at 10:28 AM
    tacomarotto
    Jon
    Jacksonville
    Audi S3
    bondo drying
    :cool:
  10. May 31, 2012 at 10:32 AM
    Madjik_Man
    Colorado Front Range
    This is going to be the Grand Poobah of Satoshi walk throughs.
    And I'm about to dumb it down with this question:
    I've read several walk throughs for all the grille conversions and understand that fiberglass/bondo is an integral part of the process.
    My question simply is why? Why do you fiberglass and/or bondo the inner lip of the grille? Can't you just smooth it all down and then insert the mesh flush?
    Don't worry... I can take it like a man, so come at me Bros
    :crapstorm:
  11. May 31, 2012 at 10:47 AM
    tacomarotto
    Jon
    Jacksonville
    Audi S3
    well on the BOTTOM lip you don't need to use and bondo/fiberglass. just alot of sanding.
    but on the UPPER lip, fiberglass and bondo is required because there are areas that are left open and will leave gaps when the mesh is laid on the backdrop.
    i used bondo on all four sides, all cornerns, and little nicks and scratches because im a perfectionist when it come to projects like this
  12. May 31, 2012 at 11:36 AM
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    i do this same kind of shit everyday at work. :D
  13. May 31, 2012 at 11:36 AM
    Madjik_Man
    Good to know. And yeah do it right is my motto too.
    I've never worked with fiberglass or bondo before... is it hard?
    In jr97's write up for a 95-97 (which is what I would be doing eventually) he said it was his first time using either and his project came out looking amazing.
  14. May 31, 2012 at 11:37 AM
    tacomarotto
    Jon
    Jacksonville
    Audi S3
    i thought you waited tables?
    :p
  15. May 31, 2012 at 11:38 AM
    tacomaforlife
    Robbie
    AIKEN, SC
    lol couple years ago now i do paint and body on business jets in augusta, GA
  16. May 31, 2012 at 11:38 AM
    tacomarotto
    Jon
    Jacksonville
    Audi S3
    yea its my first time too and im taking it really slow
    no pun intended...
  17. May 31, 2012 at 11:39 AM
    tacomarotto
    Jon
    Jacksonville
    Audi S3
    oh sweet. i didnt know that. as i remember, was it your dads restaurant?
  18. May 31, 2012 at 11:41 AM
    tacomaforlife
    Robbie
    AIKEN, SC
    no it was a friends restaurant.
  19. May 31, 2012 at 11:47 AM
    Brandon9402
    Brandon9402 uncoordinated dirtbox
    Brandon
    Mississippi
    02 prerunner sr5
    Kenwood headunit, 4 kicker 5x7 coaxials,2 memphis 1.5" tweeters, 2 12" memphis subwoofers, memphis 500w amp, chrome grille guard, kc fog lamps, chrome side steps, chrome tool box, and window visors
    SUBBED! if its not hard im gunna do my own one day
  20. May 31, 2012 at 12:11 PM
    tacomarotto
    Jon
    Jacksonville
    Audi S3
    gotcha
