Satellite Radio - 2010 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RaceGunner, Nov 27, 2020.
  1. Nov 27, 2020 at 4:18 PM
    RaceGunner
    RaceGunner [OP] Member
    Mark
    2010 Tacoma V6 Access cab
    Trying to figure out satellite radio functionality on 2010 Tacoma here's a pic of the radio console...
    Has AM / SAT button.
    I know I've got to call Sirius XM to transfer my service from my Jetta to this vehicle.
    In one know how I get this receivers ID to give 2 Sirius XM?
    Any other tips / tricks ?
  2. Nov 27, 2020 at 5:18 PM
    Brian_d
    Brian_d Well-Known Member
    Socal
    Should be able to set the unit to sat & the code should scroll on the display
  3. Nov 27, 2020 at 5:25 PM
    RaceGunner
    Mark
    I was on the phone with Sirius XM and They said the same saying but when I pushed the am/satellite but nothing happened.
  4. Nov 27, 2020 at 5:44 PM
    Brian_d
    Socal
    Try pushing the "text" button?
  5. Nov 27, 2020 at 5:45 PM
    RaceGunner
    Mark
    I did. Nothing. :(
  6. Nov 28, 2020 at 5:01 AM
    Delta09
    Delta09 OSHA Violator
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    While you have the XM pre-wire kit, unfortunately more than likely you do not have the receiver. I have the same issue on my truck, but mine has an oldschool Ipod adapter kit plugged into it instead.
    RaceGunner[OP] likes this.
  7. Nov 28, 2020 at 5:24 AM
    TacoJoeBro
    TacoJoeBro Well-Known Member
    Not Joe
    Midwest
    12 DCSB OffRoad
    6112/5160 Icon RXT JBA KO2
    On mine (2012) once you select “XM”,
    The XM preview channel starts playing. Then tune the station up or down. The “radio ID” will display instead of the next/previous station. If you don’t get XM preview channel, then you probably don’t have the receiver, only the prewire as stated earlier.
  8. Nov 28, 2020 at 6:39 PM
    RaceGunner
    Mark
    Set up an appt at BestBuy to get an xm capable receiver installed.
