SAS 2nd gen tacoma
Discussion in 'Solid Axle Suspension' started by Ropenasty, Jun 11, 2020.
  1. Jun 11, 2020 at 7:08 PM
    Ropenasty
    Ropenasty [OP] Member
    Does anyone know any axles that match up well with the stock real axle. I'm looking to do a swap I was thinking and fj60 with a new transfer case any suggestions?Screenshot_20200611-190744.jpg
  2. Jun 11, 2020 at 8:18 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    what do you mean match up well? Strength, WMS, R&P ratio? You can go get a custom front axle made and spend all kindsa cash, depends what your budget is. The FJ60 axle has the pumpkin on the passenger side, so you're out of luck unless you want to do alot of extra work and get a passenger drop case.
  3. Jun 11, 2020 at 8:23 PM
    Ropenasty
    Ya basically something I could put in the front without changing the rear but after slot of research seems like just building 2 Dana 60s is the way to go?
  4. Jun 11, 2020 at 8:31 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    That's like asking what kind of oil to put in your vehicle. You'll get a wide variety of opinions, I'd determine what you want to use your truck for, what tire size you'll be running, what engine power you're putting out, and go from there.
    SR-71A and fatfurious2 like this.
  5. Jun 11, 2020 at 8:38 PM
    Ropenasty
    I do a heavy amount of crawling now. I'd have the stock motor in my second gen. The Marlin crawler box, is there an axle I could match up with my stock rear now that would not require new gears? I was planning on building a SAS with just springs for now and then upgrading as I go but I could not find a front that matched the back gears and drop. I'm kinda new to building just trying to see what's out there.
  6. Jun 11, 2020 at 8:39 PM
    Ropenasty
    I currently run 35s. Not sure I'd really need to go bigger I mean everyone wants 40s but I don't think it's necessary.
  7. Jun 11, 2020 at 8:56 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    For leafs and 35s, I’d go with a flipped toy axle, or get a new housing from trail gear. With Dana 60’s and 35s you’ll be dragging that front pumpkin like a boat anchor. Get a HP 8” diff and you’ll be set since you’ll be riding on the drive side of the gearset.
    Ginger-Vitis likes this.
  8. Jun 13, 2020 at 11:18 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Just wheel it as is with a crawl box. That's a far more impactful mod performance wise than an SAS.
    Probably invest in some sliders as well.
    SR-71A and Mully like this.
  9. Jun 13, 2020 at 11:23 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Buy another vehicle if you want a solid axle up front. Not worth the cost or trouble to do a SAS on a Tacoma. My old 4Runner will run circles around any Tacoma with a solid axle.
    Daria likes this.
  10. Jun 13, 2020 at 11:27 AM
    slander
    Hickory, NC
    Yes but did it have AC?
  11. Jun 13, 2020 at 12:20 PM
    Ropenasty
    I have the crawler box
  12. Jun 19, 2020 at 6:12 AM
    signguy
    signguy Well-Known Member
    Mission mountains, MT
    supercharged sas
    You are crazy
  13. Jun 19, 2020 at 6:17 AM
    v5ensx
    v5ensx CARB legal is not CALI legal
    Care to elaborate how your 4r can run circles around SA Tacoma?
    PandaYota, reg0928 and Mully[QUOTED] like this.
  14. Jun 19, 2020 at 6:21 AM
    v5ensx
    Crawl control option or an actual dual case setup? There's a BIG difference between the two.
  15. Jun 19, 2020 at 6:26 AM
    YotaBum
    YotaBum Not So Well-Known Member
    Alex
    North Georgia
    2015 TRD Sport DCSB
    Blacked Out-887-Dakars-LR UCA-FJ Trail Team wheels-285 BFG KO2
  16. Jun 19, 2020 at 7:44 AM
    Mully
    CA
    I was just being an obnoxious ass.
    Starring the pot, it was just a joke.
    Tacoma with a SAS are full on badass.
    mojojojo78 and bhigbee like this.
  17. Jun 19, 2020 at 9:38 PM
    v5ensx
    Now that's sick
    Mully[QUOTED] likes this.
  18. Jul 3, 2020 at 7:28 AM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    A first gen 4Runner on 37’s will wheel circles around a second gen Tacoma on 40’s even. A second gen Taco is a big heavy bitch compared to a first gen 4Runner
  19. Sep 28, 2020 at 8:18 PM
    ToyotaRoamer86
    ToyotaRoamer86 Well-Known Member
    Brandon
    Frisco, CO
    2007 Tacoma TRD Sport
    67" wms on fj80 knuckles, ifs hubs --- Only 1" difference side to side.
  20. Sep 29, 2020 at 3:44 PM
    02hilux
    Planet: EARTH
    IFS and FJ80 hubs are completely different, how did you make that work? Guys go from SA to IFS hub to gain ~3" width, but never heard builder using IFS hubs with FJ80 outer.
