San Diego fabrication rec
Discussion in 'Southern California' started by Blue-steel, Sep 8, 2023.
  1. Sep 8, 2023 at 11:55 AM
    Blue-steel
    Blue-steel [OP] Well-Known Member
    Looking for a fabrication shop to install a landcruiser ARB bumper on my tundra. The mounts need to be custom fabricated and altered to fit. Trying to keep the cost down on the install, because one shop I contacted said the install will be as expensive or more than the bumper.
  2. Sep 8, 2023 at 11:25 PM
    TacoTuesday1
    FL
  3. Sep 9, 2023 at 1:00 AM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    Contreras fab in Tijuana
    Blue-steel[OP] likes this.
  4. Sep 17, 2023 at 8:10 PM
    FishingInSand
    FishingInSand Well-Known Member
    Corey
    Temecula
    06 now with 4x4
    Some stuff here and there
    Hit up Jason and see if he'll take it on, he probably has a thousand recommendations myself included. @Speed Freek
    Speed Freek likes this.
  5. Nov 4, 2023 at 9:59 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Turned out really good, but holy crap that was time consuming...I forgot to respond to the thread a while back.
    I made some super beefy custom mounts that turned out super good however it took 2 days to complete, however it will certainly be stronger than the factory mounts that it came with so that's good.
    Not sure I'd want to do it ever again but in the end it looks like it belongs on the truck as long as you take the time to triple check how it lines up and make absolutely sure that it is fitted properly front to back and side to side when tacking it in place before removal and finally burning it in..
    d.shaw likes this.
  6. Nov 4, 2023 at 10:04 AM
    Speed Freek
  7. Nov 7, 2023 at 3:04 PM
    ill ay
    ill ay I DO MAN STUFF
    The Valley
    2012 Pre Tacoma & 2017 4x4 SR5 Tacoma
    Amazing work and sometimes these one off projects are a pia. It looks good and you did an amazing job but you can see how it doesn't look like it belongs on the Tundra. It's extremely wide and heavy on the front end. If that's the look he's going for, then he accomplished it. I compared it to the original picture the OP posted. He should've sold that bumper and just bought one for his Tundra.
    How much did you charge him if you don't mind me asking?
