Same torque for alloy wheels?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kiki111, Oct 16, 2020.
  1. Oct 16, 2020 at 9:32 AM
    kiki111
    kiki111 [OP] MENTALLY DISTURBED MEMBER
    Tacoma 2.7L SR
    getting my new wheels tommorow....ordered new rims, tpms, center caps, wheel lugs....
    question old rims...factory steel rims
    new rims factory alloy rims...
    toyota says torque to 83 ft lbs on steels...is it the same torque for alloy?
  2. Oct 16, 2020 at 9:34 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. There is no distinction in the Owners Manual.
    shakerhood likes this.
  3. Oct 16, 2020 at 9:35 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yes. I make it a nice 85 ft lb.
    CusterFan, tcjacado and wiljayhi like this.
  4. Oct 16, 2020 at 9:40 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Torque value are based on the fastener (lug bolt) size and the clamp load needed for the task.
    83 ft lbs is correct and sufficient. Please do not fall into the mindset of "if tight is good, then tighter must be better"
    BTW, few torque wrenches are able to discern a 2 ft lb difference. I torque mine to 85 ft lb setting on the torque wrench.
  5. Oct 16, 2020 at 9:46 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    And also, that even lug nut torque will prevent induced warp in the brake rotors. Maybe not so much of an issue on the Taco, but there have been some pulsing rotors reported. Of course, no real feedback if re-torquing worked.
  6. Oct 16, 2020 at 9:49 AM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    The tech at my dealer does the same. 85 ft-lbs torqued and retorqued.
    boston23 likes this.
  7. Oct 16, 2020 at 9:51 AM
    Knute
    Torque wrenches do not have a good resolution of increments.
    I wouldn't consider it a "precision" instrument or tool.
  8. Oct 16, 2020 at 9:52 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    just had mine done ..................83 !
    be certain to hand mount ALL
    NO ratchet/burp guns
    U want to be able to get those lugz off at 3am in the rain dark on a soft shoulder
    tonered likes this.
  9. Oct 16, 2020 at 9:58 AM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    Yep. 85 ft lbs. Easy to remember.
    CusterFan likes this.
  10. Oct 16, 2020 at 10:59 AM
    kiki111
    Tacoma 2.7L SR
    i use a new craftman torque wrench, i torque every time i rotate tires...83 ft lbs
    but 85 ft lbs sounds good
    tonered likes this.
  11. Oct 16, 2020 at 11:06 AM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Out of curiosity, what does the wheel manufacturer recommend?
  12. Oct 16, 2020 at 11:10 AM
    boston23
    boston23 Well-Known Member
    Adam
    Bend, OR
    2019 SR5 DCSB 4x4
    Curious why over torquing is bad. I know it is but dont know why
  13. Oct 16, 2020 at 11:11 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You stretch the bolt and it weakens it/can snap it in half. That applies to all bolts.
    tonered likes this.
  14. Oct 16, 2020 at 11:15 AM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    I love some auto manufacturers give you a range which drives me nuts. For example, our Hyundai Santa Fe torque is 65.1 ~ 79.6 lb - ft so I go with a nice round 80. They do this for all the fasteners from trim screws down to axle nut. In the long run, it's probably more representative of a variations in clamping force from torque wrench, lubricant on threads, bolt stretch... etc. but the ocd in me just wants one number!
    tonered likes this.
  15. Oct 16, 2020 at 11:15 AM
    su.b.rat
    su.b.rat broken truck
    interestingly, i was told this spec is manufacturer specific, not wheel specific, and is related to the hubs not the wheels.
    tonered likes this.
  16. Oct 16, 2020 at 11:16 AM
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    puts too much stress on the bolt, and the contact surfaces.
    tonered likes this.
  17. Oct 16, 2020 at 11:18 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    There is always a range. But for shops and the home gamer, the nominal number is all that we need unless it is something particular like head bolts and such.
  18. Oct 16, 2020 at 11:20 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    TacoTruck808, Smacky2020 and tonered like this.
  19. Oct 16, 2020 at 11:23 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  20. Oct 16, 2020 at 11:24 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Boghog1, Smacky2020 and tonered like this.
