Sail panel tweeter
Discussion in '3rd Gen. Tacomas (2016-2023)' started by akoaypogi29, Mar 4, 2023.
  1. Mar 4, 2023 at 5:28 PM
    akoaypogi29
    akoaypogi29 [OP] Active Member
    Raymond
    2019 MGM TRD Off Road
    Front bumper
    Anybody here have done sail panel tweeter? Please show some pics…
    Santytacoma likes this.
  2. Mar 4, 2023 at 5:38 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    5nahalf likes this.
  3. Mar 4, 2023 at 6:35 PM
    Spielightdude
    Spielightdude Well-Known Member
    Joseph
    Canterbury
    2023 TRD Offroad
    I was wondering about that myself for a 3 way set up woofer in the door mid rage in factory dash and tweeter in the a pillar.
  4. Mar 4, 2023 at 7:01 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Here is mine, They are JBL stadium components with the stadium 2 inch midrange in the dash location. And yes, the orange of the mids and tweeters matches the color of my truck :)
    These are in my dash, they are midrange speakers
    Spadi_5 and Nate88cool like this.
  5. Mar 4, 2023 at 8:07 PM
    akoaypogi29
    Raymond
    Front bumper
    @5nahalf do you have 3-way crossover installed? I’m running 2-way component I do have morel woofer 6.5 speaker on front door and morel 1” speaker on dash but I’m planning to put midrange on dash and the morel 1” speaker that will be relocate on sail panel
  6. Mar 4, 2023 at 8:11 PM
    japjoe7
    japjoe7 Well-Known Member
    Joey
    Pike County, PA
    21 Barcelona Red Sport DC AT
  7. Mar 4, 2023 at 8:18 PM
    5nahalf
    Erik
    Minnesota
    I am not running 3 way crossovers, I am running a 10 channel DSP to a pair of 4 channel amps and a mono amp. The DSP time aligns, adjusts levels and controls the frequencies of each speaker individually. So each speaker has its own channel of amplification.
    D.A.S. Taco and Spielightdude like this.
  8. Mar 4, 2023 at 8:35 PM
    akoaypogi29
    Raymond
    Front bumper
    @5nahalf gotcha! So should I run DSP when I install midrange speaker? Like I said I’m running 2-way component with crossover, along with 2 separate amp 1 JL RD400/4 for all door speakers/dash and 1 JL RD500/1 for 2 10” subwoofer
  9. Mar 4, 2023 at 8:36 PM
    akoaypogi29
    Raymond
    Front bumper
    @5nahalf also I’m running aftermarket head unit
  10. Mar 4, 2023 at 8:44 PM
    5nahalf
    Erik
    Minnesota
    You can run a DSP, but unless you plan to add another RD400/4 you will need to run a normal passive crossover.
    The way my system run, each tweeter has its own channels, each mid has its own channels, each woofer has its own channels and each rear speaker has its own channels. So there are 8 channels just to run my speakers (the 9th is subwoofer).
    D.A.S. Taco likes this.
  11. Mar 4, 2023 at 8:48 PM
    5nahalf
    Erik
    Minnesota
  12. Mar 29, 2023 at 10:46 AM
    CRogersism
    CRogersism Well-Known Member
    Used body filler on a stock sail after drilling the correct size hole I needed.
    Used sandable filler primer to fill in those smaller holes.
    Used SEM Plastic Trim paint
    Used SEM Texture Paint to try and match the textured plastic. It's not a perfect match.
    Final product with the Audiofrog GB10 Tweeter Installed.
    GB25 inside the dash, and GS690 in the door.
  13. Mar 29, 2023 at 10:53 AM
    japjoe7
    Joey
    Pike County, PA
    Nice! They came out great! I'm doing the same exact thing as you.
  14. Mar 29, 2023 at 11:56 AM
    akoaypogi29
    Raymond
    Front bumper
  15. Mar 29, 2023 at 12:01 PM
    akoaypogi29
    Raymond
    Front bumper
    @CRogersism got mine custom work from my local audio shop. Currently I'm running morel maximo ultra 602 2-way and i decided to add the morel ccwr 254 2.5' midrange driver so they relocate my 1" tweeter on the dash into sail panel then put the ccwr 254 on the dash.
  16. Mar 29, 2023 at 2:13 PM
    CRogersism
    Looks like they used some sort of fabric. Is that what that texture is? I know the Faux Leather pattern is pretty close to the molded plastic texture on that trim piece.
  17. Mar 29, 2023 at 2:35 PM
    rnmnzii
    rnmnzii Active Member
    rene
    taco
    Nice, looks oem
  18. Apr 12, 2023 at 5:53 PM
    sempermma
    sempermma Living the Dream
    Michael
    Maryland
    2022 White Tacoma TRD Off Road
    - Diamondback Tonneau Cover - Prinsu Cab Rack - Voswitch 8 Gang Switch Panel - Auxbeam 4" Amber Ditch Lights - Rhino Shackles - Sequential Dynamic Turn Signal - Dashtop Multi-Mount - Triple Tailgate Light Bar - Custom Trailer Wiring Harness - Sony XAV-9500ES - Rockford Everything
    These turned out great. Any directional issues once mounted?
  19. Apr 13, 2023 at 4:28 AM
    CRogersism
    None that I can hear. I'm running them off a Pioneer 6600NEX and Audio Control D-6.1200. Audiofrog's are definitely worth the price.
    sempermma[QUOTED] likes this.
  20. Apr 13, 2023 at 5:25 AM
    sempermma
    Michael
    Maryland
    Thanks for the update, I'll have to check them out. I'm a Rockford guy and hadn't heard of Audiofrog before. Great job on this!
