Safe to tow from bumper?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Timbo66, Dec 19, 2021.
  1. Dec 19, 2021 at 10:15 AM
    Timbo66
    Timbo66 [OP] Well-Known Member
    I have a 2006 Tacoma 4WD that I want to tow behind a motorhome. But I see that it has an aluminum bumper under a plastic skin and I worry that aluminum isn't strong enough to tow from. My fear that the aluminum would crumple pretty easily. Then again, it is a bumper, and in theory ought to be strong enough to pull the truck. But maybe that's naive. Appreciate anyone's opinions.
    Here is the underside, showing the alum bumper which is a 2" thick and hollow. Note the extensions that connect it to the steel frame.
    Here are the brackets that would be bolted through the skin and the aluminum bumper
  2. Dec 19, 2021 at 10:19 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Flat towing 4wd Tacomas requires a driveshaft disconnect.
    Tow from frame, not bumper.
    Knute, whatstcp, Dm93 and 2 others like this.
  3. Dec 19, 2021 at 10:20 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Put it on a car trailer. You can not flat tow the truck. It’s in the owners manual.
    Knute, TRDSport10, road2cycle and 2 others like this.
  4. Dec 19, 2021 at 10:24 AM
    Timbo66
    I'm aware of that and planned to remove the driveshaft
    boston23 likes this.
  5. Dec 19, 2021 at 10:25 AM
    Timbo66
    I'm not much of a manual-following guy
    boston23 and bubba swift like this.
  6. Dec 19, 2021 at 10:27 AM
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    Then hook it up and giv'er.
    Marc70 and whatstcp like this.
  7. Dec 19, 2021 at 10:33 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    The bumper is, by design, a sacrificial, impact-absorbing member (In plain English, it's intended to crumple! - notice you didn't get a bumper jack with your truc?). Putting aside the issues of flat-towing a truck that is not meant to be flat-towed (Your truck, you do what you want), you could probably actually get away with towing that way on flat, level ground, provided you drove gently, but if you had to make a panic stop, panic acceleration, or other emergency maneuver, it's very likely that the tow vehicle and Tacoma would part ways.
    eherlihy likes this.
  8. Dec 19, 2021 at 11:50 AM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    I’d be wary of not following the manual on this one. Too much liability if something goes wrong and the tow vehicle and Tacoma become two disconnected objects. Think about others around you who could get affected by an uncontrolled Tacoma breaking loose from the tow vehicle.
    wi_taco, Marc70 and 2015WhiteOR like this.
  9. Dec 19, 2021 at 1:55 PM
    Timbo66
    That's exactly my fear. Now, if this were a jeep with a nice big steel bumper and no plastic skin....
  10. Dec 19, 2021 at 2:31 PM
    TacoTuesday1
    FL
    BPFabricating makes add-on recovery points that bolt onto the left and right front side of the truck, possibly to frame. Not sure if that it something that can be used.
  11. Dec 19, 2021 at 2:41 PM
    Bishop84
    Bishop84 Well-Known Member
    Fuck no. Mount the brackets to the frame.
    Also buy a proper vehicle to drag, tacoma is far from the right choice.
    2015WhiteOR likes this.
  12. Dec 19, 2021 at 3:29 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Not related to anything going on here but couldn't help but think of this video. The poor Nissan truck.
  13. Dec 19, 2021 at 5:04 PM
    tirediron
    It would be in the shop, and you couldn't tow it anyway... :p
    Jimmyh and 2015WhiteOR like this.
  14. Dec 19, 2021 at 6:55 PM
    Timbo66
    Yeah, with some rope. It'll probably be fine :crazy:
  15. Dec 19, 2021 at 6:56 PM
    Timbo66
    :itllbuffout:
  16. Dec 20, 2021 at 9:57 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    road2cycle and 2015WhiteOR like this.
