Safe to run RIGID SRQ Pro on Factory Fog Switch?
Discussion in 'Lighting' started by BeaconHillT4R, Apr 15, 2020.
  1. Apr 15, 2020 at 8:49 PM
    BeaconHillT4R
    BeaconHillT4R [OP] Well-Known Member
    I have a pair of Rigid SR-Q Pro P#915313 which I plan to run for offroad fogs on my 2014. Would if be safe to run these two lights directly on my factory fog switch? I purchased a pair of the H11 to Deutsch connectors and plugged the Rigids into the factory fog harness, everything worked fine but how safe will they be to in the long run?
    The Rigid kit came with their harness, relay, switch but just trying to keep everything clean and run the factory fog switch if possible.
    https://www.transoniconline.com/RIGIDIndustries/SR-Q-Series-Pro-Driving-Light/915313
    Product Specifications
    SR-Q Series Pro Driving Light
    Surface Mount
    5 in.
    Specter
    6 White LEDs
    Black Rectangular Housing
    Set Of 2
    Amperage Draw: 2.93
    Application: Automotive
    Beam Distance w/ .25 LUX: 332.3 m
    Beam Distance w/ 1 LUX: 166.1 m
    Beam Style: Driving
    Bulb Technology: LED
    Field Horizontal: 46.8 Degrees
    Field Vertical: 22.2 Degrees
    Housing Color: Black
    Housing Shape: Rectangular
    LED Quantity: 6
    LUX @ 10m: 275.99
    Peak Beam Intensity (cd): 27599
    Quantity Sold: 2
    Raw Lumens: 4752
    WARNING CA Proposition 65: No
    Wattage: 41
    Product Features
    This 6 LED Light Can Be Used For Any Lighting Application
    Offers The Same Light Out Put As D2 In A 1 x 6 Configuration
    3030 Raw Lumens At Only 34.5 watts
    Compact Size And Shape Allow Light To Fit Almost Anywhere
    Incl. Mounting Hardware Plug And Play Wire Harness w/Switch
  2. Apr 15, 2020 at 8:54 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Factory H11 fogs draw about 4.6A, those draw less than 3A, so it is less power than stock. Won’t be a problem.
    BeaconHillT4R[OP] likes this.
  3. Apr 15, 2020 at 9:07 PM
    BeaconHillT4R
    Awesome crashnburn80!
    crashnburn80[QUOTED] likes this.
  4. Apr 15, 2020 at 11:13 PM
    caribe makaira
    Caribbean, Puerto Rico
    There is a relay involved in the factory fog lights...OP is asking to use the switch alone...or he and you forgot about the relay.
    And the blue,nice thick 22 awg gauge, wire.
  5. Apr 15, 2020 at 11:27 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Unsure what you are trying to imply. He stated getting an adapter to run the Rigid lights directly off the OEM fog light plug, using the OEM fog light switch. The OEM fog light plugs use an OEM relay to run off the OEM switch. You cannot run lights off the OEM switch alone and bypass the OEM relay without significant custom wiring, which is clearly not what the OP is stating when he says he has adapters to plug into the OEM H11 foglight connectors off the factory harness. The OEM halogen fogs are 55w, the Rigid LEDs are 35w. It won’t be an issue.
  6. Apr 15, 2020 at 11:34 PM
    caribe makaira
    My bad..I focused his opening remark...
