safe to run 90 ethanol free ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AMGTRDPRO, Sep 4, 2021.
  1. Sep 4, 2021 at 12:06 PM
    AMGTRDPRO
    AMGTRDPRO [OP] Well-Known Member
    2021 Lunar Rock TRD PRO
    I have a brand new 2021 TRD Pro and was wondering if it was safe to run 90 ethanol free gas ?
    I have a station a mile away that sells it. I know that there is 10 percent in 87-93 I just don't know if safe because I know Toyota has these trucks tuned for 87 for fuel eco reason. I do not care about the cost being I have had and have cars that require 93 only. I just want the truck to run to it's best abilities. side note what about 93 with 10percent ethanol vs the 90 ethanol free ?
    thanks to all that reply.
    1Crusader likes this.
  2. Sep 4, 2021 at 12:13 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Alcohol free is fine.
  3. Sep 4, 2021 at 12:13 PM
    TSmoove
    TSmoove Well-Known Member
    Trevor
    Atlanta, GA
    2017 Tacoma
  4. Sep 4, 2021 at 12:13 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Good to go
    98_3RZ_NIC, ndoldman59 and Skydvrr like this.
  5. Sep 4, 2021 at 12:24 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    You're find but ethanol is a very good cleaning solvent that keeps your injectors and intake valves clean. It's downside is that it attracts moisture and doesn't have as many BTUs vs. pure gasoline. The cost doesn't justify the added mileage. If I have leftover ethanol free gas in a can and want fresh gas for my small engines, the ethanol free goes into my truck.
    JayRolla and eurowner like this.
  6. Sep 4, 2021 at 12:29 PM
    TRDSlow
    TRDSlow Well-Known Member
    Maxwell
    2018 Tacoma SRUP
    Ethanol free is better in every way.
  7. Sep 4, 2021 at 12:34 PM
    Trail Limo
    Trail Limo Well-Known Member
    Perfectly safe, worse case you might get a little worse fuel economy and power. More likely, the truck will adjust and behave exactly the same as it does with the recommended fuel.
    ndoldman59 and zoo truck like this.
  8. Sep 4, 2021 at 12:37 PM
    TRDSlow
    Maxwell
    2018 Tacoma SRUP
    Actually you will get more power and better fuel mileage with ethanol free fuel.
    beergeek, Frank_NJ, knayrb and 7 others like this.
  9. Sep 4, 2021 at 1:00 PM
    TRD2021SPORT
    TRD2021SPORT Well-Known Member
    2021 Tacoma TRD Sport AC
    Huh???
    Please explain how that works.
    TRD-Troll likes this.
  10. Sep 4, 2021 at 1:01 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    You can run it, but your wasting your money, the trucks runs well if not better on 87.....my 2020 actually runs worse on 92 E10 premium.
    Trail Limo likes this.
  11. Sep 4, 2021 at 1:23 PM
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    We will need a San Francisco decoder ring to translate that.
  12. Sep 4, 2021 at 1:28 PM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    I find mine to run the best and get the best milage with 89 ethanol. We don't have any 0 ethanol so I can't compare that but it sounds perfect for these trucks.
  13. Sep 4, 2021 at 1:30 PM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Running a higher octane will do no harm to your engine at all…just your check book.
    doublethebass and zoo truck like this.
  14. Sep 4, 2021 at 1:36 PM
    bornxbackwards
    bornxbackwards Well-Known Member
    Bruno
    Sherbrooke, QC
    2021 MGM Tacoma SR5 4x4 DCLB
    Debadged, black sumos, brake controller.
    It will run best at 87 octane.
    Edit: unless you're in Colorado or something. Then it's lower.
    zoo truck likes this.
  15. Sep 4, 2021 at 1:59 PM
    TRD-Troll
    NV
    2019 TRDOR DCSB AT
    Was up at South Lake Tahoe yesterday.
    $5.19/gallon
    Yikes, hope the pump also dispenses complimentary lube.
  16. Sep 4, 2021 at 2:12 PM
    AMGTRDPRO
    90 E free It is $3.52 as of now in my area of FL 93 is $3.62
    R4D4G4ST, Skydvrr and Thatbassguy like this.
  17. Sep 4, 2021 at 2:23 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Non E is good for long term gas storage like if you only fill up every 3 months or more. E10 loses Octane after 30+ days. Really no benefits to Octane higher than 87/89.
    I run 89 Non E because I only drive 8 miles a week.
  18. Sep 4, 2021 at 2:35 PM
    TRDSlow
    Maxwell
    2018 Tacoma SRUP
    90 octane is perfect if you have a KDMax regular fuel tune. 90 octane is as high as the tune will adjust to and take avantage of. Anything higher is a waste. A premium fuel tune is a different story but you can't run regular gas with it. Without a tune all you need is 87 octane or 85 at higher elevations. All things being equal ethanol free is better regardless of Octane rating.
  19. Sep 4, 2021 at 2:47 PM
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    I heard rumors of people getting better mileage out of mid grade fuel (using this term for those at elevation). I tested that. I didn't see more mileage. Theoretically it should not work because higher octane is less efficient if you are tuned for regular. Gas without ethanol will give better mileage, but the cost usually doesn't justify it. I'd be curious if you test it. If you have a tune, it may be octane learning. Again, testing will show the results with the higher octane and no alcohol.
    Trail Limo and TRDSlow like this.
  20. Sep 4, 2021 at 3:17 PM
    Trail Limo
    Nothing like selectively quoting a post huh... I said, most likely the computer would adjust for the different octane level, and the lack of alcohol (an oxidizer) in the fuel.
    If you must know how it might be worse though, comes down to timing advance, and the fuel air mixture being different. Alcohol is an oxidizer, meaning that non oxy will run richer than oxidized fuel. Again, modern engines all adjust for this (the O2 sensor can sense the if the engine is running rich), but if it didn't, you would get worse fuel economy due to running rich.
