SA-12, Sundown Audio ported Box
Discussion in 'Audio & Video' started by Marine 8541, Jun 30, 2017.
  1. Jun 30, 2017 at 7:28 PM
    Marine 8541
    Marine 8541 [OP] Well-Known Member
    Jimmy
    Iowa
    Tacoma SR5 4x4
    Stock
    So I am re-building my SA-12 Box. Looking to getting total cubic feet at 2.42. Less the port and speaker displacement, a total of 1.75 cubes, 28" of slot port with a 27.5 " port length after adjustment.
    Today was used to pre-drill, measure, and prep before lining the MDF with a mixture of wood glue and water to seal the surface.
    After the box is layered with sealant it will be primed for paint, and then placed in for taping and fiberglass.
    The sub will not fit with out a fiberglass backing.
    I plan on using a layer of painters tape over the rattle trap.
    I will spray on glue to hold a fleece liner to fill the rear.
    Zac of all trades likes this.
  2. Jul 3, 2017 at 8:15 AM
    Zac of all trades
    Zac of all trades FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
    It looks good! However i think that you are going to have a hard time keeping that sub from hitting the back of your rear seats. I have 2 sd3 10s behind the seats and its fine, i tried to put 2 sa 10s behind there and they didnt fit without hitting the backs of the seats.
  3. Jul 7, 2017 at 3:24 AM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    How do you create the seal against the back wall?
    Marine 8541[OP] likes this.
  4. Jul 7, 2017 at 3:31 PM
    mbrogz3000
    Northern NJ
    I see - I'm always curious to see how people fit normal subs behind the seats. I have the thin 13" JL, but aside from 40HZ to 50Hz, it rolls bass off a little too quickly. The thing claims to play to 20Hz, but it barely makes a tone. Thin subs, no matter what the claims, just don't cut it if you love your bass.
  5. Jul 8, 2017 at 8:05 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    Freq response of a speaker doesnt mean they actually play down to that freq with authority. Look at the subs FS that will give you an indication of where the subs performance lies in the " response range "
    Marine 8541[OP] and ManBeast like this.
  6. Jul 9, 2017 at 3:50 AM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    That and your F3 will be much higher in a sealed alignment (compared to ported, horn-loaded, PR, etc). If you're missing 20 - 40 Hz, that's an entire octave!
  7. Jul 15, 2017 at 3:35 AM
    Marine 8541
    Jimmy
    Iowa
    Tacoma SR5 4x4
    Stock
    Got it covered
  8. Jul 15, 2017 at 3:37 AM
    Marine 8541
    Jimmy
    Iowa
    Tacoma SR5 4x4
    Stock
    I put some rattle trap down, tape, then fiberglass. I had a little rattle so filled the edges with great stuff.
  9. Jul 15, 2017 at 5:01 AM
    Marine 8541
    Jimmy
    Iowa
    Tacoma SR5 4x4
    Stock
  10. Jul 18, 2017 at 4:35 PM
    rob feature
    rob feature Tacos!
    Colorado
    Definitely moving some air. Flexing any panels yet? I halfway expect my SA10 to - if I can feed it enough power.
  11. Jul 18, 2017 at 4:58 PM
    Marine 8541
    Jimmy
    Iowa
    Tacoma SR5 4x4
    Stock
    With the center brace and plenty of fiber glass, it is not flexing the box. The doors, windows, and steering wheel are moving. Plenty of lows and more of a punchy feel.
  12. Jul 19, 2017 at 4:24 PM
    rob feature
    rob feature Tacos!
    Colorado
  13. Jul 20, 2017 at 1:42 PM
    jmeitz
    jmeitz Audio Solutions
    Jeremie
    St. Louis, MO
    2016 Tacoma trd sport
    Remote Start Lift Stereo Leather LED lights
    Impressed
  14. Jul 21, 2017 at 4:23 AM
    Marine 8541
    Jimmy
    Iowa
    Tacoma SR5 4x4
    Stock
    I took some longer bolts to replace the factory ones holding the rear seats and added washers to space the seats forward. Gives an extra half inch or so.
  15. Jul 21, 2017 at 6:58 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    yes thats a great mod
  16. Jan 2, 2018 at 12:55 PM
    Naum02taco
    Naum02taco The Silver Bullet
    Glendale, Arizona
    2014 Tacoma 4WD SR5
    King 2.5 coilovers with reservoirs in front Rear OME 2.75 HD leaf springs with king 2.5 with reservoir 18" fuel Maverick with BfG all terrain 275.70R18
    Does anyone know where I can buy a similar subwoofer enclosed box?
  17. Jan 21, 2019 at 10:54 PM
    quadzilla
    quadzilla Member
    2008 double cab
    This is hands down the best enclosure I've seen in a double cab. Wish these were for sale. It's a little beyond my box building abilities.
  18. Jan 22, 2019 at 5:32 AM
    Zac of all trades
    Zac
    fwpfab.com
    Yeah this looks like it also requires you to seal your back wall with fiberglass, and then use more fiberglass to attach this box to it. That is the only way you can get a normal sized sub to fit, or at least that is the only way i personally have found so far.
    I would just be afraid to tear up the surround hitting the back of the seats. These Sundowns have a lot of excursion so i personally would like a bit more room. haha.
    Even with the seat spacers and removing the back panels it looks a little tight. I have 2 sa10s that i would have liked to install but i need another 1/2" - 3/4" more mount depth to get there, and i need a ported box.
  19. Jan 28, 2019 at 4:17 AM
    Marine 8541
    Jimmy
    Iowa
    Tacoma SR5 4x4
    Stock
    Going on a year and a half, zero rub.
  20. Jan 28, 2019 at 1:40 PM
    Zac of all trades
    Zac
    fwpfab.com
    did you build the box, then disassemble it again to attach it to the rear wall? And how hard was it to fiberglass that rear wall?
    Im debating on ripping out the back seats of my truck and building a platform/sub box. This will give my dog more room in the back and allow for a ported box with 2 12s.
    Of course i will not be jamming with the pup in the truck, and all this would happen after the truck is paid off and i have another DD. I already have 2 sa 10s in my possession but i am saving those for the new DD.
