S-10 Leaf springs
Discussion in '1st Gen. Tacomas (1995-2004)' started by panardo, Jan 10, 2018.
  1. Jan 10, 2018 at 10:20 PM
    panardo
    panardo [OP] Well-Known Member
    Taco 2000 4x4 V6 manual w/RDlock
    Went to the J-yard and found this Leaf springs on a S-10, does it worth to use it on my tacoma 2000 extended cab manual? from center to front measures 26" and to the back shackle 28". is 2 1/2" wide it looks in good shape and super beefy
  2. Jan 10, 2018 at 10:58 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Best way is to measure your leaf to see if they'd fit
  3. Jan 11, 2018 at 1:25 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If you can move things as needed you can make them work
    You might need to get new shocks depending on the length from where the shocks attach
  4. Jan 11, 2018 at 2:17 AM
    OldYota
    OldYota Active Member
    Charleston, SC
    2002 Tacoma TRD
    Anyone ever tried Dakota springs? Length is 1/2 longer overall, pin is close to offset of Tacoma, 1/8”. Just a thought. We used to use them on Cherokees to make bastard lead packs, used the top leaf on the Cherokee and the rest of the leafs from Durango pack.
  5. Jan 11, 2018 at 4:09 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    S-10 leafs are spring under. They would probably be way too tall on a tacoma as spring over and may not even mount correctly.
  6. Jan 11, 2018 at 8:40 AM
    panardo
    what about that top leaf that is running on top of the axel of the S-10?
    Oldyota Do you have the measurements of the rest of the toyotas pickups, like 94 and on?
  7. Jan 13, 2018 at 4:20 AM
    OldYota
    Charleston, SC
    2002 Tacoma TRD
    Quick Google search shows 24 1/8” front eye to pin and 31 1/8” pin to rear eye on 01-04 Tacoma.
    More searching shows about a 3” difference in free arch of S10 spring vs Tacoma.
  8. Jan 13, 2018 at 7:26 PM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
  9. Jan 13, 2018 at 7:55 PM
    rybern
    rybern Well-Known Member
    N Alabama
    2023 TRD OR & 2000 SR5
    5100's & 3AAL, 265/70r17 Toyo AT3
    I used my top leaf (the one with bolts through it) and replaced only the 2nd leaf with ones from a Dakota truck. I don't see why this would't work the same way. I didn't want a lot of lift but just wanted to replenish the sagging springs. Swap the leafs until you get your desired result. No regrets. Here's a few details of what I did. https://www.tacomaworld.com/threads/omd-1st-gen-leaf-mod.500081/
