RWD to 4x4 conversion
Discussion in '1st Gen. Tacomas (1995-2004)' started by cgunn1800, Dec 31, 2017.
  1. Dec 31, 2017 at 6:41 PM
    cgunn1800
    cgunn1800 [OP] New Member
    1995 Toyota Tacoma
    None
    So I'm new to the online discussion world, but I wanted to just throw this out to anyone that might have any experience. I have a 1995 Tacoma that I inherited from my grandfather. Its only got about 121,000 miles and runs strong, but is only a RWD. I briefly read through a few different forums I found on various sites, but I am interested in doing a 4x4 conversion on my truck. Its really not worth selling (I don't owe anything on it but the money I would get isn't worth letting it go.) Does anyone know someone, or have any experience with the work involved, general costs, tips or tricks?
  2. Dec 31, 2017 at 9:44 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  3. Dec 31, 2017 at 9:47 PM
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    Easiest way it to find a donor truck. But yes look at the links listed above.
    And welcome to tw.
    A rwd can be just as fun as a 4x4
  4. Dec 31, 2017 at 10:28 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Funny you ask I'm in the middle of doing it right now.
    You must have a PreRunner, the 5-lug Tacomas will not work. You don't necessarily need to have a parts truck - while it does make it easier it's very doable to do it just collecting parts. It took me about six months to collect everything.
    Easiest way is to buy a 4x4 transmission like the A340F for automatics, or the R150F (iirc) for Manuals. People sometimes swap the output shafts but it's rather difficult.
    You can have ADD or Manual Hubs, Manual Hubs are significantly easier to get to work than ADD. If you want to use the ADD system it requires wiring up some VSV's and vacuum lines which you'd rather not deal with.
    With the used parts, new seals and fluids, plus the cost of alignment I'm expecting to pay $2,500. So far I've spent about $2,000 not including the cost of an alignment.
    It's not bad. Feel free to ask if you have any questions.
  5. Jan 1, 2018 at 7:02 AM
    Indy
    Indy Master of all I survey.
    1. Find a 4wd of the same year.
    2. Swap bodies.
    3. Go get lunch.
    Obviously it's not an afternoon project, but the conversion is long and can be fairly expensive. Most people will be time and money ahead by trading the 2wd in for a 4.
    But some just "love" their truck and would rather spend the time and money. For those, the body swap does the same job for less time and work. You just then have to decide which part of the truck, is the truck? If it's the frame to you, if it's the engine etc. If it's just the parts you see and sit in, body swap. If it's the look, just paint the new truck the same. I like my vehicles but I haven't found a magic that occurs between my butt and the seat.
    Op has sentimental attachment to this one though. For that I'd leave it as is personally.
    cgunn1800[OP] likes this.
  6. Jan 1, 2018 at 12:27 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    It's really not as bad as you make it seem - I'm doing my truck with manual hubs and it's pretty straightforward.
    Remove the 2WD drivetrain, and add the 4WD one. If you can remove a transmission you can do this. It's ALL bolt on bolt off and if you run Manual Hubs there's no electrical or vacuum involved. All purely mechanical. You can do it for WAY cheaper than it is to buy a truck already 4WD. The parts can cost less than $2k. I've seen people do it for $1k. I just paid on the higher end of the spectrum because I bought new manual hubs and seals from Toyota for mostly all of the front end. Most people don't even bother to replace them, I just did for preventative maintenance purposes.
    rmepilot, frenchee and El Taco Diablo like this.
  7. Jan 1, 2018 at 5:36 PM
    kmac1701
    kmac1701 Well-Known Member
    Kevin
    Boston
    1998 Tan Tacoma PreRunner Ext Cab v6 3.4L
    How did you go about collecting parts if you don't mind me asking?
  8. Jan 1, 2018 at 6:08 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Research. Research. Research. I can't stress this enough you need to read through all the threads on here.
    I Googled "Toyota scrapers <insert your city here>" into Google. That turned up scrapers who like to charge tons of money for their parts at premium because they specialize. I ended up using car-part.com, the 1st Gen Marketplace, Craigslist, and some users on here. I had a spreadsheet and put down the cheapest prices with their mileage and location.
    I ended up driving to a yard in Reno who sold me a complete A340F with transfer case for about $450.
    Post some ads on here, look around, it's not that bad. Feel free to ask me any questions.
    rmepilot likes this.
  9. Jan 1, 2018 at 6:21 PM
    Jon G
    Jon G Hoarding Tacomas one at a time,
    Jon
    St John's Newfoundland Canada
    02, 04 & 07 Tacoma
    Magnaflow 2.5 Catback Exhaust K&N filter
    Quick question
    I can get a 2wd 2003 v6 crew cab preruner that has trans problems has had the frame recall.
    I own a 2004 xtra cab v6 Auto 4x4 parts truck (bad frame)
    This is not as easy as bolt on ?
    I think the frames are different but not realy sure
    Any thoughts ?
  10. Jan 1, 2018 at 7:24 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Make sure the donor truck uses Toyota's ETCS-I electronic throttle system. Select 2003 trucks had them and all 2004 trucks did.
  11. Jan 1, 2018 at 9:38 PM
    tacotime1
    tacotime1 Well-Known Member
    A 4x4 conversion, even using later model electrical components that I swapped in. Is still easier than a full body swap and I’ve done both lol
  12. Jan 3, 2018 at 12:44 PM
    snotaco
    snotaco Well-Known Member
    Lewiston, Idaho
    2003 prerunner tacoma
    2003 tacoma double cab, prerunner, 4wd conversion, 5 speed conversion, dual cases with inchworm clockable adapter, toytec ultimate coil overs, trd supercharger with urd 7th injector, 37 inch mastercraft mxt's, arb front locker
    i was able to do mine for around 500 dollars and half a days worth of work with some friends
    frenchee likes this.
  13. Jan 3, 2018 at 12:49 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    $500? Where did you get a deal like that?
    tacotime1 likes this.
  14. Jan 3, 2018 at 12:59 PM
    snotaco
    Lewiston, Idaho
    found a guy that let me cut the frame from the firewall forward on a tacoma he was parting, got a used trans for free, and then bought a transfercase
    SafetyDang and Dalandser like this.
  15. Jan 3, 2018 at 1:01 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Wow. Manual Hubs or ADD? You have an '03 too so I believe you have the ETCS-i electronic throttle.
  16. Jan 3, 2018 at 2:16 PM
    snotaco
    Lewiston, Idaho
    manual hubs and j shift case. ive since 5 speed swapped and put dual cases in it
    Dalandser likes this.
  17. Jan 3, 2018 at 2:21 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Same clip had manual hubs on it?
  18. Jan 3, 2018 at 2:25 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
  19. Jan 3, 2018 at 2:34 PM
    snotaco
    Lewiston, Idaho
    yea it was off a 96 4 cylinder, 5 speed, single cab tacoma that had been rolled
  20. Jan 3, 2018 at 2:36 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    You have a 4 cyl or v6? I thought 03/04 had electronic throttles.
