Rusty Radiator Flushed Now Overheating
Discussion in '1st Gen. Tacomas (1995-2004)' started by xaviersevenity, Oct 13, 2014.
  1. Oct 13, 2014 at 5:49 PM
    xaviersevenity
    xaviersevenity [OP] Member
    Xavier
    Denver, CO
    I just bought a 2.7 1996 Tacoma 4X4. I am very novice in auto care. I noticed the other day how much rust was in the coolant reservoir tank, an absolutely incredible amount. :( I decided to do a flush. I drained it and used Prestone Flush and filled it to the top with water. I took it for a short drive to cycle it through, as the instructions mentioned. It ran rough. I returned and used a hose to clear flush and rust until water was clear. I have gradually put in and ran engine to get the full amount of coolant mixture in (2.2 gallons). Got about 1.5 gallons in and took it for a drive. The temp fluctuated a lot during the short trip and often drastically as if the water pump was coming on and then turning off. By the time I returned it got very hot and steam was coming out of the cap and it was leaking. Any ideas?
  2. Oct 13, 2014 at 6:01 PM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    Air trapped somewhere in the cooling system.
  3. Oct 13, 2014 at 6:08 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    pull the thermostat to release the air pocket then refill.
    trapped air can be a pain if you completely drain the system so always remember to pull the thermostat to "burp" out the air pocket
  4. Oct 13, 2014 at 6:14 PM
    xaviersevenity
    Xavier
    Denver, CO
    Thank you both for the quick responses. Where is the Thermostat? Sorry if that is a stupid question. Should I run the truck with the cap off until there are no more bubbles? I saw that in a video earlier. Thank you for your help.
  5. Oct 13, 2014 at 6:25 PM
    keakar
    karl
    louisiana
    here you go: http://www.youtube.com/watch?v=aZEYAkdyymg
    wouldn't hurt to just put in a new thermostat while you are at it in case the old one is bad
    if youi notice there is a little doo-dad (technical term) on the thermostats flat part (time stamp 1:22) where its supposed to allow air to bleed past and prevent trapped air but if there was a bunch of junk in the system this was probably blocked on yours and the reason you had trapped air issues.
    also, its not mentioned in the video but this air bleed hole should be mounted at the top naturally so it can do its thing correctly
  6. Oct 13, 2014 at 6:30 PM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    Good info above.
    Not trying to convulute the issue but, It may be easier to remove the radiator cap and start the truck. When the thermostat opens and the truck reaches operating temp the fluid will drop.
    At that point add fluid straight to the radiator until full. Cap and top of res.
    GL.
  7. Oct 14, 2014 at 12:41 AM
    xaviersevenity
    Xavier
    Denver, CO
    Will pulling the thermostat off and putting it back on "burp" it enough that it could fix the over heating? I have ran the truck with the cap off while filling the coolant. Almost have the full 2.2 gallons in. I haven't ran it on the road since to see how the temp does but I will in the morning.
  8. Oct 14, 2014 at 2:06 AM
    TacoMitch93
    TacoMitch93 Tasty Taco
    Mitch
    Nova Scotia, Canada eh
    09 Tacoma SR5
    Are you squeezing the rad hoses going to and from the block?
    Let it idle up to temp, have your heater on (full heat, full fan) and with the rad cap off squeeze the hoses. It doesn't hurt to bring up the idle while you're squeezing the hoses either, the faster the engine is turning the faster the waterpump is turning.
    However, as stated by keakar, if you had a bunch of gunk/rust/ deposits of any sort you should probably take the thermostat out and make sure there isn't anything behind it. Thermostats aren't very "free flowing". What I mean is its a valve and it will restrict the flow, so any material that passes through the block freely might not pass through the thermostat.
    I don't believe they're very expensive either, might as well replace it while you're in there. You should get a new gasket with a new thermostat so saves you from potential leaks, if you were going to reuse the old one!
  9. Oct 14, 2014 at 2:26 AM
    Terminal4
    Terminal4 Well-Known Member
    South of the Sierras
    2022 DCLB 4WD
    Accutuned Fox suspension, Wildpeaks AT4, Batzmaru
    Welcome and congrats on a great purchase. All the above feedback is great. But, you are just covering up the symptoms. Rust comes from an old radiator. Do it right and purchase a new radiator, prediluted red coolant (I always purchase this from the dealer) and thermostat. Not that expensive and pretty simple to replace, just time consuming. The thermostat is underneath the housing which is connected to the lower hose. There are pdf files stickied on here with repair manuals. Or just buy a chilton/haynes, its a wise investment.
  10. Oct 14, 2014 at 5:48 AM
    TacoMitch93
    Mitch
    09 Tacoma SR5
    There is long life and super long life. Ones darker.
  11. Oct 14, 2014 at 11:18 AM
    xaviersevenity
    Xavier
    Denver, CO
    bought a thermostat and gasket. About to get to it. Not sure if I mentioned this before but the reservoir tank filled up all the way to the top and hasn't gone down. I only put in 2 gallons, just shy of the 2.2 specification. Not sure if that says anything new.
  12. Oct 14, 2014 at 1:11 PM
    xaviersevenity
    Xavier
    Denver, CO
    Upon taking the old Therm out lots of old coolant came from behind it. Does that mean anything?
  13. Oct 14, 2014 at 3:47 PM
    toadtoad
    toadtoad New Member
    oregon
    lookibg to buy
    Are you sure it's rust? Are you aware that the factory coolant is reddish in color? Just checking the basics. Don't want you replacing anything the does not need to be replaced.
  14. Oct 14, 2014 at 4:12 PM
    xaviersevenity
    Xavier
    Denver, CO
    There were chunks and sediments of rust all through it. The reservoir was caked in rust. I replaced the therm and took it for a drive. The temp maintained very well and the truck ran well. However, the res was bubbling when I got back. It still hasn't taken the full 2 ish gallons.
  15. Oct 14, 2014 at 4:24 PM
    FATPUBUS
    FATPUBUS Well-Known Member
    Moulton, Texas
    13 Tx Edition
    Run the heater as well when you change it out so it circulates thru the system
  16. Oct 15, 2014 at 2:25 PM
    xaviersevenity
    Xavier
    Denver, CO
    The temp is maintaining continually but now the coolant is boiling in the reservoir tank. I found a possibly fantastic shop to take it to so I am thinking that is what I will do.
  17. Oct 15, 2014 at 2:59 PM
    keakar
    karl
    louisiana
    that's just the trapped air still escaping, (I assume you mean bubbling and not really boiling water) it will suck in water to replace the air as it cools so keep a close eye on the overflow so it stays filled unil it no longer bubbles then recheck your radiator level and after that your back to normal.
    sounds like you got most of it out, but you had a lot of crud in there and im worried you didn't clean it all out which is why your not getting the right amount back in (its still full of sediments) if you still have sediments in there it could and likely will plug up your heater core and radiator in the future.
    if it were me I would disconnect the radiator hoses remove the thermostat and run a hose under pressure through the engine block and heater core in both directions until you see nothing but clean water then do the same for the radiator to get any crud that went in there out and then finally reconnect and refill with antifreeze. think of your block as a dirty storm drain and you need to flush the buildup off the bottom of the pipe, it just takes time and patience (and getting your feet wet lol) so do your best to get it all out.
    you have already done most of the work so no need to pay a mechanic to do a flush when you can and will do a better job yourself. when they do flushes they do a quicky flush and that's it they don't make sure to take the time to fully clear out everything. a trained monkey could do it so don't pay someone to do a job you will do better.
    also when you are done remove the catch jug and clean it because the radiator sucks up water from there when its needed as it cools down so it needs to be clean in there.
  18. Oct 15, 2014 at 3:04 PM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    Don't complete fill the expansion tank. Its there to catch the coolant when it gets hot and expands.
  19. Oct 15, 2014 at 3:09 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If you had that much rust & crappola inside..... you might have a blockage somewhere. Debris & lose crap clogging up the lines - and perhaps in the block itself. The fluid can't flow freely like it should.
    When was the last time the water pump was changed? If the water pump is going bad (especially the bearings), it can't pump the fluids as good / and with enough pressure / to force out any blockages.
    Just something to think about....
  20. Oct 15, 2014 at 7:15 PM
    keakar
    karl
    louisiana
    with that much crap in it its probably got worn seals in it anyway so being you had thermostat problems and found a lot of junk its worth the peace of mind and a very good idea to replace the water pump now before it goes out in 6-9 months from now, the water pump blades may also be worn from all that debris it had to push through it
