Rusted spare tire mechanism
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OkieTom, Feb 1, 2024.
  1. Feb 1, 2024 at 3:52 AM
    OkieTom
    OkieTom [OP] Member
    White 2020 SR5
    I was prepping to do an undercarriage wash yesterday on my 'new to me' 2020 SR5. When I tried to lower the spare it wouldn't budge until I really put some oomph into it.
    After I got the spare off and to the side I crawled under and discovered the lowering mechanism was heavily rusted.
    After spraying liberally with Corrosion-X and then applying machine oil it seems good as new.
    One more thing to add to my spring and fall check list I guess.
    tom
  2. Feb 1, 2024 at 4:04 AM
    Tac2021
    Tac2021 Well-Known Member
    Phil
    2021 SR5 Drk Grey Met Dbl cab 4 x 4
    none yet
    Yes these spare tire setups are always prone to rust, up in the Northeast here I bet 99% of any truck brand don’t think about it until they have a flat. Same thing happened with my 2004 Colorado. Do yourself a favor, every summer take the spare down, check tire for pressure and rot. Clean and spray tire rim and mechanism with wool wax or other type of rust preventive.
    Good luck.
  3. Feb 1, 2024 at 4:17 AM
    OkieTom
    OkieTom [OP] Member
    White 2020 SR5
    Yep. Added to my 'things to do' list. I'm a firm believer in 'an ounce of prevention'...
  4. Feb 1, 2024 at 4:40 AM
    Ryeguy
    Ryeguy Well-Known Member
    43* North
    2021 TRD Off Road 4X4 Blackout
    OEM Bed Extension, Bed Mat, Lomax Bed Cover, Auto lock tailgate (OEM)
    FWIW, I lower my spare tire when I do my annual early fall frame oiling.
    Having the spare out of the way gives me better access to the frame, plus I get to oil the mechanism.
    The other “trick” is to make sure the tire inflating valve is pointed down when you raise the spare. This way to can more easily check that it is at the proper pressure.
  5. Feb 1, 2024 at 5:07 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Yup. It's called "Maintenance." You could add 'Lube the hinges on the gas filler door.' Perhaps the door & hood hinges as well.
    faawrenchbndr likes this.
  6. Feb 1, 2024 at 5:09 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I don't live anywhere near a "salt state", but I still need to excercise that spare tire mechanism occasionally. Thanks for the reminder OP.
  7. Feb 1, 2024 at 5:18 AM
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    Same here. And wash the undercarriage before oiling without the spare in place. And here is another trick to make checking and filling the spare tire. Keeps the stem up and run the tube down through the rim. Worth the $7 especially once you are in your 60's, just saying...
    Tire Valve Extensions, 8.25 Inch Flexible Schrader Tire Valve Stem Extension with 90 Degree Extension
  8. Feb 1, 2024 at 5:18 AM
    OkieTom
    OkieTom [OP] Member
    White 2020 SR5
    Starting a list. I actually like doing preventive maintenance.
  9. Feb 1, 2024 at 10:01 AM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    Lowering the spare once a year is also a good reminder of how to do it. I add an extra 10 pounds to the spare so if it loses some over time, there will still be enough.
    I used to own a 1970 VW that used the air pressure in the spare to run the windshield washer but you had to overfill it because it had a cutout at normal running pressure so you didn't deflate your spare by washing your windows.
    Tac2021 and Crooked Beat like this.
  10. Feb 1, 2024 at 10:07 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I try to check mine with every tire rotation/oil change. That usually works out to somewhere between 2-3x annually.
  11. Feb 1, 2024 at 10:47 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    more reason to do a yearly spray on undercoating, they soaked the heck out of mine, along with everything else underside.
    Also, I do drop mine occasionally when it is on the lift, and spray further.
    skidooboy likes this.
