Rusted out muffler replacement help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tiki Tacoma, Jan 29, 2015.
  1. Jan 29, 2015 at 6:52 PM
    Tiki Tacoma
    Tiki Tacoma [OP] Well-Known Member
    CT
    03 dbl cab trd
    hello everyone, I recently noticed my muffler tailpipe connection was rotting out and was hoping to wait until spring to fix it, but after this weeks snowstorm i maybe did one two many donuts and now my truck sounds like a shitty civic, and i can only turn the radio up so loud...So im wondering how to go about fixing this. can i sawzall the old muffler off and clamp on a new one? should i get a new tailpipe too? I was going to go with stock stuff but if anyone wants to convince me otherwise Im all ears. gracias amigos
  2. Jan 29, 2015 at 10:11 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    why not just pay a muffler shop
    and have them weld on an oem muffler ?
    It might possible to sleeve it...
    but I wouldn't.
    the factory muffler cost is ridiculous IMO
    and has no real advantage unless it is stainless.
    Stainless will endure more corrosion and possibly
    survive longer... But will be more costly for sure.
    Galvanized/coated mufflers will endure corrosion acceptably
    tho' not likely survive the rest of your lifetime.
    If you want a little sound out the tail pipe...
    a Flowmaster does it.
    if you want it to run a little quieter...
    a Masterflow would be better.
    If you don't care...
    just have the muffler shop weld up the cheapest oem
    muffler they have in stock.
    should be able to get a shop
    to weld one up for less then $ 100
    I'd think
  3. Jan 30, 2015 at 4:04 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Bosal makes a factory bolt on replacement. I got mine for 120 I think. Unbolt the existing pipe and muffler assembly and bolt on the new one. I think I got it on autoplicity. Seems to be made to exact OEM specs, it looks OEM and it's quiet as hell
  4. Feb 7, 2015 at 7:49 AM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    Magnaflow cat back exhaust systems are stainless.
  5. Feb 7, 2015 at 9:03 AM
    Exhaust
    Exhaust Well-Known Member
    Erik
    Wharton State Forest
    02 DC TRD
    Extended breather, Grey Wire mod, Tundra brakes, Rockford-Fosgate sound, General Spring HDs, 5100s + 880s, Heated Seats, TRD Supercharger, 2.1 Pulley, URD 7th Kit
    My flowmaster 40 has a bad drone after 2500 rpm, I wouldn't recommend it. However, it does keep me below that 2500 point so if you're looking for fuel economy....
  6. Feb 7, 2015 at 2:29 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
  7. Feb 8, 2015 at 4:08 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Flowmaster 50 if you want a good tone and low sound levels.
  8. Aug 17, 2020 at 10:29 AM
    DCrider
    DCrider New Member
    I know its an old thread but adding for comparison was just quoted at a DC area small muffler shop $400 for relacement with a Walker "OEM", seems pricey to me even for DC, guess Midas or a chain shop would be even more $. Just ordered from Rockauto for $116 with 3-day shipping, I'll save the $280 and install myself.
