Rusted bed bolt
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kozy, Jan 17, 2023.
  1. Jan 17, 2023 at 8:20 PM
    kozy
    kozy [OP] Well-Known Member
    Tim
    Arizona
    2006 Access Cab 4x4/6MT
    Looking for ideas on getting a very rusted bed bolt out. The t55 head is completely ruined by rust (bit just slips with any amount of torque applied).
    I've read through the other similar posts on TW and tried everything. Cutoff wheel to cut square edges and using a large pipe wrench to attempt to remove it. Grind the bolt head into a hex shape and pounding a socket onto it.
    The bolt will move a tiny bit (1/16th inch maybe) but won't break free. Has been soaked multiple times in PB blaster. Torch didn't help. No easy access to a welder to weld a nut on. I'm about ready to grind the bolt head off and try to drill it out. (any bit recommendations for that?)
    Any other genius ideas out there for this before I go caveman on this?
    Not_Dustin_Hoffman and Robnik like this.
  2. Jan 18, 2023 at 7:19 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    drilling out would be a pain as the bolts so long, Id find a welder first. Just my opinion.
  3. Jan 18, 2023 at 7:30 AM
    Not_Dustin_Hoffman
    Not_Dustin_Hoffman Member
    Spokane, WA
    2008 TRD Sport DCLB Super White
    I went through this same thing. Ended up taking it to a mechanic. The bolt snapped and they welded a nut to the bottom and pulled it through from underneath the bed.
    When you replace it, make sure to use plenty of anti-seize.
    Robnik likes this.
  4. Jan 18, 2023 at 7:39 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Yeah those bolts are super long. Heat and penetrating oil from above probably wont help you. Depending on which bolt is stuck you can get access from under the truck. Lots of PB and some heat on the actual threads that go through the frame should help
  5. Jan 18, 2023 at 9:41 AM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    Really clamp it down hard, I mean hard. Try to replace with a stainless steel bolt if possible. Good luck with your mission. :)
    Not_Dustin_Hoffman and HondaGM like this.
  6. Jan 18, 2023 at 10:10 AM
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    Bad memories ... I'd cut the top off and start drilling it out. The things suck. I hadn't ever tried to loosen those bolts (bought in November 2004). The first one was completely rusted in - I basically cut this flush and continued to drill out pieces. I just put a different size bolt in the remaining hole and secured it down with a nut.
    I was able to get this one out and re-tap it and use a new/replacement bolt to secure it.
  7. Jan 18, 2023 at 1:13 PM
    jwarr
    jwarr Well-Known Member
    grind the head off, remove the bed, cut it off flush, then drill it out
    dk_crew likes this.
  8. Jan 18, 2023 at 1:19 PM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    Yep, but be careful under there with a torch... Gas tank, fuel lines, brake lines, etc.
    Really, you're probably going to need a nut welded on the bolt after you cut the head iff to remove the bed.
  9. Jan 18, 2023 at 4:56 PM
    Scorchedtaco
    Scorchedtaco Well-Known Member
    AZ
    2012 ac trd 4x4 sc , 2012 sequoia 4x4
    You could also use a left hand threaded bolt extractor , you would need to drill into the bolt with a tungsten drill bit to get it started though . Prob be cheaper & less hassle to just have someone weld a nut or socket on it though….
  10. Jan 18, 2023 at 5:24 PM
    TacoMoose
    TacoMoose Well-Known Member
    2017 Tacoma OR
    Heat it from the bottom until it's glowing, weld a nut on top and take it out. Dont waste your time heating it from the top. If you're scared to heat it from the bottom, use a air hammer to help it break loose. It would help if you had 2 hands. One person on the bottom with the air hammer and one on top putting tension on the welded nut. But it depends how rusty it is, a picture would give us a good idea of how fucked you are
    MSgt O and SR-71A like this.
