Rusted 5 speed clutch hydraulic line
Discussion in '2nd Gen. Tacomas (2005-2015)' started by takomajake, Jun 15, 2019.
  1. Jun 15, 2019 at 4:55 PM
    takomajake
    takomajake [OP] Well-Known Member
    Jake
    2021 DCLB SR5
    Sorry, I feel I have searched thoroughly for this topic. My 2007 2.7 5 speed clutch line/hose is very rusted and I'd like to fix it in my driveway vs on the side of the road. Anyone have a toyota part number for the hard line? Or anyone have this problem before? Or learn how to bend my own brake line and hook it up?
    So with these pics I'm looking for the hard line coming out of the firewall and goes down to the slave cylinder.
  2. Jun 15, 2019 at 6:55 PM
    Taco'09
    Taco'09 Well-Known Member
    OP, I took a quick peek at the parts manual and there are a number of options depending on production date, with or without VSC, etc. and you have not provided enough info to continue. If you like PM me with your VIN, production month and year and I shall try a second attempt.
    HP11 and Taco505 like this.
  3. Jun 15, 2019 at 10:24 PM
    jkuniverse
    jkuniverse Well-Known Member
    Arlington TX
    2013 Limited DCSB 4x4 Super White
    It’s not clear how bad the rust is in the photos. It looks like some dried up thick paint or undercoating flaking off in the 2nd photo. I would use a wire brush to clean it up a little bit, and examine how the brake line rust is. It might be just fine. I would then hit it with some Rust-Oleum, and call it a day.
  4. Jun 16, 2019 at 4:46 AM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    Dood... that "thick paint" flaking off in the 2nd pic is commonly referred to as "steel". If it were a brake line, it probably would've popped by now, but being that it's the clutch and doesn't hold nearly the pressure, it looks like it hasn't yet. Clean up the flaky stuff, and what's left will be DOT 3.
    Depending on price and/or availability from the dealer, I'd probably bend up my own. Measure the old one with a string, you can get lines with the right M10 fittings, pre-flared, in coated or probably even copper-nickel. My usual method is to get it to where I can route the new line under/over/behind/whatever it needs to do, get it in & tightened on whichever end is going to be more difficult, then work my way to the other end doing the final bends it needs.
    takomajake[OP] and JdevTac like this.
  5. Jun 16, 2019 at 5:15 AM
    takomajake
    Jake
    2021 DCLB SR5
    I sort of like the bend my own brake line idea. Can't be that hard with the right tools right?
  6. Jun 16, 2019 at 6:43 AM
    fb40dash5
    11 V6 AC 4x4
    Copper-nickel bends stupid easy, and while it'll turn green like any other copper, it won't rust.
    I have one of the little 2-handle tubing benders, but honestly I didn't even use it that much, mostly just for tight bends to keep from kinking the line. Just get one end in solid and work towards the next mounting point until you get to the other end.
    But, I don't know what price & availability from Toyota are... if it's like $20 and readily available, just buying it might be the ticket. The usual downside with pre-bent lines is usually getting them in place, but this one doesn't look near as difficult as long brake lines can be.
  7. Jun 16, 2019 at 7:04 AM
    Tacoma Nick
    Tacoma Nick Active Member
    Nick
    Michigan
    2008 Indigo Ink Pearl Regular Cab 2TR auto 2WD
    All new under the floor, factory frame swap. Bucket seat swap. Bilstein 4600 shocks and X Runner rear swaybar. 4:10 DIfferential. 225/60/17 on Sienna 5 spoke alloy wheels. After market black headlights. OE replica fog lights. OE Intermittent wipers plug and play. Leather steering wheel (OE eBay) that came with a cruise stalk, I bought the $38 OE wire to plug into the clock spring, plug and play.
    A bend it yourself brake line (with fittings on each end) that you can get any almost any auto-parts store will work just fine.The thread pitch will be the same as the brake line (and clutch) that are on your (or any) Tacoma. That really rusty female union joint could be replaced with something from the auto-parts store also though it may not be exact.
    takomajake[OP] likes this.
  8. Jun 16, 2019 at 2:23 PM
    takomajake
    Jake
    2021 DCLB SR5
    Awesome! Thanks for the answers guys! Excited to learn a new skill and buy some new tools. I'll follow up with my success or failures with this project when I have time to get to it.
  9. Jul 15, 2019 at 10:39 AM
    takomajake
    Jake
    2021 DCLB SR5
    Found the part number from the clutch master cylinder to the rubber hose. So hopefully this helps someone in the future.
    Toyota part number
    31481-04080
    $14 online or I got mine from my nearest Toyota dealer for $16
