Rust proofing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Yeahbro31, Mar 29, 2018.
  1. Mar 29, 2018 at 8:28 PM
    Yeahbro31
    Yeahbro31 [OP] Member
    18 TRD Off Road, DCSB
    Looking for input or experience with a rust proofing system. Live in Buffalo NY, where it seems that the towns compete over who can lay down more road salt in a given year. Dealer pushed Ziebart for $650, which I've seen first hand can end up holding moisture and causing more issues. Thinking oil based, but there are a lot of products out there. Hitting up the car wash religiously now that the white stuff is done for (hopefully) and seriously considering applying rust proofer in the fall. Thanks for your $.02.
  2. Mar 29, 2018 at 8:36 PM
    Gunner123
    Gunner123 Well-Known Member
    2018 TRD OR
    Im interested too I may be moving to buffalo in a year or so!
    Yeahbro31[OP] likes this.
  3. Mar 29, 2018 at 8:47 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    I’m a believer in the Krown coating, which is available in your area. It’s ~$150/yr to get it reapplied, and they warranty everything it touches. They drill little holes (and then plug them) in all your panels and spray / mist it into everything so your truck can’t rust from the inside out. I figure I’m planning to keep the truck for as long as possible. Over say, 10yrs, you’re definitely gonna see rust in a salted-road area, so a $1500 investment is well worth it.
    Lot of of guys on here like Fluid Film too, which is a similar idea but just on the underbody and you apply it yourself.
    LoMa, Jcyr, Clear7 and 1 other person like this.
  4. Mar 29, 2018 at 8:49 PM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
  5. Mar 29, 2018 at 8:49 PM
    Yeahbro31
    Not a bad place to live. Honestly the road salt will eat cars alive within 6 years or so depending on what it is. If you wash them every week, it'll keep it from getting ugly, but wrenching around here can be an unbelievable headache on older vehicles if they've been allowed to rust
    doublethebass likes this.
  6. Mar 29, 2018 at 9:55 PM
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    Krown or fluid film. I would go ahead and apply it now, then again in the fall. This way you will have a good layer of protection when salt season begins. Some will wear off from use, so it’s good to reapply at least twice a year in your location.
    LoMa, shakerhood and Clear7 like this.
  7. Mar 30, 2018 at 4:36 AM
    Clear7
    Clear7 Well-Known Member
    Ontario
    2017 SR5 2.7L - tried tested & proven
    Krown or Fluid film are proven. The "one time" paste stuff is convenient, but doesn't stand up over time. The black rubberized coating is the worst, traps moisture, and inevitably chips off leaving it completely exposed.
    Nothing is better than a yearly applied oil application. For the first few years, I second Riding Dirty's statement.. apply it twice a year.. once in the early summer, and again in the fall. Wait for warm days, and no rain in the forecast.
    If you're willing to, jack the truck up, grab a few cans of Fluid Film, and go over it even after the shop did it. (They can miss a few spots.)
    Here's a previous post:
    [QUOTE="Clear7" I have an 18 year old jeep (which are brutal for rust), and it still has the original paint on most of the frame. It's been driven every winter where salt is plastered on the road. I oil sprayed it from day one. Always in the heat of the summer every year. No power washing. The oil and dirt sludge that gets built up keeps the oil against the frame at all times, so the salt and oxygen can't do their thing.
    It's not going to see any more winters, so I just started to clean it up. Look at the inside of the shock mount. Half has the oil crud still on it, while the other half I cleaned off has the original paint underneath. Just the front half of the frame has surface rust. Also note the side of the grill.. zero rust.
    [/QUOTE]
    Riding Dirty and Sprouty115 like this.
  8. Mar 30, 2018 at 4:40 AM
    Bowhuntercoop
    Bowhuntercoop Well-Known Member
    2006 5.9 Cummins , 2018 4Runner, 2025 gx550
    Move outta the north, problem solved. Seriously though yeary bust all the rust off, paint, then fluid film is your best bet.
  9. Mar 30, 2018 at 5:00 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    I'm north of you in the salt capital of North America. Where there's been numerous lawsuits against the city for over salting, Toronto.
    Krown is a good option I've always done it to every car I own although the one I've dealt with was a bit disappointed with this season so might try a different one next season. Fluid film is another great option.
    Don't waste your money on the shit the dealers say.
    KBOX, Yeahbro31[OP] and Riding Dirty like this.
  10. Mar 30, 2018 at 5:41 AM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    @Yeahbro31
    Are you a "do it yourself" type?
    I was asking a similar question and was told by a few reliable sources that Fluid Film was a good option.
    First time I used Fluid Film, I purchased aerosol cans. I thought it was worth the effort, so I purchased the pro gun and gallon can from Kellsport.
    I second the "twice a year", and if you time it right, you can apply Fluid Film during oil change/ tire rotation, since it is better with the tires and (front) skidplate removed.
    This thread is the best I have found at TW relating to this subject:
    https://www.tacomaworld.com/threads/how-to-fluid-film-your-3rd-gen.455241/#post-13412819
    And welcome to TW.
    shakerhood and Yeahbro31[OP] like this.
  11. Mar 30, 2018 at 5:42 AM
    AFMurse2014
    AFMurse2014 Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    Move to Arizona. Best rust proofing I ever did
    Bwcall likes this.
  12. Mar 30, 2018 at 6:27 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    When I lived in pa I used to take used motor oil and spray inside the doors and cut with kerosene and spray the entire undercarriage and it would be good for years..
    Yeahbro31[QUOTED][OP] likes this.
  13. Mar 30, 2018 at 3:37 PM
    Yeahbro31
    Thanks for all the input! Thinking the Krown seems worth the money. One last thought...how's the mess aftewards? Are we talking rainbows in the driveway after it rains, or is it pretty adherent to the truck? Again, thanks for all the feedback!
    shakerhood likes this.
  14. Mar 30, 2018 at 3:41 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I sprayed my underside down with Cavity Wax last year and will definitely make it an annual thing, it is nice so far as it did not smell bad and it was not sticky after it cured.
    brohloff likes this.
  15. Mar 30, 2018 at 3:42 PM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    With Krown it drips pretty good for a day or so, and then that’s it
  16. Mar 30, 2018 at 3:42 PM
    Tacos in Gensokyo
    Tacos in Gensokyo Bohemian Archive in Japanese Red
    2017 SR 4cyl MT SSM
    Rokblokz Mudflaps, 2015 TRD Pro Suspension
    Not to hijack OP's thread, but does any of this work after the truck's been Ziebarted?
  17. Mar 30, 2018 at 5:36 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    I suggest that you DO NOT wait till fall....:eek:.....Do it this spring so it doesn't take hold....
    I'm a true believer for 30 yrs now of "Corrosion Free". I assume it's very much the same as Fluid Film and Krown....... There is NO dripping with it.....I get it every yr. at the original price (same price for life of truck)... About $140 CDN.
    I suspect Krown the FF would do as well........Don't wait to get something on it ASAP........
  18. Mar 30, 2018 at 6:05 PM
    Dank24
    Dank24 Well-Known Member
    3rd gen OF
    Fluid film
  19. Mar 30, 2018 at 6:18 PM
    Wallyt
    Wallyt Member
    2018 sport DCSB 6MT
    Been in the autobody business for 20 years and have tested many products I would go with krown, it works well but swells door seals and rubber pieces.
    Has a lifetime warranty against rust(from inside out) if you get it done every year.
  20. Mar 31, 2018 at 5:25 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Look into ACF-50 or Corrosion Block made by Lear Chemical.
    ACF-50 is more expensive but won't loosen bolt torques. It's used on planes and helicopters and by the military.
    You Fog/mist it on and it dries to a non-tacky finish. So no goo all over when you work on the underside.
    You don't need to "hose it on" and if you do it lightly or fog it, it does not drip.
    Lasts 2 years in areas not exposed to direct spray.
    Does not damage rubber, paint, seals, or electronics, in fact can be sprayed on your electrical connections to help prevent corrosion and prevent water intrusion.
    Just don't SOAK natural rubber parts in it.
    Can even coat your exhaust with it.
    Fog it in your engine bay....
    It does lubricate so keep it off your brakes!!! Can't describe it but the truck seemed "smoother" when I drove it afterwards.
    It does not break down in high heat like regular products do (why it works in the engine bay and on the exhaust).
    Best stuff out there.
    In the UK they use it on their motorcycles in the fall and then don't wash the bikes until spring and they look good as new.
    doublethebass and boynoyce like this.
