Rust Prevention / eastwood internal frame coating
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Teleholic, Jan 18, 2015.
  1. Jan 18, 2015 at 9:24 PM
    Teleholic
    Teleholic [OP] Well-Known Member
    2014 Baja tx
    I have a 2014 tacoma, and after seeing what the new one looks like, I decided to keep my 2nd gen for as long as possible. Which is why I want to prevent rust before it becomes a problem. I'm gonna do the inside of my frames with some Eastwood internal frame coating. I'm a little worried I might get it on parts that shouldn't get this stuff. Looking underneath, it looks as if there could be a lot of overspray going through holes I can't even see, on parts I don't want to be painted. Does this stuff dry instantly, or can it be wiped off while fresh?
    Also there are little rust spots on my frames weld points, they look like there getting bigger everytime I check them. Can you recommend a product that has little or no prep work, or a method to deal with rust, preferably rust proofing the whole frame? I've heard about fluid film, but people say it tends to make things dirty. I would use Por 15, but I live in an apartment with shared garages, so it's pretty difficult to sand and paint the whole thing.
    Anyways, I was thinking of useing a small dremel to sand off these spots, and spray it with some rust proof paint for now. Have no clue if this is a bad idea.
    Any help would be appreciated :)
    GQ7227 likes this.
  2. Jan 18, 2015 at 9:33 PM
    Artruck
    Artruck Well-Known Member
    Lawrence, KS
    '09 Super Basic
  3. Jan 19, 2015 at 9:30 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I've used Eastwood's internal frame coating on my last nonToyota truck. It's a paint and will run. For my '13, I chose Amsoil HD metal protector and used the flexible want that came with the Eastwood internal frame coating spray can. I wouldn't worry about the little rust spots on the welds. For rust to grow it needs exposure to air and water/humidity. Block them and it won't grow or at least have very, very slow growth. There's several choices to go with and everybody has a favorite. Whichever you choose is better than none...
    GQ7227 likes this.
  4. Jan 20, 2015 at 7:37 PM
    Teleholic
    2014 Baja tx
    Was a long read but worth it. Very confident with my decision now. Thanks
    Ya I am worried about paint dripping everywhere. So I'll probably go with amsoil or fluid film. Will spray it on everything and try to keep that stuff away from the exhaust. I hope the smell doesn't piss off my neighbors.
    GQ7227 likes this.
  5. Nov 19, 2019 at 7:43 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
  6. Nov 19, 2019 at 7:54 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    I used rust bullet on my 94 Toyota 4x4. That shit is excellent.
  7. Nov 20, 2019 at 9:26 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Holy thread revival batman! Uhhh, the OP hasn't been seen since 2015...
    GQ7227 likes this.
  8. Nov 20, 2019 at 9:27 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    it was the only relevant topic i could find in a search
    the 1st gen forum is very lacking in this topic i have found
    tired of always getting barked at to shut the F up
  9. Nov 21, 2019 at 4:59 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
  10. Nov 22, 2019 at 3:31 PM
    Crosis
    Dunedin Fl
  11. Sep 6, 2020 at 10:04 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    you were spot on about it running out of the existing frame holes if there was no rust to encapsulate which it dried instantly in a few spots i saw it deep under that had a surface crust
    here is a short video of what it looks like in the passenger rear area right behind the spring perch
    https://www.youtube.com/watch?v=P4-BV44fW2Y
    i used the green IFC first to see if there were any missed spots it did not creep into, which a couple are noticed and noted
    also dripped some on my arm and burned the skin sortof, i would rec a long sleeve shirt and DEFINITELY eye safety, fumes were choking as well so take precautions as you see fit
    Torspd likes this.
  12. Sep 6, 2020 at 4:58 PM
    Capespencer68
    Capespencer68 Well-Known Member
    Scott
    Massachusetts
    2021 DCSB AG Trail edition
    My 2014 has the same issues on the frame. Goes in October 30 for the dealer rust corrosion treatment on the inside of the frame only. I just bought 2 quarts of Eastwood’s Rust encapsulator Plus and cans of the pre-prep spray. Scrape/wire brush first then prep, then I’ll brush the entire frame. I’ll be finishing off with a coat of Woolwax as well.
