Rust Inside Frame
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ozark_RegCab, Jun 23, 2021.
  1. Jun 23, 2021 at 11:03 AM
    Ozark_RegCab
    Ozark_RegCab [OP] Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    I recently acquired a '98 single cab which appeared to have a clean frame; however, upon later inspection, I started noticing chips of rust when I stuck my finger inside the frame holes, especially the ones inside the rear wheels wells, similar to the ones seen in this older thread: https://www.tacomaworld.com/threads/rust-chips-inside-frame.478746/. I've been washing it out and spraying WD40, but there always seems to be new chips popping up every week. Despite all this, the frame still seems structurally solid. The truck is from Virginia/Maryland and it has the original frame.
    Basically I wanted to ask: is there anything that can/should be done about this? I've considered Corroseal or a similar product, but will that stop the internal delamination of the steel?
    Also, I know this is hard to say without looking at it, but are the rust flakes usually a sign the frame is about to fail, or is it generally not a sign of impending catastrophic failure?
    I'm asking since I don't want to spend more money on maintaining an old truck when it could be totaled in the next year due to a bad frame.
  2. Jun 23, 2021 at 11:16 AM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    You can start with the hammer test. Take a hammer and smack the frame above the leaf hangers. If your frame is bad you will hear more of a thunk sound then a ping.
    Also pictures of the frame can help.
    Soggywaffles66 and Abeyancer like this.
  3. Jun 23, 2021 at 11:44 AM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Thanks for the replies, I can take pics when I get home from work. Basically the outside of the frame is decent, with some spotty surface rust, but the inside has rust chips of varying sizes. Most of them look a lot the pics from the thread I linked to above.
  4. Jun 23, 2021 at 11:48 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    unfortunately, rusting from the inside out is what these frames love to do. Definitely do the hammer check method
  5. Jun 23, 2021 at 2:32 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Stop spraying WD40 inside frame.
    Get a Undercoating gun and 360° wand extension and spray Coroseal inside frame. After it dries spray Fluid Film or Wool Wax inside frame.
    Rinse undercarriage and coat with Fluid Film or Wool Wax in Spring and Fall.
    You can drill 5/8" holes in frame bottom at front and back to help wash out frame while on alternating inclines before treating inside frame.
  6. Jun 23, 2021 at 2:53 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Frame rust and lower balljoints are probably the 2 most commonly discussed topics on this forum.
    There is a plethora of information already on the site - just search around, you'll find tons of info and many many other people who've dealt with this.
    Do the hammer test. Then realize that the ONLY real solution is to remove all the existing rust from the inside. It's cancer, if you don't remove ALL of it, it will grow back, even if you dunk it in fluid film or some other coating.
    You need a grinder and a flap disk to actually remove rust. Unfortunately that's not really possible on the boxed frames without cutting them open, lol.
    A bandaid fix is safe-T-caps, or some other brand of frame plates. This will reinforce the areas that are rusty, but again, it's a bandaid fix and only delays how long until the frame fails.
    Or go to CA or AZ or UT and find a frame and swap them. THEN coat the frame fluid film to prevent new rust from appearing.
    TACOTU3 likes this.
  7. Jun 23, 2021 at 3:03 PM
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
  8. Jun 23, 2021 at 8:19 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    I have been reading the various threads on frame rust on this forum and elsewhere, but it's hard to gauge how concerned I should be, even with how much the topic has been covered. Below is a photo of the leaf spring area with one of the many flakes which can be found inside. As of now, there's no visible rot or holes. The hammer test just kinda resulted in a non-descript tapping sound; I guess more "thunky" than "pingy"? Seemed decently solid.. no visible holes or rot either..
    I do plan on looking into some of the remedies discussed above, but as far as I can tell, there's no way to get to the root of the problem at this point. Apparently the steel they used was faulty somehow in these early Tacos?
    In any case, I suppose everything rusts away eventually.. hopefully I have a ways to go before ending up on one of those frame fail compilations. I'd appreciate any further insights.
  9. Jun 24, 2021 at 11:30 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It all depends where you live Our Fair weather friends( Drier no Winter chemicals climate) would tend to tell you to scrap the truck or if you were thinking of buying it to run far away .
    Here in the Northeast that would be No big deal ! What sort of winter do you see lots of winter chemicals or very seldom?
    I can`t figure this out how this problem spanned so many years. Exposed long enough I have never seen Steel do anything quite like this Almost like the winter chemicals are leaching part of the steel but leaving a dead shell and nothing to weld to.
    In any case fall and spring attention to the frame are needed.
  10. Jun 24, 2021 at 12:38 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    I’m in northwest Arkansas now where winters are usually very mild. Very little salt on the roads. However, the truck lived most of it’s life in northern Virginia, so it must have seen road salt, but nothing like PA or western NY, where I’m from originally.
    I also thought it was odd how it was corroding; I guess I have the DANA Corp to thank for that?
    It’s a shame since the truck only has 163k and the 2.7 has good compression and runs like a champ.
  11. Jun 24, 2021 at 3:14 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    before applying any product inside the frame, you must remove the rust chips and chunks. No point in putting anything in there if it does not reach the frame itself.
    You could try to tape a piece of flexible pipe/tubing on the end of a shop vac tube and vaccum out the chips and chunks through the square holes along the frame rails
    Ozark_RegCab[OP] likes this.
  12. Jun 24, 2021 at 3:39 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Thanks for the tip; I hadn’t thought of that. I suppose I could also try to go in through the c-section and see how far I could get down the frame with the vacuum.
  13. Jun 24, 2021 at 3:47 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Is it necessary to spray fluid film after the corroseal? I live in Arkansas now and I’m not too worried about salt or chemicals getting inside the frame, although I do go down some muddy tracks sometimes. I pressure wash the inside regularly as well.
  14. Jun 24, 2021 at 4:45 PM
    Black DOG Lila
    Virginia
    Yes.
    How do you pressure wash inside the box frame sections?
  15. Jun 24, 2021 at 4:47 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    I just kind of aim it down the c section and spray it in some of the frame holes. Not ideal, but at least it gets some of the dirt and grime out.
  16. Jun 24, 2021 at 4:51 PM
    onakat
    Canada
    2000 indestructaco!
    no, you cannot go inside the boxed section through the C-channel section under the bed. It is closed off :(
    well, unless that section is rusted away, which is usually the first section to rust through on these frames...
    Anyway, the only access is through the square holes. Pushing the vaccuum tube in and out a few times on each hole should be enough to remove most of the rust chunks and chips
    Black DOG Lila likes this.
  17. Jun 24, 2021 at 5:08 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Gotcha, thanks. I guess I hadn’t looked too closely at the c-sections lol.
  18. Jun 24, 2021 at 5:19 PM
    Black DOG Lila
    Virginia
    Yeah, C channels end and are blocked at shock mount on passenger side and LSBPV on driver side. Those big round holes are a dead end but it's good to keep those clean and Fluid Filmed.
  19. Jun 24, 2021 at 5:23 PM
    Black DOG Lila
    Virginia
    A big part of the rust problem is the tiny drain holes on bottom of frame.
    They get clogged and hold water and road salt.
    That's why I drilled 5/8" drain holes.
  20. Jun 24, 2021 at 5:26 PM
    UtahTacoma02
    UtahTacoma02 Well-Known Member
    Dave
    SLC
    02 Tacoma Double cab TRD Limited
    ARB front bumper, Old Man Emu suspension, on board air compressor, on board hot water converter, cb radio, safari snorkel, warn 8K lb. winch, AP rock slidders/rear bumper, gray wire mod
    My plan is to get a drain snake (at Home Depot) that hooks to a drill and attach a small chain on the end and feed it into the frame and let it rattle all the flaky rust. Then drill slightly larger drain holes on the underside of the frame to allow for better drainage and spray out the frame with high pressure water. Let the inside of the frame dry for a week or so. Then coat the inside with Eastwood chassie paint made for the inside frame rails, you can Youtube it. They have spray cans with a thin hose that connects to the spray tip allowing you to access the inside of the frame. Then I would fluid film it once the paint has had some good time to cure. Hope that helps some. image_16255.jpg
