russell speed bleaders
Discussion in '1st Gen. Tacomas (1995-2004)' started by toastyjosh, Nov 15, 2014.
  1. Nov 15, 2014 at 9:59 AM
    toastyjosh
    toastyjosh [OP] Well-Known Member
    northern New mexico
    95 dark green taco(sold), 2005 chevy 2500HD duramax
  2. Nov 15, 2014 at 10:55 AM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    They work as they are designed to. They inhibit air to enter back into the brake system while doing a brake bleed job.
  3. Nov 15, 2014 at 12:53 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    they have those as cheap as $8 if you google search other websites
    I prefer to just stick a hose in a bottle so the end is below the level of some old brake fluid I remove from the master cylinder to do the same thing without needing to buy anything. you can also fold the tubing over to kink it and hold it there with a rubber band so the pressure pushes its way out but air cant be sucked back in. no matter how you bleed your brakes you will still need to use a hose and catch bottle on it anyway unless you plan to just let brake fluid leak out everywhere so I don't see where this is something you should make a point to go out and buy for your truck but it is one of those nice things to have.
    If my bleeders needed replacing anyway then I would definitely by the check valve bleeders but that would be the only reason.
    by the way, if anyone wants these for the Tacoma 2wd trucks then you want to use the Russell Speed Bleeder #639570
    and this is the application number list to find the right one for any vehicle http://russellperformance.com/mc/speed-bleeders/truck-suv.shtml
  4. Nov 15, 2014 at 6:35 PM
    toastyjosh
    northern New mexico
    Thanks
  5. Nov 16, 2014 at 6:24 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Gave them a try on another rig. 3 out of the 8 I bought leaked and let air back into the system. Gave the other 4 away,,not worth my time.
    Grab yourself a pressure bleeder kit.
  6. Nov 16, 2014 at 9:34 AM
    keakar
    karl
    louisiana
    well that took care of my wondering if they worked as described, now I know not to bother trying them
