Running while re fueling
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MTLTaco, Feb 9, 2011.
  1. Feb 9, 2011 at 4:45 PM
    MTLTaco
    MTLTaco [OP] Well-Known Member
    Montreal
    09 Double Cab TRD
    Is this bad?
  2. Feb 9, 2011 at 4:47 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Ummmm yes. That's why the gas stations have signs telling you to shut your vehicle off.
  3. Feb 9, 2011 at 4:48 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Yup would not do... Have good chance to go BOOOOM... not really boom but could catch fire
  4. Feb 9, 2011 at 4:49 PM
    NicksRig
    NicksRig Well-Known Member
    Kenora, Ontario
    07 Tacoma DC TRD Sport
    Blacked out Skid plate, block heater, bug deflector, blacked out headlights, tinted fronts, OME 3" lift, Toytec AAL, Revenge-Fab Sliders, K&N Air Filter
    Unless you have a diesel.
  5. Feb 9, 2011 at 4:50 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    I don't do it, but i don't see how it can be bad, we drive in an out of the gas station, through it, start the vehicle at the pump, and there's no issues.
    all your doing is putting gas down a tube into a big tank...
  6. Feb 9, 2011 at 4:53 PM
    07TaCo07
    07TaCo07 Well-Known Member
    oregon
    07 double cab 6" lift
    6" fab tech lift, 35" toyo m/t, 17" teflon wheels
    My ignition switch went out on my bmw and had to refuel a few times while running and no probs
  7. Feb 9, 2011 at 4:54 PM
    judd94
    judd94 Well-Known Member
    Ponchatoula, LA
    17 4Runner TRD Off Road Premium
    Mods in Progress
    the big deal is that static is being created as the fuel flows. this static can build at the nozzle. you arent grounded because of rubber shoes. so you touch the nozzle it sparks and you have a show. as long as you hold onto the nozzle or keep touching the truck your ok.
    as far as the fuel system goes, if your cap isn't secure properly it'll give you a check eng light. i'm assuming this would give you a light. but i dont know how long the truck has to be running and the cap loose.
  8. Feb 9, 2011 at 4:58 PM
    NicksRig
    Kenora, Ontario
    Its probably more dangerous to use the cap to keep the fill going and getting back into your car. Thus creating the possibility of generating a static charge. So when you get out and grab the nozzel creating a spark and igniting the fumes around the fill hole.
  9. Feb 9, 2011 at 5:02 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    When I lived in MN, I never shut off my car during fueling in winter... *shrug* I am still here...LOL
  10. Feb 9, 2011 at 5:05 PM
    davestaco
    davestaco TW's number one gear whore
    David
    Schofield Barracks
    00' tacoma xtra cab trd v6 4x4
    chances of anything happening are slim but why chance it?
  11. Feb 9, 2011 at 5:07 PM
    Ted Nugent
    Ted Nugent Well-Known Member
    Tim
    NEPA
    2010 Reg cab 4x4
    I do this almost every time i get gas and it does nothing.
  12. Feb 9, 2011 at 5:09 PM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    ^^this
  13. Feb 9, 2011 at 5:24 PM
    neoflex
    neoflex Well-Known Member
    I do it all the time and never went Boom in my 20 years of driving. :crazy:
  14. Feb 9, 2011 at 6:00 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    fine, if you blow your own ass up..but kinda selfish even risking others..
    doesnt matter if it is a real threat or not..
    i shut the diesel off too, if it is next to a gas pump.
  15. Feb 9, 2011 at 6:06 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I say its no worse that the ones using the phone and fueling up. What about the people smoking in the same lot as you? I don't do it but couldn't care less if others did it. I understand all the possibilities but fail to see how it is any more dangerious than any of the things I have stated above.
  16. Feb 9, 2011 at 6:39 PM
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    Gasoline itself is not explosive (flammable yes), but gasoline vapors are extremely explosive and heavier than air. Outside those vapors stay close to the ground until dispersed by a breeze. So gasoline vapors would have to get high enough to be ignited by a spark somewhere on the truck. Not very likely. I would fuel up with the engine running if I needed to and not worry a bit. I mean has anyone seen a vehicle blow up at a gas station? Having said that, if you sit in the truck while fueling, ground yourself somewhere on the cab before touching the nozzle.
  17. Feb 9, 2011 at 6:42 PM
    rex99
    TArdCOMAWORLD
    Proton Cruiser
  18. Feb 9, 2011 at 6:49 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
  19. Feb 9, 2011 at 6:55 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    that vid looks a bit questionable... thats certainly not what i do when i fill up:rolleyes:
    my dad keeps his car running when filling up in the winter. every winter. for 38 years.
  20. Feb 9, 2011 at 6:56 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    damn, wonder how that happened?!!
    I also shut my truck and bike off when refueling. Last thing I need is to spill some gas on the hot engine of my bike and go boom.
