Running lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WNYBill, Oct 6, 2023.
  1. Oct 6, 2023 at 8:07 AM
    WNYBill
    WNYBill [OP] Active Member
    Bill
    Tacoma SR
    My "bottom of the line" 22 Tacoma does not have running lights. You can use the parking lights and I like that because it then has taillights, however I can't remember to turn them off. I haven't had the truck long enough to know if the truck is "smart" enough to turn them off or will the battery run down? I believe they are led lights, so won't use much juice. Do the parking lights have an auto shut off feature?
    pastoreater likes this.
  2. Oct 6, 2023 at 8:13 AM
    BoomerGVNG
    BoomerGVNG GET OFF MY LAWN
    2022 TRD SPORT DCSB
    My 22 sport with auto headlights will turn the lights off, if i leave them on the "on" position during daytime rainy driving (not dark enough to utilize the Auto on feature"
    if you want to test it, turn them on and lock the truck. wait 20 mins and check.
    Stevie17 likes this.
  3. Oct 6, 2023 at 8:18 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    On a lot of Toyotas you can leave them on, lock it.....and theyll stay on a bit. But if you hit lock a second time they go off.
    Not sure on the 22 Taco though.
  4. Oct 6, 2023 at 8:23 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    page #211 in the owner's manual, starts the headlight switch section
    Stevie17 and fathomblue like this.
  5. Oct 6, 2023 at 8:39 AM
    fathomblue
    fathomblue I used to be disgusted; now I'm just amused.
    Richard
    Eastern Kansas
    Cavalry Blue 2019 DCSB SR5 4x4
    Damnit man, I was just about to post that page of the manual myself. Now you've made me waste a screenshot.:annoyed::rofl:
    I will add that you can adjust that 30 second timer to 60 or 90 seconds or, I think , to off in vehicle settings on the head unit.
    Edit: Handy thing that manual, eh?
    Stevie17 and Chew[QUOTED] like this.
  6. Oct 6, 2023 at 8:47 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    The truck will turn them off. Also, your truck has daytime running lights, which on your model is the front turn signals constantly on until turn signal is selected, at which point the selected side blinks. After the turn maneuver is complete, that respective side goes back to full brightness for DRL. At night time, once parking lights or headlights are selected, the drl turn signal bulbs dim down to the lower filament for normal running lamp operation and blink brighter for turn signals.
    in other words, if you’re going for visibility, you’re already visible with your Amber turn signal DRL.
  7. Oct 6, 2023 at 9:06 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    very, so much so, many of us have it on the ready!
    Stevie17 and fathomblue[QUOTED] like this.
  8. Oct 6, 2023 at 9:36 AM
    caribe makaira
    Caribbean, Puerto Rico
    Do you mean Daytime Running Lights? 'Cause you do, they are your TURN bulbs.
  9. Oct 6, 2023 at 9:52 AM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    Does the base model have an auto setting? ...I thought that was the higher trim levels.
    Are you able to use the repair manual on your phone?
    The file size is a lot larger than the owners and I think several thousand pages......it doesn’t work well on my phone.
  10. Oct 6, 2023 at 10:11 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    I was referring to owner’s manual, I don’t have a need for repair manual
  11. Oct 6, 2023 at 10:21 AM
    pastoreater
    pastoreater doesn't know
    M
    5g 4runner
    Yes OP drive with your parking lights on. I believe they do turn off as others posted, you'll check it over yourself I'm sure.
    on tacoma, does the dash dim with parking lights on . . . this is the behavior of 4runner, and the dash is dim to see at midday with my :cool: on. Has anyone done a mod to turn parking lights on with the drl switch position (and the dash staying bright)? So after mod you would have on the stalk, off, drl (modded to turn on parking lights), parking lights (dim dash), lo beam.
  12. Oct 6, 2023 at 11:15 AM
    WNYBill
    Bill
    Tacoma SR
    No "auto" setting on my trim level, does have auto dim. No day time running lights either. Unless you have to be in "drive" for them to turn on I'll check that.
    Stevie17 and pastoreater like this.
  13. Oct 6, 2023 at 11:22 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    I have the lowest trim SR. If I leave the headlights on with the truck off they turn off automatically after 30-60 seconds. I don't have the "auto" setting. Just off, DRLs, Parking lights, and On.
  14. Oct 6, 2023 at 12:46 PM
    caribe makaira
    Turn engine On, release parking brake, set again. Go outside and view them (DRL's)
