Running lean and rich at the same time.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Turdyota3000, Dec 25, 2019.
  1. Dec 25, 2019 at 5:40 PM
    Turdyota3000
    Turdyota3000 [OP] Well-Known Member
    Round da corner
    07 dcsb trd off-road
    Icon 2.5's, TC, yackety shmackety....
    Has anyone experienced this before? Running super rich on bank 2 and lean on bank 1. I’ve tried many things with no avail. It is a new/remanufactured engine, that recently replaced a new remanufactured engine due to washing the pistons. New injectors, MAF sensor, up and downstream sensors. My fuel trims are all over the place, any ideas?
  2. Dec 25, 2019 at 5:43 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Are these new injectors oem or eBay specials?
    Taco-Obsessed likes this.
  3. Dec 25, 2019 at 5:44 PM
    Turdyota3000
    Round da corner
    Fuel injector clinic.
  4. Dec 25, 2019 at 5:50 PM
    Empty_Lord
    Dan
    The only time I’ve ever had issues with rich on one side and lean on the other were from fake oem injectors just not spraying correctly.
  5. Dec 25, 2019 at 5:52 PM
    Turdyota3000
    Round da corner
    Replaced the injectors due to running rich on bank 2. Now I’m lean and rich.
  6. Dec 25, 2019 at 9:10 PM
    Turdyota3000
    Round da corner
  7. Dec 25, 2019 at 9:56 PM
    Muddinfun
    Muddinfun Well-Known Member
    Just shootin from the hip here, but any chance the O2 sensor harnesses are reversed? The ECU leans out 1 side, because it thinks it’s rich, but it’s leaning out the wrong side. At the same time, it’s richening out the other side, but it’s reading the lean side, so it just keeps on getting richer. Don’t know if all that’s possible, but just a thought that came to mind.
    b_r_o and gasgasman like this.
  8. Dec 25, 2019 at 9:57 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    Lower intake manifold vacuum leak?
  9. Dec 25, 2019 at 9:58 PM
    Bishop84
    Bishop84 Well-Known Member
    Fuel pressure is my suspect.
    If its low, the one rail will get higher pressure than the passenger side.
  10. Dec 25, 2019 at 10:02 PM
    Turdyota3000
    Round da corner
    I was thinking about a vacuum leak as well. Also had someone tell me to check the fuel pressure regulator but I didn’t know if it would have that kind of effect?
  11. Dec 26, 2019 at 5:58 AM
    Turdyota3000
    Round da corner
  12. Dec 26, 2019 at 6:10 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
  13. Dec 26, 2019 at 6:10 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    I would troubleshoot one step at a time. If the wiring were flip flopped then you would be getting one rough as hell running engine considering the firing order. Check the fuel pressure in the rail first to eliminate anything from the fuel pump forward. What size are your FIC injectors? Are you S/C or turbo? Is this a 2TR or 1GR? I have a complete set of stock TRD and supercharged injectors in my garage that are good, but I think more diagnosis is needed for you.
  14. Dec 26, 2019 at 6:13 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
  15. Dec 26, 2019 at 6:43 AM
    Turdyota3000
    Round da corner
    Good one :rofl:
  16. Dec 26, 2019 at 6:49 AM
    Turdyota3000
    Round da corner
    1g NA and the injectors are the right size.
    @JustDSM has been helping me with this and I think it has him scratching his head as well.
  17. Dec 26, 2019 at 7:02 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    What is the fuel pressure in the rail? And you can confirm no vacuum leaks? What about swapping ECUs? I had one fault out one bank of injectors.
  18. Dec 26, 2019 at 7:03 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Ok isn't there just one fuel source? Low fuel pressure will make it run lean both sides, liquids don't compress well. I would like to know the methodology of how it's being tested.
  19. Dec 26, 2019 at 7:15 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    The injectors fire twice during each cycle. So firing order 1-2-3-4-5-6 Question, how was it determined that is rich on one side and lean on the other?
  20. Dec 26, 2019 at 7:15 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Yes. Pressure would be universal. However, it may not be high enough to keep up with the firing order of the injectors and when it exceeds the fuel pump capability then those cylinders run lean. It probably isn’t very rhythmic as well which would explain why the lean/rich scenario is jumping all around. I would put a pressure tester on the rail. I would be willing to bet your regulator or fuel pump is malfunctioning and not able to maintain over 40psi in the rail.
