Running fans with vehicle off
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GX82, Jun 5, 2023.
  1. Jun 5, 2023 at 5:39 PM
    GX82
    GX82 [OP] New Member
    2018 Inferno TRD
    Race winning truck
    Hi all,
    I'm glad to join this forum with other obviously high class individuals who drive such an esteemed truck. Anyways, to make a long story short, I bracket race my truck and would like to be able to cool it more efficiently between rounds. Is there a way to activate the cooling fans with the ignition off?
  2. Jun 5, 2023 at 5:42 PM
    caribe makaira
    Caribbean, Puerto Rico
    If your Taco has electric fans, yes.
    Chew likes this.
  3. Jun 5, 2023 at 7:15 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Welcome to the forum :hattip:
    I wasn't aware of the Tacoma coming with an electric fan unless the TSB for air conditioning had been applied.
    You can add any kind of fan you want along with a fuses, relay and switch. Be aware cooling fans pull quite a bit of power so this will be hard on the starting battery.
  4. Jun 5, 2023 at 7:36 PM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    If the truck is off, running a fan will just cool the radiator, and not circulate any coolant through the block.
    Have you tried letting it idle to cool down? I know race engines will heat up a lot, but a regular car should cool down at idle, with cold air coming through the radiator, cold air through the engine, and very little gas burning. I'll sit idle for a few minutes after a long climb off-road, and both the engine and trans temps come down (if I shut the truck off, they actually appear to increase after a few minutes).
    Chew and b_r_o like this.
  5. Jun 5, 2023 at 7:39 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    This^
    If you really want to do this, you'd need an electric fan and some kind of inline aux water pump (electric) like German cars have
    Chew likes this.
