RUNNING BOARD RECOMMENDATION, NOT OFF-RODE
Discussion in '3rd Gen. Tacomas (2016-2023)' started by STEVO 1957, Mar 2, 2020.
  1. Mar 2, 2020 at 12:57 PM
    STEVO 1957
    STEVO 1957 [OP] Active Member
    STEVE
    2005 TACOMA ACCESS CAB, LOADED
    NONE, REPLACED COMPONENTS WITH OEM PARTS WHEN NEEDED
    My 2020 VooDoo Blue Limited will arrive tomorrow. It will not be seeing any off-road except for mountain biking. I love the classic look of the boards on my 2005 SR5 Access Cab. I don't like the Cast Al ($975) factory boards. Any recommendations for something close to what I have now? I have been looking at Dee Zee NXt units (black on black). Any thoughts guys/gals? BTW the 05 has 353K miles, running like a top.
    Thanks All
  2. Mar 2, 2020 at 1:14 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    All I can say is there are a lot of options, you can go to 4 different websites and each one might have some options that the others don’t have
  3. Mar 2, 2020 at 1:22 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    You can get the same that you have, only in DCSB that your getting (2020 Limited). 2nd Gen running boards bolt right up to 3rd Gen.
    over60 likes this.
  4. Jul 25, 2020 at 11:27 AM
    ItWks4me
    ItWks4me Member
    Rebecca
    2006 Silver Tacoma TRD
    Stevo: What brand and where did you get your 05 Access running boards? I desperately need some for my 06 and I like the ones depicted on yours.
  5. Jul 25, 2020 at 12:10 PM
    angerbot
    angerbot Well-Known Member
  6. Jul 25, 2020 at 12:11 PM
    Shellshock
    Iowa
    I have the cast aluminum ones on my truck.
    If you like the ones on your access cab, you can get a set to put on the new truck. The mounts are the same between the second and third gen.
  7. Jul 26, 2020 at 8:31 AM
    STEVO 1957
    STEVE
    ItWks4Me, The running boards on the 05 are original factory, hard plastic type shell over steel, they have held up well, made it through the frame changeout OK. I did finally go with DeeZee Units. https://realtruck.com/p/dee-zee-nxt-truck-running-boards-black-board-with-black-trim/. Very happy with them, Powercoat with pressed in rubber grip ovals. Easy to install and the cost was $375? I don't know if the original 05 boards are still available from Toyota.
  8. Jul 26, 2020 at 10:08 AM
    Volt
    Volt Well-Known Member
    Overland Park, Kansas
    2022 SR5 4x4 Double Cab V6
    My fourth red Tacoma
    I was able to buy like new 2nd Gen Toyota brand running boards on Facebook Marketplace for $175. They had been stored in a guy's garage since 2012. They still had various Toyota stickers on them. Toyota running boards do turn up on Craigslist and Facebook fairly often. The 2nd Gens fit the 3rd Gens.
  9. Jul 26, 2020 at 12:11 PM
    JAMC
    JAMC Well-Known Member
    SW Ontario
    2019 TRD SPORT DC LB
    iboards BFmx4
    Ordered thru Amazon Canada. google iboard 6" ,part number IB-TRO58W, amazon US is the same part no. Made by APS
  10. Jul 26, 2020 at 12:18 PM
    JAMC
    SW Ontario
    iboards BFmx4
