Running board bolt holes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Signatureinc, Apr 18, 2022.
  1. Apr 18, 2022 at 2:33 PM
    Signatureinc
    Signatureinc [OP] Well-Known Member
    Doug
    Flat Land, Ontario
    2019 TRD OR Access Cab
    Hey you guys, I bought my rig used it had running boards (OEM) I took them off and want to put the plastic gromits back in the 12 bolt holes that are in the frame. Anybody have them in theirs that never had running boards? I called a dealer they said if I can get a visual they might be able to help me track them down or if you guys have any suggestions of what I can put in the bolt holes I’d be grateful. I’m thinking of bolts but don’t want anything that will f/up the threads in the holes…
  2. Apr 18, 2022 at 3:27 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
  3. Apr 18, 2022 at 3:32 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    SS bolts with teflon tape.
  4. Apr 18, 2022 at 3:32 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I was gonna suggest to pack it with grease......
    Signatureinc[OP] likes this.
  5. Apr 18, 2022 at 3:34 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    I took mine out. Can't remember what I did with those plugs? (I'll take a look when I get home and if I can find them I'll let you know)
    You can put some silicone in the holes and that should seal them up.
  6. Apr 18, 2022 at 3:37 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    I bought a box of those cheap plastic plugs that are used all over our trucks off eBay. They come in different sizes and I used them to plug the unused holes.
  7. Apr 18, 2022 at 3:46 PM
    Signatureinc
    Doug
    Flat Land, Ontario
    ya I found similar on Amazon but no clue if one or any would fit and stay in. Might have to trial and error a bit
    MadKatt[QUOTED] likes this.
  8. Apr 18, 2022 at 3:48 PM
    Signatureinc
    Doug
    Flat Land, Ontario
    Thanks man I don’t want to silicone them in case I want them again some day. Might have to buy a bunch of sizes and just trial and error them..
  9. Apr 18, 2022 at 3:50 PM
    Signatureinc
    Doug
    Flat Land, Ontario
    would you know the size that will fit I don’t want to try the wrong size and mess the threads
  10. Apr 18, 2022 at 3:52 PM
    AXL
    AXL Well-Known Member
    Axl
    Maryland
    Grumpy Old Veteran
    The bolts are M8 1.25. You can buy a short length bolt just for the sake of filling the hole.
  11. Apr 18, 2022 at 3:52 PM
    Signatureinc
    Doug
    Flat Land, Ontario
    If anybody knows the running board bolt size I could go that way rather than gromits..like a fool I sold the boards and didn’t measure the bolts before I gave them to the guy
  12. Apr 18, 2022 at 4:55 PM
    Signatureinc
    Doug
    Flat Land, Ontario
    thanks man much appreciated, I’ll see if I can get gromits otherwise bolts are another option
    AXL[QUOTED] likes this.
  13. Apr 18, 2022 at 5:15 PM
    HoosierAussie
    HoosierAussie Well-Known Member
    2019 Tacoma TRD Offroad
    I went to a local hardware store and they let me try a few different sized grommets before I found one that fit. Then I just went back in and bought the rest. Bolts would also work - grommets are just cheaper!
    Signatureinc[QUOTED][OP] and AXL like this.
  14. Apr 18, 2022 at 5:25 PM
    Signatureinc
    Doug
    Flat Land, Ontario
    ya bolts ain’t cheap lol
  15. Apr 18, 2022 at 6:28 PM
    tneynop
    tneynop Well-Known Member
    Charlie
    Levittown, PA (Bucks County, SE Pa.)
    '22 SR5 V6 DCSB 4x4 - Barcelona red, black w/red int
    Peragon tonneau, Vertex Offroad faux leather seat covers, Tufskinz interior dress up, Diode Dynamics stealth light bar, NFab nerf/steps
    May I suggest getting nylon bolts to plug the holes? Will not mess up threads, light weight and easy to install/remove.
  16. Apr 19, 2022 at 6:40 AM
    CT Yankee
    CT
    @Signatureinc: Metric nylon bolts may be hard to find at your local hardware or big box store which is why I suggested the plugs. Filling the holes with silicone may preserve the threads but it'll be a b!tch to remove in the future should you decide to utilize the holes. Using 316 SS M8-1.25X30mm bolts would cost you about $1.15 each at the site I recommended. Might take a day or 2 to get them if you order today. You might have to buy 15 cuz they come 5 to a package.
    BTW I do NOT have any association with McMaster - I have simply used them for decades for the hard to find stuff.
  17. Apr 19, 2022 at 7:04 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Before you put plugs in there, spray the insides of every hole with fluid film (also pull the rubber plugs on the rockers and spray in there) Or you will get a good amount of rust in there.
    Signatureinc[OP] and JJ Diablo like this.
  18. Apr 19, 2022 at 8:08 AM
    k20pham
    k20pham Well-Known Member
    KP
    2019 taco
    I run sliders now so I put the bolts from my OEM running boards back in place with some thread sealant.
  19. Apr 19, 2022 at 2:55 PM
    Signatureinc
    Doug
    Flat Land, Ontario
    I would have done the same but I sold the running boards :)
  20. Apr 19, 2022 at 2:58 PM
    Signatureinc
    Doug
    Flat Land, Ontario
    I found some on Amazon may just go that route thanks for the tip
