Running a OBD1 cat on a OBD2 truck
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dick4x4, Jun 23, 2013.
  1. Jun 23, 2013 at 8:35 AM
    Dick4x4
    Dick4x4 [OP] Well-Known Member
    Quebec
    2012 4x4 2.7 Auto
    I've just received my headers from trail gear and I'm preparing to upgrade my exaust.
    I currently have a small case universal fit IN/OUT 2.25/2.25. The new headers ends at 2.5" So I'd like to upgrade the complete exaust to 2.5".
    I'd also prefer to use a direct fit cat in case I want to replace it sometime with a shelf available part with just wrenching and no welding.
    I found quite affordable cats that was used on OBD1 Toyota Camry with 3.0L engine also on Supra 7MGE, and Nissan D21 and few other cars according to the Summit racing application chard.
    Theses have the stock 2 bolts flanges and 2.5" IN/OUT so will be a direct fit. They are a little bit shorter at 12 3/8" compared to the stock 16 5/8". The rest of my exaust will be custom made so no worry with that difference in lenght. Since all the applications are OBD1 I was wondering how really are the chance to cause MIL on a OBD2 car... I mean, the one I currently have is a wathever universal 2.25/2.25 short case that I badly fit (leak wise) under the truck and never have any MIL.
    Basically I think as long as I my sensor are properly installed and the exaust is leak tight it should be good!
    Any experiences?
  2. Jun 23, 2013 at 10:31 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Probly will trigger a code. Things like California emmissions or federal emmissions matter too
  3. Jun 23, 2013 at 10:33 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
  4. Jun 23, 2013 at 10:37 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
  5. Jun 23, 2013 at 11:03 AM
    SDSam
    SDSam from Dirt bike to Dezert Couch
    San Diego
    00 Tacoma prerunner
    Icon Shocks, BTF front, Deaver f67, 33's on stocks, Fiberwerxs 1pc, TDR S/C, Bed & Eng Caged
    Have to read under your hood decal what type of cat your car uses two way or three way cat and u have to install the same type
  6. Jun 23, 2013 at 4:16 PM
    Dick4x4
    Quebec
    2012 4x4 2.7 Auto
    P0420 is the code you receive if you have no cat or bad cat. Doesn't mean you gonna have it if you use a different cat.
    Cars are not controlled in any ways in my location. some people just cancel them and add a test pipe. I think it's a bad idea, it increase pollution and it smells shit big time.
    2 ways or 3 ways are just how are desingned the cat to react with exaust gas to work on 2 or 2 chemical reaction. But that's a good point. Therefore, according to wikipedia, they are all 3 ways since 1981.
  7. Jun 23, 2013 at 4:22 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Chances are there would be a po420, catalytic converter below threshold. But there's no solid way of knowing if it would happen or not, if you remove the cat on an obd2 vehicle with no o2 simulator it would have running problems as the ecu would be getting all sorts of bad readings
