Running a CPAP machine off the bed outlet?
Discussion in 'Outdoors' started by Taco.Tuesday, Mar 13, 2022.
  1. Mar 13, 2022 at 12:48 PM
    Taco.Tuesday
    Taco.Tuesday [OP] Well-Known Member
    New Mexico
    '21 TRD Sport 4x4 DCLB
    I'm gonna be going on a trip for a few days and was wondering if anyone has run appliances off the bed outlet, or seeing if the battery is capable of running a CPAP machine each night without dying for a few nights?
    Thanks in advance.
  2. Mar 13, 2022 at 12:53 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    The bed outlet is not powered unless the truck is running. You're going to waste a bunch of gas doing this.
    There are a LOT of threads on here about people figuring out how to run their CPAP machines off their truck battery, second battery, portable power station (like Jackery/Goal Zero), and more. Just do a search.
    Here's one.
    https://www.tacomaworld.com/threads/cpap-off-grid-setups.720860/
    Here's another:
    https://www.tacomaworld.com/threads/use-of-bed-mounted-power-outlet.747566/
    And another:
    https://www.tacomaworld.com/threads/camping-and-sleep-apnia-cpap-solution.13956/
    And so on.
  3. Mar 13, 2022 at 12:53 PM
    Louisd75
    Louisd75 Well-Known Member
    Northwest Washington
    '02 Xtra Cab, '15 DCSB
    Do you have the option of a 12v CPAP? Only reason I suggest this is because there will always be some loss running an inverter; you'll get more bang for the buck if you can go straight 12v. This goes for things like electronic chargers. It will never be as efficient converting DC to AC and then back to DC again.
    Casper66 likes this.
  4. Mar 13, 2022 at 1:00 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    You don’t need to. They will run off either, well most will. They make a simple DC adapter. This is how I run mine in our tiny camper.
    OP a DC adapter and a good jump box will work for a couple of nights if you run only the CPAP with no heat or water.
    If this is something you want to do regularly I’d suggest an auxillary battery and a suitcase solar you can recharge it with.
    Sprig likes this.
  5. Mar 14, 2022 at 9:19 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    A regular 12v car battery will run a cpap for 5 to 7 days 8 hours a night. If you use a heated humidifier that will reduce the amount of time the battery will last. You can buy an adapter so you can run the cpap directly from the battery terminals or plug it into a cigarette lighter. Your best bet is to get a separate battery so you don’t run your car battery down. Each adapter is made for a specific cpap brand and model. If you have other questions let me know.
    As others have said the bed outlet only works when the engine is running.
  6. May 16, 2022 at 6:38 PM
    tonykarter
    tonykarter Crappie Savant
    Snuff Gully, Texas
    2018 DCSB 4x4 Sport 1993 4Runner SR5 4x4, 411,000 miles
    Pine tree air freshener
    That's my old DeVilbis CPAP hung from the ridgeline in there with me. An old battery jumper that uses a 33amp/hour battery would power it (without water or heat) for three nights, no problem. It was a power miser. My new AirSense 10 is going to be a problem. Specs say it pulls 3 amps? Not sure how that's going to work. Add in the heated tube shown and I'm going to need a lot of battery. Even with the heated tube when it gets down below freezing I have to connect an additional 6-foot hose and run it down into the sleeping bag so the warmth contained in there will help heat the air. How's the AirSense 10 gonna' work? News at 10...
    20160321 - Dream Hammock Sparrow, on stand in shop, showing slope of most comfortable hang.jpg
    20160421 - Spring Crappie Camp at Rayburn, how the poor (and smart) people do it.jpg
  7. May 16, 2022 at 9:06 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    The Airsense 10 is 24v DC, you can buy a converter for it that steps 12v DC up to 24v DC so that you don't have to use an inverter and go 12v DC to 120v AC to 24v DC. 12V DC would be much better and some of the newer machines are 12v but using the battery adapter works better than an inverter. Also swap on a block off plate (so no water reservoir) and cut the heater and hose heater off. It saves a lot of power plus you don't have to worry about the dreaded rainstorm. A fleece cover for the hose will help a bit.
  8. May 17, 2022 at 6:02 AM
    Icky_Thump
    Icky_Thump New Member
    M
    2021 Mag Grey TRD PRO
    I use a Jackery with the 12v Car adapter. Works great and lasts more than 2 nights without needing a charge.
  9. May 17, 2022 at 6:49 AM
    KactusJack
    KactusJack Well-Known Member
    Collettsville, N.C.
    2014 AC TRD Sport
    I have an Airsense 10. I got the 12v to 24v converter for it, and on a recent camping trip, got three 7-8 hour nights on a jump battery, with humidifacation turned off. (The larger jump-start battery, not the newer "pocket sized" jump starter.) Still had some juice in the battery. The adapter is expensive, though, around $90 as I recall.
  10. May 17, 2022 at 7:31 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
  11. May 17, 2022 at 8:11 AM
    spitdog
    This is the adapter I bought and it works good. A lot cheaper than the Resmed brand.
    https://www.amazon.com/KFD-Airsense...ed+24,aps,90&sr=8-1-spons&smid=A2ALLIRJWD0RCV
  12. May 17, 2022 at 2:05 PM
    Bajatacoma
    SC
    I think that's one I have as well. The battery pack Resmed wants to sell you is like $300 and doesn't last as long as a marine battery, of course it's not as big or nearly as heavy either but I already had a marine for a house (truck camping) battery and trolling motor; it died this past winter and I still need to replace it but I can sleep without the cpap.
