running 93 octane
Discussion in 'Performance and Tuning' started by commtrd, Jun 24, 2009.
  1. Jun 24, 2009 at 1:38 PM
    commtrd
    commtrd [OP] commtrd
    Corpus Christi TX
    09 Access Cab 4wd V6
    I had a road trip with around a thousand miles so I thought I would put the 93 octane to the test in my truck.('09 access cab v6)
    It seemed very sluggish and passing on the highway could get pretty iffy with the truck feeling like it was dragging an anchor. I hated it. Acceleration almost non-existent. I was using 93 octane from Chevron and others. Not sure if it had any ethanol in it or not. Gas mileage was not any better either. Inside of exhaust pipe outlet was covered with black soot where before it was relatively clean.
    So I spent about 25 to 30 cents a gallon extra and I am going back to regular unleaded. My truck just runs better on regular.
  2. Jun 24, 2009 at 1:40 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    I highly doubt one tank of gas caused your exhaust to gunk up.
    Chevron doesn't use ethanol, at least not around here. If your truck runs better on 87 then go for it! It is cheaper anyway haha
    Rambo54 likes this.
  3. Jun 24, 2009 at 1:45 PM
    commtrd
    Corpus Christi TX
    I used over three tanks. Going back to regular. My truck ran like shit on 93 octane.
  4. Jun 24, 2009 at 1:48 PM
    DanGer
    That is interesting. The compression of our engines is supposed to perform better with higher octane. Not to mention chevron provides one of the highest quality gases you can easily get.
    AZ_Charles and Rambo54 like this.
  5. Jun 24, 2009 at 1:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I have never liked Chevron. My Trucks seems to not like Chevron, or Mobil....
  6. Jun 24, 2009 at 1:50 PM
    DanGer
    Thats very interesting because my truck seems to thrive on it. Its the only chain i have found that my truck seems to like
    Rambo54 likes this.
  7. Jun 24, 2009 at 1:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think it has more to do with where th agasoline comes from, than it does the chain. Out here, We have 2 fuel distributers, that deliver the gas to the chains. We have Union, and Firebird. Fuel from Union seems to suck, while fuel from Firebird seems to give good performance.
    Taco Fan likes this.
  8. Jun 24, 2009 at 1:57 PM
    DanGer
    Good to know!
  9. Jun 24, 2009 at 2:42 PM
    commtrd
    Corpus Christi TX
    I filled up at several different stations (not exclusively Chevron) twice at Valero stations once at an HEB and the rest at Chevron. I really don't feel like it is Chevron gasoline per se rather that the engine in my truck is not high enough compression to really need a slower burning gasoline. The results I got seem to bear that out. I have a Pro-Dry drop-in filter, Magnaflow muffler, 265/70/R17 tires and 5100's all around with the fronts set on 1 notch up so the lift is not excessive. In other words, the truck is not radically altered from stock. So my results did not indicate (to me) that it is a benefit to use 93 octane gasoline. Someone else may get better results on the higher octane from their truck which I cannot explain. All I can say is for the considerable higher cost of premium, the benefits were not there. It would be very interesting to know for sure what the control algorithms are implemented in the computer(s) for the 4.0 litre V6 engines. Also what the actual compression ratio is supposed to be in the V6. 93 octane is primarily there for use in higher-compression engines (and air-cooled etc.) to help prevent detonation due to higher compression and/or hotter running (air-cooled). Usually a higher-compression engine is said to be running well over 10 : 1 compression ratio.
    BUT if someone else's truck seems to run better on 93, then pay up! I am looking forward to getting all that 93 out of my tank so my truck will accelerate again.
  10. Jun 24, 2009 at 2:48 PM
    commtrd
    Corpus Christi TX
    Maybe the 4-cylinder engines do run better on the higher octane gasoline. When I had my 2000 model with a 22RE 4-cyl. it ran like a top on regular. It REALLY hated any ethanol though...
  11. Jun 24, 2009 at 5:57 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    He's talking about a V6. ;)
    My 4 banger seems to do pretty good for me with 91, don't have 93 around me. :)
    Rambo54 likes this.
  12. Jun 24, 2009 at 6:27 PM
    Phantom_X-SP
    Phantom_X-SP Rude Boy |><|
    High Point, NC
    08 DC Black Sand Pearl X-SP
    My truck kicks ass on 93 octane. I use Shell V-Power only.
    Nojuanhatedtacos and Rambo54 like this.
  13. Jun 24, 2009 at 6:30 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Mine ran great on 92 octane. 23 MPG. :D
    Rambo54 likes this.
  14. Jun 24, 2009 at 6:52 PM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    I have been running both BP and Shell 93 and my truck feels so much better on it.
    It is very noticeable over the 87 I was using.
    I could even tell the difference between the BP 93 and the Shell V-Power. Shell will get my business!
    As for MPG, I am only getting about 1.5 mpg better. I am stretching my test over 5 tanks and have 2 more to go.
    Rambo54 likes this.
  15. Jun 24, 2009 at 7:22 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    I had the same experience--Ran 91 for awhile, then 87. With the 91 it felt like driving with the e-brake on. I ran it down to near empty and filled up with 87 and it ran sooo much better. Much more responsive and better MPG. What gives??:confused:
  16. Jun 24, 2009 at 11:03 PM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    Going from 87/89 octane to 93 isn't going to make the truck perform badly. In most cases you won't see a difference running a higher octane, unless you are custom tuned, knocking, or running more spark advance then normal.
    You said that the tail pipe had a lot of black build up which tells me it was probably running rich. That seems to be your issue, not the octane level. Octane levels won't dictate what you AFR will be unless you custom tune it, or put the ECU into its low octane mode (I forget the technical name). If that's the case, then resetting the ECU will set it right.
    I would be willing to bet if you reset the ECU and continue to run the 93 it will run the same as it did before.
    You are correct with the purpose of higher octane, and you are correct that the 1gr is a 10:1 CR motor.
    During summer heat I highly recommend higher octane to protect the motor.
    DanoDavis and Rambo54 like this.
  17. Jun 25, 2009 at 2:05 AM
    dwntwnall4u
    dwntwnall4u Well-Known Member
    Kevin
    san diego
    2013 4x4 Dbl cab Auto
    Did you get 92 in San Diego? Where?
  18. Jun 25, 2009 at 3:52 AM
    coma09
    coma09 Updated avatar
    BC Canada
    2013 taco access cab 4x4
    87 has more 'power' than 93. The higher octanes are for higher compression engines, and don't detonate (ping) as easily as loer octane rating. The common misconception is 93 gives more power ... only if the engine has the higher compression (high performance engine, eg) So sports cars/'race' cars use 93 .. but not because it's more powerful fuel
  19. Jun 25, 2009 at 4:42 AM
    Phantom_X-SP
    High Point, NC
  20. Jun 25, 2009 at 10:29 AM
    sriley727
    sriley727 Well-Known Member
    Aiken, SC
    08 Reg cab PreRunner SR5
    Bone stock
    I don't know if late model tacomas have knock sensors or not but if they do, the computer should advance the ignition timing when 93 is used and generate a little more power.
