Running 33's
Discussion in '3rd Gen. Tacomas (2016-2023)' started by L1M3Y, Feb 11, 2020.
  1. Feb 11, 2020 at 8:27 PM
    L1M3Y
    L1M3Y [OP] Greasy Rig Pig, Doing Greasy Rig Pig Things.
    Alberta
    2020 Tacoma TRD Sport Auto DCLB
    What would I need to do to fit 33's?
    Anyone that has them, did you re-gear your truck? If not how much of a difference did it make on your MPG's.
    What is the stock gear ratio on my 2020 TRD sport v6 3.5l?
    3.909?
  2. Feb 11, 2020 at 8:38 PM
    Anderson5290
    Anderson5290 Well-Known Member
    Brandon
    Corona, Ca
    2018 Tacoma TRD OR 4x4
    Tuned Fox 2.5 resi with dsc, JBA HD UCA, total chaos knuckle gussets, rear trd pro fox shocks, Deaver U402 stage 1 rear leafs, archive garage u bolt flip with fox 2.0 air bumps, White knuckle off road rock sliders, BAMF 1/4” steel skids, Magnaflow exhaust, Archive Garage Hammer Hangers, Cbi high clearance rear bumper, 285/75/16 tires.
  3. Feb 11, 2020 at 8:46 PM
    Anderson5290
    Brandon
    Corona, Ca
    On a serious note. Just use the Search bar, there is tons of info on running 33 inch tires here. Look up CMC (cab mount chop), and check out the mega 5.29 and 4.88 threads. Fill out your info page more as well, auto or manual trans? List any mods you have or just put bone stock.
    Noch, Rockefelluh, Grindstone and 4 others like this.
  4. Feb 11, 2020 at 10:14 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Search is your friend. These questions have been asked dozens of times.
    Ch78, Joe.Dirt, Rockefelluh and 3 others like this.
  5. Feb 11, 2020 at 11:21 PM
    Savoia
    Savoia Well-Known Member
    Ray
    2018 Quicksand Tacoma TRD Sport 4x2 DCSB
    Tonight's full of over asked questions today:rofl:
    GillyLink, shane100700 and Mully like this.
  6. Feb 12, 2020 at 6:30 AM
    shouldveboughtajeep
    shouldveboughtajeep Active Member
    Daniel
    2020 TRD OFF-ROAD
    4in suspension lift on 33's
    I have 33x12.50 on 17x9-12 wheels. I did a 4/3 lift which netted me 3.5” in the front and 3” in the rear. I also did after market upca which gave me +3.6 caster. My truck is a 2020 DCLB. I only have had a little tire rub when I was running a couple trails out at browns camp with my sway bar disconnected. When my sway bar was connected I got ZERO rub. AC949974-B87B-4B13-AE8B-C553445A3A8A.jpg
  7. Feb 12, 2020 at 6:36 AM
    4x4erik
    4x4erik Well-Known Member
    Erik
    2018 White Tacoma TRD Sport Double Cab 4x4
    -Currently Leveled (Bought that way) -265/70r17 Nitto Ridge Grapplers -OEM Sport Wheels with 1.25" wheel Spacers -Many Changes Coming soon! See my old Jeep and now my Tacoma build @4x4erik
    A post like this is added VERY often. Everyone who's lifted is running between a 32-34" tire... A 285/70r17 is the most popular imo, and there is a sweet tire size calculator on tacomaworld that tells you roughly what that measure... With this size tire, even with a 3" lift, you are still going to have to trim, especially if you wheel. You will see a couple people who are doing it without, but I'd assume they are mostly street driven. (Nothing wrong with that)
    A 6" lift will allow you to run 33s as well, with less trimming.
    There are so many variables to the answer of this question, but you can do it, you just may have to do a little bit more than what you thought you were going to have to. As for a regear? This is entirely up to you and what your doing. Do you NEED a re gear? No. May you WANT a re gear? Maybe. Look up 3rd generation gear ratio chart.
    Chase9, shane100700 and L1M3Y[OP] like this.
  8. Feb 12, 2020 at 6:37 AM
    4x4erik
    Erik
  9. Feb 12, 2020 at 6:47 AM
    L1M3Y
    Alberta
    Looks awesome man! What lift did you go with and uca? Did you have any issues with the vibes I have been reading about after lifting and had to change the ecgs? @shouldveboughtajeep
  10. Feb 12, 2020 at 6:49 AM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    I'm stock suspension except for a leveled front end. I did the CMC and pinch weld and some inner fender trimming. No rubbing on 285s.
  11. Feb 12, 2020 at 7:08 AM
    shouldveboughtajeep
    Daniel
    2020 TRD OFF-ROAD
    I had som rear driveline vibes that got corrected with carrier bearing spacer. up front the lift kit came with a diff drop and I haven’t experienced any front end vibes but just for precautionary reasons I’m doing the ecgs bushing this weekend. For lift I went with https://4x4.fatbobsgarage.com/toyot...orce-suspension-package-2005-2019-p33238.aspxand for upca I went with https://www.suspensionconnection.co...MIxrW8kaXM5wIVD9VkCh1ZUQ2SEAQYAyABEgLZsfD_BwE also I bought the truck with 3 miles on it. I lifted with 20 miles on it. It now has 4200miles and I’ve had zero issues with it so far.
  12. Feb 12, 2020 at 2:30 PM
    L1M3Y
    Alberta
    This is what I was thinking about doing, but I've read a lot of things that have scared me away from it. Have you personally had any issues? @Thunder Fist
  13. Feb 12, 2020 at 2:36 PM
    kherron
    kherron Well-Known Member
    Kevin
    Folsom, CA
    2020 Tacoma TRD Pro
    Scared you away from what, the CMC? What did you read?
  14. Feb 12, 2020 at 2:40 PM
    L1M3Y
    Alberta
    Probably should have asked how he leveled first. Lol. What scares is me spacers lol
  15. Feb 12, 2020 at 2:45 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Keep it stock, there is alot more to lifting these trucks than just installing a set of coilovers. Do lots of research before you buy anything. Good luck with your truck.
    Mr-Paul and L1M3Y[QUOTED][OP] like this.
  16. Feb 12, 2020 at 7:36 PM
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
    I did, in fact, use a spacer. No need to be scared of that. No change in ride quality. No issues off roading. They’ve been on there for a while now through all kinds of conditions. I’d know by now if there was going to be problem.
  17. Feb 12, 2020 at 8:51 PM
    L1M3Y
    Alberta
    Ok cool. What spacer size did you go with and could you send a link if possible? @Thunder Fist
  18. Feb 12, 2020 at 9:24 PM
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
    I got it from @HeadStrong Off-Road. Shoot them a dm and they’ll tell you what to measure to make sure you get the right size.
    L1M3Y[QUOTED][OP] likes this.
  19. Feb 13, 2020 at 12:46 AM
    L1M3Y
    Alberta
    Awesome! Thanks dude!:thumbsup:
    Thunder Fist[QUOTED] likes this.
  20. Feb 13, 2020 at 4:27 AM
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
    For reference.
    shane100700, Rockefelluh and Tommyb08 like this.
