Running 20x10 rims
Discussion in 'Wheels & Tires' started by Glenmoore785, Feb 21, 2023.
  1. Feb 21, 2023 at 8:59 PM
    Glenmoore785
    Glenmoore785 [OP] Member
    Glen
    Kansas City
    2019 Tacoma TRD Sport, Manual
    3" RC leveling kit with rear extended shocks 1.5" Wheel spacers 285/70/17 MT Brush guard Black Horse Rollbar
    2019 TRD Sport Double cab
    3" leveling kit
    What are the odds of these rubbing? What kind of trimming do you think would have to happen
    Mostly highway driving but want to be able to do some light off roading as well.
    Who is running 20" wheels???
    What you got?
    WHEEL SPECS
    Brand: Vision
    Model: Spyder
    Model Other: 361
    Part Number: 361-20083GBMS-25
    Backspacing: 4.5
    Bolt Pattern: 6x5.5
    Offset: -25mm
    Wheel Diameter: 20
    Wheel Width: 10
    Hub Bore: 106.20
    Load Rating: 2500
    Wheel Exposed Lugs: Yes
    Wheel Material: Alloy
    Wheel Structure: One Piece
    Wheel Spoke Number: 8
    Wheel Style: Mesh
    TIRE SPECS
    Brand: Radar
    Model: Renegade RT
    Inventory Number: RASYTH0122
    Aspect Ratio: 55
    Inflated Diameter: 32.6
    Inflated Width: 11.7
    Load Index: 122/119
    Load Range: E
    Max Load Pressure: 3305/3000@80
    Ply: 10
    Section Width: 285
    Service Description: 122/119Q
    Sidewall: Black
    Speed Index: Q
    Tire Rim Diameter: 20
    Tire Type: Hybrid AT/MT
    Tread Depth: 15.75
    Weight: 58.83 lbs
  2. Feb 22, 2023 at 5:31 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Going to rub like crazy.
    If your going to wheel the truck at all avoid 20 inch wheels.
  3. Feb 22, 2023 at 4:55 PM
    Glenmoore785
    Glen
    Kansas City
    Any suggestions? I want to do 33s and 10 wide. I am really looking for a good offset that I dont have to chop cab mounts.Front fender, bumper trim is ok, They are getting changed this summer. But I want to find a middle ground with a larger size rim and stay about 32.5x10 to 33"x10 tire, I would go 8 wide even. I want an aggressive tire and a little poke.
  4. Feb 22, 2023 at 5:01 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    285/70/17 17x8.5 -10 or -12 and call it good. Still may need to trim. Or to be safe 17x8 0 offset.
